993 6-speed transmission? |
Apr 9 2010, 03:50 PM
Resident German Group: Admin Posts: 41,638 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Can the R&P be flipped in a 993 transmission? I know they came in 5 and 6 speed manual.
From the looks of it, it should fit in a 914. The output flanges are a bit too far forward, but a slight angle on the axles shouldn't be a problem. (IMG:style_emoticons/default/idea.gif) Andy Attached image(s) |
pcar916 |
Apr 9 2010, 04:04 PM
I don't remember from rebuilding one 10 years ago if the case will do that, but G50's run upside down just fine. That's a lot easier than R&P flippin' since it's likely gonna be a cable shifter anyway eh?
Patrick motorsports (maybe others as well) has the short bell-housing version but I don't know if it's been fitted up to a 914. Surely someone's done it! Wonderful transmission. If it wasn't SO heavy. Could be a good thread here! Who's doing it or finished one??? |
Apr 9 2010, 04:10 PM
I don't remember from rebuilding one 10 years ago if the case will do that, but G50's run upside down just fine. That's a lot easier than R&P flippin' since it's likely gonna be a cable shifter anyway eh? Patrick motorsports (maybe others as well) has the short bell-housing version but I don't know if it's been fitted up to a 914. Surely someone's done it! Wonderful transmission. If it wasn't SO heavy. Could be a good thread here! Who's doing it or finished one??? It looks like running it upside down would require cutting the trunk. I'd rather not do that. (IMG:style_emoticons/default/popcorn[1].gif) Andy |
Porcharu |
Apr 9 2010, 04:12 PM
Senior Member Group: Members Posts: 1,314 Joined: 27-January 05 From: Campbell, CA Member No.: 3,518 Region Association: Northern California |
Might be easier to go with the 6 speed Subi. Not like your car is stock.
Steve |
Apr 9 2010, 04:14 PM
Might be easier to go with the 6 speed Subi. Not like your car is stock. Easier than mating a 993 transmission to a 993 motor using a 993 flywheel and 993 clutch? (IMG:style_emoticons/default/biggrin.gif) Andy |
pcar916 |
Apr 9 2010, 04:21 PM
Might be easier to go with the 6 speed Subi. Not like your car is stock. Easier than mating a 993 transmission to a 993 motor using a 993 flywheel and 993 clutch? (IMG:style_emoticons/default/biggrin.gif) Andy Yeah, I still have my 993 flywheel and clutch pack (55lbs) and exhaust system, and power steering pump, and... Stuff's just been sittin' there for years taunting me. No transmission though... nuts! |
Apr 9 2010, 04:34 PM
Yeah, I still have my 993 flywheel and clutch pack (55lbs) and exhaust system, and power steering pump, and... Stuff's just been sittin' there for years taunting me. I have a lightened flywheel and performance clutch package that came with my motor. Much lighter than the stock setup. It's been collecting dust at McMark's shop. (IMG:style_emoticons/default/shades.gif) Andy |
McMark |
Apr 9 2010, 04:37 PM
Boxster....
Steve |
Apr 9 2010, 06:32 PM
914 Guru Group: Members Posts: 5,585 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I have seen it done in PMS cars before. He flipped the trans upside and cut up the trunk. You mostly find them in tube frame cars.
RJMII |
Apr 9 2010, 07:04 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
Elliot Cannon |
Apr 9 2010, 08:37 PM
Flipping this trans also raises the CG correct? Heavier and higher?
Apr 9 2010, 08:41 PM
Ask for a junk one at Easy...the take it apart and see...
I would suggest that you go for the new tranny that shifts in 1/1ooth of a second... Rich |
brilliantrot |
Apr 9 2010, 10:39 PM
Member Group: Members Posts: 125 Joined: 27-April 07 From: Costa Mesa Ca. Member No.: 7,699 |
A US 993 6 speed is called a g50/20. The diff can not be flipped on them so you have to run them upside down.
The are EXPENSIVE in relative terms to 901 and have terrible gearing stock. Figure ~$5k for a decent one and most don't have LSD. Gear sets are $1k each and only the early 1995 boxes came with a removable 2nd gear so add ~$2k for the equivalent of a 904 main shaft for a g50/20. Did I mention they are ungodly heavy too? The upsides of all this though are they do shift really well and hold a lot of power. If I were going to use one in a mid engined application, I would go with a 996/997 GT3 box as they are cable shift (much easier to route for a mid-engined application), have a decent LSD, are stronger, and have much better ratios. Another option is to buy a g50/31. This is the gear box out of a 993RS and it has better parts and better gearing. Last I heard they were ~$13k from Sunset which is much cheaper than one could build one like it. |
McMark |
Apr 10 2010, 08:09 PM
QUOTE Do either of them look like they will bolt onto Andy's 993 engine? Yes, but I have 'Modification Goggles'. (IMG:style_emoticons/default/cool.gif) Where there's a will there's a way. |
Andyrew |
Apr 10 2010, 08:11 PM
Boxster.... This one is the Boxster S 6 speed This one is Boxster 5 Speed Do either of them look like they will bolt onto Andy's 993 engine? Looks like it'll bolt to my Audi 1.8T engine. Oh wait, thats because it will! (IMG:style_emoticons/default/biggrin.gif) |
sww914 |
Apr 10 2010, 08:46 PM
So will an Audi 1.8t engine bolt to a 993 engine? (IMG:style_emoticons/default/smile.gif)
RJMII |
Apr 10 2010, 09:06 PM
Looks like it'll bolt to my Audi 1.8T engine. Oh wait, thats because it will! (IMG:style_emoticons/default/biggrin.gif) Which one you looking at? |
RJMII |
Apr 10 2010, 09:09 PM
QUOTE Do either of them look like they will bolt onto Andy's 993 engine? Yes, but I have 'Modification Goggles'. (IMG:style_emoticons/default/cool.gif) Where there's a will there's a way. I like your goggles. =o) If you get one and start modifying it; I have a few questions. Could you PM me if that happens so I don't hijack one of Andy's threads? Or if you have one and don't mind answering a couple of measurement questions... |
Andyrew |
Apr 10 2010, 10:30 PM
Looks like it'll bolt to my Audi 1.8T engine. Oh wait, thats because it will! (IMG:style_emoticons/default/biggrin.gif) Which one you looking at? The B5 Audi FWD transaxle's are the same bolt pattern to the boxster trani's, Not sure which one, but thats what Felix is running on his NEO car.. |
Mike Bellis |
Apr 11 2010, 03:27 PM
Just put new cams in the 3.6 and make it spin backwards (IMG:style_emoticons/default/poke.gif)
Lo-Fi Version | Time is now: 16th May 2024 - 12:59 AM |
