Toad Twice in 8 Days, TG for AAA |
76-914 |
Apr 7 2010, 09:54 PM
So Sunday a week ago the thing died in Von's parking lot. No problem. (IMG:style_emoticons/default/headbang.gif) I Called AAA and 21 min's later they show up. Fuel pump took a crap and luckily I have a pressure gage in the old clock hole so it was an easy diagnosis. But it started right up that nite after cooling a bit. Installed a new pump Friday. Today, I pull pull into CVS after a 150mi round trip, pick up a prescription, go to start and nutin. The pump ran and everything lit up inside but I never heard the solonoid click either. So, AAA to the rescue again. Man those guys are fast. So guess what? After sitting for 2 hours it cranks right up. (IMG:style_emoticons/default/screwy.gif) I'm thinking it's old (like me) and just needs to stop and rest once in awhile. Or a Gremlin. (IMG:style_emoticons/default/happy11.gif) I'm hoping it's the solonoid. I have a spare starter/solonoid assm that I'll use in place of it, (IMG:style_emoticons/default/confused24.gif) Thoughts?????
underthetire |
Apr 7 2010, 09:57 PM
I hate getting frogged.
brant |
Apr 7 2010, 10:15 PM
Ribbit
Rand |
Apr 7 2010, 10:20 PM
Better toad than toed. Unless you are a chicken.
Rand |
Apr 7 2010, 10:25 PM
No solenoid click randomly... Cracked ignition switch. Maybe corroded connections at the battery terminals, the seatbelt relay crap under the passenger seat, or the ground strap between trunk floor and tranny.
realred914 |
Apr 7 2010, 10:41 PM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
gremlins??? I knew some one that had one, was a Levis edition, factory blue jean seats door panels and dash, with a Levis tag decal on the body. cool car
AAA may have a good tow service contract , but there insurance just plain sucks they dont pay out, they hate to pay out they are one of the worst pay out insurance companys around , get hit by an AAA insured driver and you better get a attorney, they fight for the last penny and are unethical as can be, |
Silverstreak |
Apr 7 2010, 10:53 PM
Edmund J. Fournier #36 Group: Members Posts: 117 Joined: 2-April 10 From: Pensacola Member No.: 11,552 Region Association: South East States |
gremlins??? I knew some one that had one, was a Levis edition, factory blue jean seats door panels and dash, with a Levis tag decal on the body. cool car AAA may have a good tow service contract , but there insurance just plain sucks they dont pay out, they hate to pay out they are one of the worst pay out insurance companys around , get hit by an AAA insured driver and you better get a attorney, they fight for the last penny and are unethical as can be, They sure as hell don't like to pay out to there service contractors either. I used to be a AAA contractor and most local tows(5 miles) only paid less than $20, of which most drivers only get 35% of at the most. So TIP YOUR TOWMAN! (If he does a good job, is careful and polite. And if you're not paying cash out of pocket). |
76-914 |
Apr 8 2010, 09:50 AM
No solenoid click randomly... Cracked ignition switch. Maybe corroded connections at the battery terminals, the seatbelt relay crap under the passenger seat, or the ground strap between trunk floor and tranny. Damn, I forgot about the seat belt circuit. Good thought! |
TROJANMAN |
Apr 8 2010, 09:53 AM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
This happened to one of my cars recently.
Mine would still push start, but no click when you turned the key. And it was completely random when it happened. Troubleshot EVERYTHING and it ended up being a bad ignition switch. Always check the easy stuff first. Oh, and wear gloves so that you don't get warts from the Toad |
76-914 |
Apr 8 2010, 10:10 AM
This happened to one of my cars recently. Mine would still push start, but no click when you turned the key. And it was completely random when it happened. Troubleshot EVERYTHING and it ended up being a bad ignition switch. Always check the easy stuff first. Oh, and wear gloves so that you don't get warts from the Toad I've read about switch problems so many times here that I am a bit suspect of the switch. I tried the switch at least 15 times before settling on the wrecker wescue. Is it possible for the ign switch to respond after setting for a few hours ie cool down a bit. Do the contacts wear to a point that resistance causes heat build up in the switch thus preventing contact? BTW what is the test procedure for the ign switch? |
Kirmizi |
Apr 8 2010, 12:34 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Yes, mine was doing the same thing.
At first I thought it was the "hot start" problem with the solenoid or starter, but after replacing both it continued to happen. The wiring and connections were good and after replacing the switch (with a new OEM) it hasn't happened since. Mike |
Phoenix-MN |
Apr 8 2010, 01:00 PM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
scotty b |
Apr 8 2010, 04:47 PM
Mark Henry |
Apr 8 2010, 05:17 PM
SLITS |
Apr 8 2010, 05:34 PM
Butt .... wipe .... er |
Rand |
Apr 8 2010, 05:38 PM
Cap'n Krusty |
Apr 8 2010, 06:44 PM
Butt .... wipe .... er Bear ........... whiz ........... beer The Cap'n |
zymurgist |
Apr 9 2010, 05:40 AM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Lo-Fi Version | Time is now: 17th May 2024 - 08:35 AM |
