One of the reasons I've been so Busy - Visor clips, Yes a set of all 3 - $50 for now $65 after April 20th |
Mikey914 |
Apr 2 2010, 12:08 PM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I've been playing around with these for awhile (almost 4 months) and with everythig else on my plate didn't want to start another pre purchase sale for an item that I didn't know if it could ship with others (timing). You can sign up here or I will allow you the option to combine with any other prepurchase items taht are running (form letters will be going out late this evening)
Here's the details on these The ends are available from Porsche, they are a superceeded part number for the 964. about $54 each. The rub, they are not textured like the original 914 ones. Kind of minor but for that kind of cash I want something that matches. So I reporduced these with the same texture as OEM started with. The other issue is the pins. The OEM ones where chromed steel. They rusted after the chrome was breached. Not a big deal, but why not improve it? Mine are machined stainless, no rust. They're shiny, and I don't think you'ld even notice once installed. The other issue is cracking. While the plastic isn't very thick, the factory ones have a void behind them. It uses less material to make them that way. Mine are solid. The thought was as a solid part would be less points. The pins are cast into the parts and I did do this to the center part. These will start shipping late next week (Thursday or Friday). Let me know if you need them. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 20th May 2024 - 03:17 AM |
