Vertical Roll Bar to Targa Rubber top Plug?, Anyone have a source for the Plug |
bandjoey |
Apr 9 2010, 10:45 PM
bandjoey Group: Members Posts: 4,925 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
I'm going to get a set of vertical window seals from Mikey but he only sells the rubber seal and I have to find my own top plugs for the seals. The tops on my car are beat up and worthless. His are $26 vs $125. I can make a plug from RTV for that much difference, but I'd like to find a pair in good condition if not new.
Anyone have a source of that top plug? Thanks |
Mikey914 |
Apr 10 2010, 12:48 AM
The rubber man Group: Members Posts: 12,659 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The can be cut from the old seals, but I do have these in the works, 4-6 weeks out. You can cut the extrusions and seal with silicone. But I will have this addressed very soon.
Tahnks, Mark |
dr914@autoatlanta.com |
Apr 10 2010, 08:03 AM
914 Guru Group: Members Posts: 7,840 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I'm going to get a set of vertical window seals from Mikey but he only sells the rubber seal and I have to find my own top plugs for the seals. The tops on my car are beat up and worthless. His are $26 vs $125. I can make a plug from RTV for that much difference, but I'd like to find a pair in good condition if not new. Anyone have a source of that top plug? Thanks We have the one piece seals repro for 38.50 each which have the top extrusion but of course are more expensive than mikeys. |
bandjoey |
Apr 10 2010, 09:49 AM
Will the plug be a separate piece to glue on or molded on? I.e. Do I get the existing seal now and wait for the plug or wait for thecomplete seal?
Thanks Mark |
Mikey914 |
Apr 10 2010, 11:11 PM
My plug will be long enough that you could retrofit the extrusions that have already been purchased. Even those that have been cut and plugged. The idea is that I needed to have made these and that way you'll be able to have the correct fit. These will be able to be glued on and have a small "plug" that will extend into the extrusion to orientate it correctly
These will be about $11 a set. I just need to finish a few other projects I have started to tool up on these. -Mark |
Lo-Fi Version | Time is now: 9th May 2024 - 12:12 AM |
