ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,445 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
#6 is an internally regulated Bosch alternator. Not sure what it fits, but it doesn't fit a 914.
#7 has a stock 914 coil on the left, middle is unknown, and the right is an early 911 cis fuel pump. |
jt914-6 |
Driving & working on teeners 41 years ![]() ![]() ![]() Group: Members Posts: 1,787 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States ![]() |
#4....trotline weight.....AKA smog pump.... (IMG:style_emoticons/default/aktion035.gif)
Gigamight |
Member ![]() ![]() Group: Members Posts: 220 Joined: 8-June 09 From: Near Akron, Ohio Member No.: 10,454 Region Association: Middle East ![]() |
pic 11)
code on this is GC 07017 Attached thumbnail(s) ![]() |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Typical aftermarket radio with a plate from a T1 VW. No value
Clutch cover (pressure plate) from something alien to this forum. Not VW, not Porsche. No value On the left, a VW T1 starter, on the right, a 911/914/VW automatic starter. Core value of about $10, each. VW T2 or 914 "smog pump", AKA air injection pump. '74 bus, '75-'76 914 2.0. Possible core value, but I doubt it. The filter housing may be worth something, but the pump is guaranteed to be junk. Coil, solenoid, fuel pump. All worthless Valve springs, well used. May go with those rabbit clutch bolts in the box. Any rust at all renders the springs useless. The cross bar is 70-72 914 Brake drum, backing plates, and hardware are VW T1. Scrap value. The alternator probably came from the same Rabbit as the 4 speed tranny. Values by weight at the scrap metal guy's yard. The Cap'n |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Pic 3 .... one on left is an SR15X, Type 1 Bug starter, won't work worth a shit on a type 4
One on right is a SR17X ... known as the VW Automatic starter ... correct for type 4s and 914s, some 911s. Pic 6 ... Alternator ... can't see the entire Bosch number to give you the applications Pic 5 ... Early 1.7, tailshifter engine mount bar Pic 4 ... 75/76 914 smog pump and 76 912E You won't get rich on any of it. Total value as cores, maybe $20 Ahhh ... John beat me to it. |
Gigamight |
pic 12)
one friggin picture won't load sigh..... oh well, it wasn't anything special anyways, just a curiosity VW part. pretty sure it's not a 914 part. Ok, now I can read what you all have said so far. |
ClayPerrine |
#11 is a VW Rabbit gearbox. Also known as a boat anchor.
SLITS |
forgot pic 7
Middle piece is the vibrating motor from a "Magic Fingers Motel bed" Coil you can toss Fuel pump could be CIS, but need to know number off base ... will be junk anyway. The hammer behind the radio in pic 1 is the most valuable piece you possess. |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,739 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
All that fit in your trunks?!?! (IMG:style_emoticons/default/blink.gif)
Gigamight |
Pic 3 .... one on left is an SR15X, Type 1 Bug starter, won't work worth a shit on a type 4 One on right is a SR17X ... known as the VW Automatic starter ... correct for type 4s and 914s, some 911s. Pic 6 ... Alternator ... can't see the entire Bosch number to give you the applications Pic 5 ... Early 1.7, tailshifter engine mount bar Pic 4 ... 75/76 914 smog pump and 76 912E You won't get rich on any of it. Total value as cores, maybe $20 Ahhh ... John beat me to it. Thanks for all the replies so far guys, just to set the record straight, I know none of this junk is highly valuable stuff, so I'm not asking so I can try and make a bunch of money. I am really just trying to learn, and if someone needs something here, by all means it's a cheap price (IMG:style_emoticons/default/wink.gif) I didn't buy the car for what was in the trunks by any means. (except for some trinkets I'm not showing pics of here (IMG:style_emoticons/default/santa_smiley.gif) |
ClayPerrine |
. (except for some trinkets I'm not showing pics of here (IMG:style_emoticons/default/santa_smiley.gif) This means he found a bunch of joints under the seats...... (IMG:style_emoticons/default/biggrin.gif) |
SLITS |
. (except for some trinkets I'm not showing pics of here (IMG:style_emoticons/default/santa_smiley.gif) This means he found a bunch of joints under the seats...... (IMG:style_emoticons/default/biggrin.gif) That would be "Roaches" Mr. Shorty ... SWEEEEEEEET!!!!!! |
Gigamight |
You .... would ... be ... AMAZED what they had stuffed in these trunks. I'm not even showing you the 200 lbs of assorted junk (a bicycle pedal, knives forks and spoons, children's toys, dirtbike parts, rusted out HE's, about 50 door knobs and hinges, etc etc etc.....) |
ClayPerrine |
. (except for some trinkets I'm not showing pics of here (IMG:style_emoticons/default/santa_smiley.gif) This means he found a bunch of joints under the seats...... (IMG:style_emoticons/default/biggrin.gif) That would be "Roaches" Mr. Shorty ... SWEEEEEEEET!!!!!! That would be all he found if he bought a car from you. |
SLITS |
. (except for some trinkets I'm not showing pics of here (IMG:style_emoticons/default/santa_smiley.gif) This means he found a bunch of joints under the seats...... (IMG:style_emoticons/default/biggrin.gif) That would be "Roaches" Mr. Shorty ... SWEEEEEEEET!!!!!! That would be all he found if he bought a car from you. (IMG:style_emoticons/default/smoke.gif) Ummmm Yaaaaassssssss! |
Gigamight |
wanna see the best thing I found after cleaning out the rear trunk? It was holding water, so I was hoping..... Just surface rust at the seams, pretty amazing for a car that has sat in Ohio for 30 yrs.
Gigamight |
. (except for some trinkets I'm not showing pics of here (IMG:style_emoticons/default/santa_smiley.gif) This means he found a bunch of joints under the seats...... (IMG:style_emoticons/default/biggrin.gif) That would be "Roaches" Mr. Shorty ... SWEEEEEEEET!!!!!! That would be all he found if he bought a car from you. (IMG:style_emoticons/default/smoke.gif) Ummmm Yaaaaassssssss! noooooo, the roaches were left in the ashtray, however I'm afraid those didn't come free with the car. |
SLITS |
. (except for some trinkets I'm not showing pics of here (IMG:style_emoticons/default/santa_smiley.gif) This means he found a bunch of joints under the seats...... (IMG:style_emoticons/default/biggrin.gif) That would be "Roaches" Mr. Shorty ... SWEEEEEEEET!!!!!! That would be all he found if he bought a car from you. (IMG:style_emoticons/default/smoke.gif) Ummmm Yaaaaassssssss! noooooo, the roaches were left in the ashtray, however I'm afraid those didn't come free with the car. That would have killed the deal for me. (IMG:style_emoticons/default/sad.gif) |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
Porsche used a ND Denso smog pump????
Oh, looked again, said Bosch but had the ND logo? |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,188 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
Lo-Fi Version | Time is now: 13th July 2025 - 08:39 PM |
