Screw Size? Engine Tins, What size are the engine tin screws |
LotusJoe |
Apr 9 2010, 04:50 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
I am missing a bunch of engine tin screws. What size are these screws? Looks like a M6???? (IMG:style_emoticons/default/dry.gif)
Eric_Shea |
Apr 9 2010, 04:51 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
M6
LotusJoe |
Apr 9 2010, 04:52 PM
Eric_Shea |
Apr 9 2010, 04:54 PM
Invaluable resource for these kind of things:
http://www.porsche.com/latin-america-en/ac...partscatalogue/ That and... www.mcmaster.com ...and you're in fastener heaven. |
LotusJoe |
Apr 9 2010, 05:03 PM
Invaluable resource for these kind of things: http://www.porsche.com/latin-america-en/ac...partscatalogue/ That and... www.mcmaster.com ...and you're in fastener heaven. Thanks!! Saves me a ton of time |
Apr 9 2010, 10:20 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
There's one on the right over-cylinder tin, under the plenum, that is larger. I forget if it's M7 or M8.
--DD |
type47 |
Apr 10 2010, 05:40 AM
Socket head bolts are nice to use in those hard to get to places. Black oxide ones are cheap at Home Depot, Lowe's, or local hardware store.
thomasotten |
Apr 10 2010, 05:29 PM
Senior Member Group: Members Posts: 1,544 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
check the online VW places. They have them, and they have a stainless steel finish.
McMark |
Apr 10 2010, 07:58 PM
Dave, good catch! That's only on later cases, but you're right.
veltror |
Apr 11 2010, 10:19 AM
Senior Member Group: Members Posts: 928 Joined: 27-April 08 From: Potters Bar Herts UK Member No.: 8,978 Region Association: None |
There is no way I am going to use screws again, it was a bastard to get some of my screws off and the ones which I replaced with ocket heads I used cheap ones which rusted and rounded off, an even bigger bastard to do, I suggest stainless socket heads or you could go for these
http://www.volksbolts.com/eng.htm roman |
charliew |
Apr 11 2010, 10:51 AM
m6x10. I got a set of ss socket button head for a super beetle 1600 from someone on samba but I am going to try to find the source as I need lots of them for my projects.
Apr 11 2010, 11:01 AM
Apr 11 2010, 11:36 AM
Curious, the catalog doesn't mention any larger screws.... It also lists several different lengths:
M6x10: 8 + 4 + 2 = 14 M6x12: 5 + 3 + 4 + 4 + 2 = 18 M6x15: 2 + 4 + 2 = 8 ...Plus the two M5 screws for the cylinder-bottom tin, and 7 more M6x12 for the front tin--and one M6x12 bolt (yes, the Cap'n is right once again!) for the front-most holes on the front tin. Very interesting!! --DD |
stateofidleness |
Apr 11 2010, 11:50 AM
Senior Member Group: Members Posts: 810 Joined: 1-September 07 From: Canyon Lake, Texas! Member No.: 8,065 Region Association: None |
Curious, the catalog doesn't mention any larger screws.... It also lists several different lengths: M6x10: 8 + 4 + 2 = 14 M6x12: 5 + 3 + 4 + 4 + 2 = 18 M6x15: 2 + 4 + 2 = 8 ...Plus the two M5 screws for the cylinder-bottom tin, and 7 more M6x12 for the front tin--and one M6x12 bolt (yes, the Cap'n is right once again!) for the front-most holes on the front tin. Very interesting!! --DD Hey Dave, I was actually about to head to local hardware store to get all the engine tin screws and was perusing the site for a compiled list of all sizes/lengths I would need. Can you confirm this: M6x10: 14 M6x12: 18 + ftront (12) M6x15: 8 M5x?: 2 M6x12 (bolt?): what's the difference? |
charliew |
Apr 11 2010, 03:10 PM
Stainless steel socket head m6x10 12mm long, pck of 50 $11.00 + shipping
http://www.fastenal.com/web/products/detai...0000&ucst=t I ordered these and they are allen head ss screws and not button head screws like I thought. |
stateofidleness |
Apr 11 2010, 03:31 PM
can those be used throughout the whole engine tin or are different sizes necessary?
I'm really dreading this part as I don't remember where screws came from |
Apr 11 2010, 07:58 PM
I cannot confirm anything other than that's what the catalog says. I think I used M6x10 Allen screws for all of them on mine, except for the larger one where I re-used the funky fastener that the PO installed.
BTW, the bolt is just a regular hex head bolt, not a slot-head screw. Nothing special about it, just that it isn't a screw. That's because it's difficult to get a screwdriver onto the screw-head on the forward-facing fastener. (The one holding the two pieces of front engine tin together.) --DD |
Mikey914 |
Apr 11 2010, 10:27 PM
The rubber man Group: Members Posts: 12,657 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I have the 10mm allen head scres in stainless with stainless washers for $18 if you need them. I would definately stay away from the black oxide as they WILL rust. Cheaper, but not really what you want.
Last line on the list. http://www.914world.com/bbs2/index.php?act...=0#entry1113642 |
stateofidleness |
Apr 11 2010, 10:38 PM
If i need all 4 sides that seal the engine tin to the engine bay, which "set" would I be looking for?
can you price me a set of the screws and a set of the seals? |
Mikey914 |
Apr 12 2010, 12:23 AM
If i need all 4 sides that seal the engine tin to the engine bay, which "set" would I be looking for? can you price me a set of the screws and a set of the seals? You are correct that is all 4 seals. The long front ans 2 sides of the "J" seal and the "Y" seal for the back. $76 for the set, Screws for $18. Shipping $6 I'll PM you with the payment info. |
Lo-Fi Version | Time is now: 8th May 2024 - 10:56 AM |
