Spare tire size, What should I do ? |
johannes |
Apr 2 2010, 09:30 AM
Club Porsche 914 France President Group: Members Posts: 3,084 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
I would like to save space in the boot and also a bit of weight on the spare tire.
I have a 5.5 Mahle rim and I wondered what is the smalest tire that could fit on this rim ? I was thinking of a 135/80. (IMG:style_emoticons/default/idea.gif) I don't care about same size as the other wheels, I would only use it as temporary spare I could also hunt for a 4.5 steel rim (paint it red) but I don't think I will save weight with this one. Of course there is the "no spare" option, but I don't like it. |
Drums66 |
Apr 2 2010, 01:27 PM
....Johannes
I found a space saver spare in 1 of the wrecking yards here in the states out of a fairly current VW 4lug(rabbit) that worked out great.....less weight and space. I would suggest 1 o (IMG:style_emoticons/default/idea.gif) f those......just a thought like you said....don't have to use it often!! (IMG:style_emoticons/default/bye1.gif) |
Tom_T |
Apr 2 2010, 02:11 PM
Johannes - the 135/80R15 would have 3 wheels up & 1 down if you ever have to use it, since it's a shorter tire, which IMHO not good on a 34-40 year old car's suspension.
Instead, look for one of the Michelin, Continental, Bridgestone, Kleber, Semperit, etc. new Eco/Energy Saver tires in 165/80R15, because they're making them lighter for less rolling resistance/inertia to get going, in order to improve fuel efficiency - especially on Hybrids. Right size but supposedly a few pounds/kilos lighter per tire, & would still work as a fill size spare on the car in an emergency. |
johannes |
Apr 2 2010, 04:32 PM
....Johannes I found a space saver spare in 1 of the wrecking yards here in the states out of a fairly current VW 4lug(rabbit) that worked out great.....less weight and space. I would suggest 1 o (IMG:style_emoticons/default/idea.gif) f those......just a thought like you said....don't have to use it often!! (IMG:style_emoticons/default/bye1.gif) I thought Rabbits had 4x100mm pattern ? you speak only from the tire ? |
johannes |
Apr 2 2010, 05:05 PM
Johannes - the 135/80R15 would have 3 wheels up & 1 down if you ever have to use it, since it's a shorter tire, which IMHO not good on a 34-40 year old car's suspension. Instead, look for one of the Michelin, Continental, Bridgestone, Kleber, Semperit, etc. new Eco/Energy Saver tires in 165/80R15, because they're making them lighter for less rolling resistance/inertia to get going, in order to improve fuel efficiency - especially on Hybrids. Right size but supposedly a few pounds/kilos lighter per tire, & would still work as a fill size spare on the car in an emergency. Its not for driving long trips. Its a spare "just in case"... In France you are never more than 20 miles away from a garage. |
URY914 |
Apr 2 2010, 05:35 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,693 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I have a 135mm that I bought at a VW store 20 years ago. Perfect space saver spare.
Elliot Cannon |
Apr 2 2010, 05:58 PM
I use a space saver tire with a five lug wheel adapter. I use a small pony SCUBA bottle with the first stage of a SCUBA regulator for air. The regulator steps the air pressure down to about 120psi. Works great.
Attached thumbnail(s) |
johannes |
Apr 3 2010, 02:28 AM
Drums66 |
Apr 3 2010, 12:18 PM
I have a 135mm that I bought at a VW store 20 years ago. Perfect space saver spare. The 1 I have is this size(135mm)....on a 15' rim any VW(space saver) that is comensurate..will work is my point!! (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/flag.gif) (IMG:style_emoticons/default/shades.gif) P.S. do you have 5 or 4 lug?? |
johannes |
Apr 4 2010, 01:56 AM
I have a 135mm that I bought at a VW store 20 years ago. Perfect space saver spare. The 1 I have is this size(135mm)....on a 15' rim any VW(space saver) that is comensurate..will work is my point!! (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/flag.gif) (IMG:style_emoticons/default/shades.gif) P.S. do you have 5 or 4 lug?? I have 4 holes in 4x130 pattern... I don't think Golf has 4 x 130 |
Lo-Fi Version | Time is now: 19th May 2024 - 12:03 PM |
