West Caldwell PPI, 1976 2.0L |
rmital |
Apr 7 2010, 06:20 AM
Northeast optimist Group: Members Posts: 1,946 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
The only real problem I had with this car was the asking price. Most if not all 914 owners would love to be driving this '76 around and wrenching away on the weekends, but for about 3K less than what the current owner is asking.
I'm sure if the current owner does some investigation on current prices; even on Ebay or searching the websites for comparable cars, he'll realize the 10K+ is just not reasonable for a car with as many flaws as it has. I think this would be a good buy for the buyer at 6K...or a great sell for the seller at 7K. |
rmital |
Apr 7 2010, 06:23 AM
I'll start with the good:
The lines of the car were great. Nice and straight. Passenger side Attached image(s) |
rmital |
Apr 7 2010, 06:24 AM
sail clip replaced, holes for bottom chrome filled:
Attached image(s) |
rmital |
Apr 7 2010, 06:25 AM
driver's side lines:
Attached image(s) |
rmital |
Apr 7 2010, 06:27 AM
driver's side sail also replaced:
Attached image(s) |
rmital |
Apr 7 2010, 06:30 AM
both front and rear lids opened and closed nicely:
Attached image(s) |
rmital |
Apr 7 2010, 06:36 AM
all rust was repaired in the trunk:
Attached image(s) |
rmital |
Apr 7 2010, 06:38 AM
he mentioned the longs were replaced; the door gaps look good:
Attached image(s) |
rmital |
Apr 7 2010, 06:40 AM
he also mentioned the both buckets were replaced. They look fine, no other signs of major repair:
Attached image(s) |
rmital |
Apr 7 2010, 06:42 AM
the front bumper guard looks a little weathered, could just use a little TLC and the gas tank area is pictured:
Attached image(s) |
rmital |
Apr 7 2010, 06:44 AM
the nicest thing I could point out in the interior is the console, looks great and in working condition:
Attached image(s) |
rmital |
Apr 7 2010, 06:48 AM
...maybe one more nice thing...the taga seal is in good shape. But also in the picture is the dash. I've never seen one of these dash cover ups, but it's certainly a strange and cheap feeling fix. You can't tell from the pic, but it's flaping around (needs to be glued)...but looks good for a few feet away. And the vinyl forward of the pad is dry and weathered.
Attached image(s) |
rmital |
Apr 7 2010, 06:51 AM
the steering wheel felt like a dead snake....it also had some other issues. The "column" had verticle movement. Not just quarter of an inch, this thing was moving up and down!
Attached image(s) |
rmital |
Apr 7 2010, 06:52 AM
again...for the price, there was too many imperfections:
paint cracks Attached image(s) |
rmital |
Apr 7 2010, 06:53 AM
tears in the rubber:
Attached image(s) |
rmital |
Apr 7 2010, 06:54 AM
faulty seals:
Attached image(s) |
rmital |
Apr 7 2010, 06:58 AM
The engine bay's on these '76 amaze me....10 pounds of poop in a 5 pound bag. Really makes it tough to see what's going on.
Over the past 2 years checking out cars for buyers (PPIs), I've seen some nice engine bays and some that do not warrent a 10K price tag. passenger side hell hole. Seemed solid Attached image(s) |
rmital |
Apr 7 2010, 07:04 AM
I couldn't get to the driver's side hell hole cause of all the smog stuff in the way...but here's the best I could do. I'm pretty sure I believe him when he said all was repaired:
Attached image(s) |
rmital |
Apr 7 2010, 07:06 AM
not the worst engine bay I've seen, but too much rust on the plenum, engine shelf, etc. for the asking price.
Attached image(s) |
rmital |
Apr 7 2010, 07:23 AM
just some misc. stuff:
no sway bars steel wheels fog lamps and all other lights functional after market mirrors cracks in the bolster pad floor pans solid pedal cluster clean longs solid rocker panels have seen better days. many imperfections rear suspension mounting points good a-arm mounting points good front trunk floor good seat mounting point (couldn't move seats well enough) but all seemed well interior firewall solid targa top good body paint gets a 6 outa 10 lenses are 8 outa 10 seats are bad, 2 outa 10 seat belts need work or replacement locks are keyed different from ignition key sound system did not impress me tires are 5 outa 10 NO oil leaks (had him open the garage, nice and clean) new heat exchangers new injectors (his word) cold started fine transmission worked great idled fine drove or tracked fine steer wheel kind of funked up...not sure what was going on with that!! brakes nicely, did whistle a bit...pads...rotors...etc.... handbrake functional I was little impressed with the power...I'm usually more excited when driving any 914. I covered most, post any questions if you have them. |
Lo-Fi Version | Time is now: 3rd May 2024 - 03:51 AM |
