QUOTE(dr914@autoatlanta.com @ Mar 31 2010, 01:06 PM)
QUOTE(buhs914 @ Mar 31 2010, 12:59 PM)
Ok so i did a full check to see why my tachometer stopped working and i can't figure it out. I believe it may be the tach itself and not the connections. Is there someone in the area who could take a look at it or something one of these days? thanks.
If you are sure that it is the tach that is bad send it to Palo Alto and to the attention of hartmut. He is really good and vdo factory authorized.
Also North Hollywood Speedo repairs them, but I agree with the others above - esp. on a student's budget - test in another car, check anything you may have changed & all connections & wiring for wear/cracked insulation/shorting-out, the maybe try to get an inexpensive used one for now & save your original one to restore at Palo Alto or N Hollywood when you're bucks-up!
