Okay Racers: tire questions, V710s on narrow bodied car |
BMXerror |
Apr 7 2010, 06:54 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
So here's the thing. I've been running Dunlop Direzza Z1 Star Specs. They're a fast street tire, but I'm getting killed by a couple R-compound guys. Last night I came across a hell of a deal on some V710s; two 205/50/15s, never used: $160! I jumped on it, and I'll grab the other two when the Dunlops wear out.
Here's the question, the 195/55 Dunlops measure in at about 7-1/2" width, and fender clearance is a little close running Rivieras. The 710s, however, measure in at just over 9 inches (not mounted). Has anyone run V710s of that size on a narrow bodied car (rolling fenders is acceptable) with 5.5" rims, or will I HAVE to go to say a 7" rim with a deeper offset? Will mounting the tires change that measurement at all? Experience appreciated. Remember, it's for the good of the 914's track reputation. My final question: Why is a race slick wider? Why does a 195 street tire measure in at 195mm, and a 205 race slick measure in at about 230mm? I've heard Hoosiers are wide too. Any explanations? Thanks. Mark D. |
sww914 |
Apr 7 2010, 06:59 PM
All of the 205/50/15's that I've tried have fit the front of my car. Hoosiers, Kumho 700's, 710's, old Yohohamas back in the day. My fender lips are smashed flat, I hammered them down before I painted it. The rear is flared, no info there to help you.
PeeGreen 914 |
Apr 7 2010, 07:01 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
A lot of 914s run 205s without the need of any modification. Some do require a slight fender roll. I don't know if the 205s will fit on a 5.5" rim as I have only seen them on 7s.
BMXerror |
Apr 7 2010, 07:09 PM
A lot of 914s run 205s without the need of any modification. Some do require a slight fender roll. I don't know if the 205s will fit on a 5.5" rim as I have only seen them on 7s. Yeah, well that's my real question. Kumho says it's okay to run them on a 5.5" rim. It's more a matter whether I can get them under the car on that rim. It's an offset thing. Thanks guys. Keep it coming. Mark D. P.S. Jon, do you still run with SCCA at all? |
qa1142 |
Apr 7 2010, 07:10 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
I run 205/50 15's on 4 lug oem fuchs and they fit fine
Faulkens (SP) |
ottox914 |
Apr 7 2010, 07:11 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
They will be pinched on the 5.5 rims. I ran 710's on factory 5.5 rims, then got some 7" keizer rims, correct offset, and the tires were night and day faster/better on the wider rims. You CAN fit a 7" rim on a stock fendered car, but you need to get the offset just right, and depending on the car, you may or may not need to roll/smash the rear fender lip/return. Fronts should be fine. I used a 5" offset/back space/whatever you want to call it, (5" from the inner mounting surface of the hub to the back of the wheel), and had a local machine shop make spacers of different thicknesses for each corner of the car, so I could rotate tires and fit the rims under the fenders. The tires will fit on the 5.5 rims, they'll just work better on the 7" rims.
Todd Enlund |
Apr 7 2010, 07:15 PM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
I can't say how they'll fit under the fenders, but a 5.5" wheel is not going to be optimal for those tires. I'd look for a second set of wheels for the V710s, and keep the Dunlops mounted for the street.
PeeGreen 914 |
Apr 7 2010, 08:47 PM
Yup, still running with SCCA and PCA. Even after my car sells I have a few rides available. (IMG:style_emoticons/default/smile.gif)
DanT |
Apr 7 2010, 09:00 PM
ran 205x50 Hankooks on stock 5.5 Fuchs...fit front and rear no problem...
also ran a custom set of 7" steelies with 205x50 710s and they also fit. I ran these both with 3/4" spacer up front and a 1/2" spacer in the rear... my fender lips were rolled and the fenders were lightly bumped... like this when I finish my '75 I will be running Dunny Direzza Star Specs on stock 4 bolt fuchs... Attached image(s) |
BMXerror |
Apr 7 2010, 09:47 PM
Yup, still running with SCCA and PCA. Even after my car sells I have a few rides available. (IMG:style_emoticons/default/smile.gif) Okay, thanks guys. I'll have to see what I can do about 7" rims minus the $ for a full 5 lug conversion. This has been a big help. What class you running in SCCA? Are you reasonably competitive? Are you the only 914 out there? I only ask because I'm the only 914 entry out of usually 200-250 entrants. Mark D. |
PeeGreen 914 |
Apr 7 2010, 10:40 PM
Yup, still running with SCCA and PCA. Even after my car sells I have a few rides available. (IMG:style_emoticons/default/smile.gif) Okay, thanks guys. I'll have to see what I can do about 7" rims minus the $ for a full 5 lug conversion. This has been a big help. What class you running in SCCA? Are you reasonably competitive? Are you the only 914 out there? I only ask because I'm the only 914 entry out of usually 200-250 entrants. Mark D. I am locally but not nationally. Last year I got 2nd, 1st, 3rd, 5th, and 3rd at the local events in FP. My car not being close to a real FP car anytime Leads was there or another FP car was there I was off. We have a few 914s that run but SCCA isn't the best place for our cars. There is a class that was opened up to the 914 that I am going to prepare a 914 for once I am out of debt. I think there are a few classes you could run your car in and do okay but it isn't easy. It is always fun though (IMG:style_emoticons/default/piratenanner.gif) |
BMXerror |
Apr 8 2010, 10:17 AM
I am locally but not nationally. Last year I got 2nd, 1st, 3rd, 5th, and 3rd at the local events in FP. My car not being close to a real FP car anytime Leads was there or another FP car was there I was off. We have a few 914s that run but SCCA isn't the best place for our cars. There is a class that was opened up to the 914 that I am going to prepare a 914 for once I am out of debt. I think there are a few classes you could run your car in and do okay but it isn't easy. It is always fun though (IMG:style_emoticons/default/piratenanner.gif) Yeah. SCCA just isn't easy, period! That's why I'm there; best place to learn. (IMG:style_emoticons/default/biggrin.gif) I'm running in DP (4 banger) with a regional class of all the prepared and modified cars lumped together and indexed due to low participation. My car, like yours, is nowhere close to full DP prep, but I don't doubt that it could be Nationally competitive if fully prepared. Even as she sits now, she surprises some people! (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/bootyshake.gif) (IMG:style_emoticons/default/biggrin.gif) Keep it up, Jon. Keep representing! Mark D. |
PeeGreen 914 |
Apr 8 2010, 11:26 AM
I will (IMG:style_emoticons/default/aktion035.gif) Autocross is my crack (IMG:style_emoticons/default/blink.gif) but my wife is okay with that (IMG:style_emoticons/default/wub.gif) .
I think DP may be the class I plan on building a 914 to go to nationals with. I'm not too sure as I haven't looked into it a ton. Need to do a LOT of stuff first. Besides, Greg Fordahl and Tim Kornacki are the guys that will be guiding me on this. I don't really NEED to know. I just have to listen (sometimes hard to do (IMG:style_emoticons/default/lol-2.gif) ) |
yeahmag |
Apr 8 2010, 01:06 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
They will be pinched on the 5.5 rims. I ran 710's on factory 5.5 rims, then got some 7" keizer rims, correct offset, and the tires were night and day faster/better on the wider rims. You CAN fit a 7" rim on a stock fendered car, but you need to get the offset just right, and depending on the car, you may or may not need to roll/smash the rear fender lip/return. Fronts should be fine. I used a 5" offset/back space/whatever you want to call it, (5" from the inner mounting surface of the hub to the back of the wheel), and had a local machine shop make spacers of different thicknesses for each corner of the car, so I could rotate tires and fit the rims under the fenders. The tires will fit on the 5.5 rims, they'll just work better on the 7" rims. What did those rims run each if you can recall? |
Joe Ricard |
Apr 8 2010, 02:07 PM
a rear rim can fit with up to 5 3/4" back space. like mentioned above 7" rim will fit if centered up right.
Stock 2.0L Fuchs is 4 1/2" Or you could just step off the slippery slope and buy my 15 x 10 Bogarts. |
yeahmag |
Apr 8 2010, 02:10 PM
Lo-Fi Version | Time is now: 15th May 2024 - 01:55 PM |
