will 80 PSI VDO gauge work with 150psi sender, hard to read this 150 psi gauge =/ |
qa1142 |
Apr 10 2010, 01:52 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
so got a 150 PSI gauge (picture at Jegs showed 80 psi dial) (IMG:style_emoticons/default/chair.gif)
hard to read Will 150 PSI dual sender work right with VDO 310012 80 PSI gauge? |
qa1142 |
Apr 10 2010, 01:53 PM
Oh, and which calibrated VDO temp gauge would replace the uncalibrated consoule (SP) gauge?
150-300F 120-300F ???? |
marks914 |
Apr 10 2010, 01:56 PM
Senior Member Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
No,
You need the right sender for the right gauge, you cannot mix and match them or brands. Mark |
qa1142 |
Apr 10 2010, 02:29 PM
same brand both VDO
Cap'n Krusty |
Apr 10 2010, 03:24 PM
You can't mix and match senders and gauges. Or brands. There, clearer now?
The Cap'n |
Mike Bellis |
Apr 10 2010, 05:10 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
You can't mix and match senders and gauges. Or brands. There, clearer now? The Cap'n (IMG:style_emoticons/default/agree.gif) Although it may read somthing, the callibration would be way off and you would not know the actual pressure. |
zx-niner |
Apr 10 2010, 06:46 PM
Member Group: Members Posts: 294 Joined: 13-June 05 From: Las Vegas, NV Member No.: 4,269 Region Association: Central California |
If you used a 150 psig sender with an 80 pound gauge, your gauge readings would be just over half the true value of your pressure.
McMark |
Apr 10 2010, 07:52 PM
I'm not clear on what you have, exactly. (IMG:style_emoticons/default/blink.gif)
Your gauge is ______ psi. Your sender is _____ psi. I was just researching this for SirAndy. Both senders have a range of 0-180 ohm. If you have a 5 bar sender and a 10 bar gauge, the gauge will read fine, but you'll have to mentally 1/2 the numbers you see on the gauge. If you have a 10 bar sender and a 5 bar guage, again, the gauge will read fine, but you'll have to mentally double the numbers you see on the gauge. If you have a dual contact (pressure and warning light) 10 bar sender that you don't want, PM SirAndy because he's going to be buying on and you might be able to work something out. |
qa1142 |
Apr 10 2010, 08:29 PM
I have 150 psi dual sender and 150 psi gauge but never get past 60 psi.
all very very new like 300 miles Now wish I had 80 PSI gauge so I had more sweep and could read lower oil pressures with accuracy If that means new sender and new gauge so be it. Just trying to understand what I need to do |
914Sixer |
Apr 11 2010, 06:38 AM
914 Guru Group: Members Posts: 8,885 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
From what your last post says your gauge is reading correctly. Your oil pressure should never exceed 60 psi. Yes, the lower scale will be easier to read but the accuracy should be the same with a matched sending unit.
McMark |
Apr 11 2010, 11:28 AM
I would sell what you've got in the classifieds, and get the right stuff. If it were me.
Lo-Fi Version | Time is now: 19th May 2024 - 11:09 PM |
