914 front fascia aero mods |
Backdraft |
Apr 11 2010, 01:37 AM
Newbie Group: Members Posts: 6 Joined: 2-April 10 Member No.: 11,550 Region Association: None |
Hi all,
I'm a new member, so go easy if you will. Anyways, I'm currently a university student working on a class project for a professor/teacher, which just so happens to entail his modded 914 (see more here). In a nut shell, he has already bought a front-mounted oil cooler for the 914, but does not know the optimal shape/size of the holes in the front bumper/valance area and the front floor in order to provide the right amount of airflow to the cooler, yet still preserve as much aerodynamics and lowered drag. He has tasked us to figure this out (using Solidworks/Flow Simuation, and a real-life water channel experiment using a 914 scale model), and suggested this forum for advice. Anyways, has anyone done/looked into anything similar for their car, especially modifying the front fascia area to increase/promote better airflow into an radiator/cooler, and what kinds of results/consequences you noticed? It doesn't even have to scientific at all, I was just fishing for different ideas of how some drivers may have modified their cars especially to promote aerodynamics and/or better airflow in the frontal area. This is mainly an autoX car, so huge ass fins or wings won't be that important. I'm more looking for slits or opening modifications to the bumper/fascia. Thanks all for your help. |
sixnotfour |
Apr 11 2010, 10:57 AM
914 Wizard Group: Members Posts: 10,422 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
not sure if this what your looking for , 20yrs ago.
Attached thumbnail(s) |
ArtechnikA |
Apr 11 2010, 11:16 AM
In a nut shell, he has already bought a front-mounted oil cooler... In is easy. You can get no more air in than you can get out. Figure how you're gonna exhaust the heated air. For a variety of reasons, conventional wisdom dictates the exhaust must be bigger than the intake. The Earls Supply website (hint: they are a Holley company) has a lot of good information on airflow requirements. For extra credit, reference Carroll A cynic would observe that a front-mounted oil cooler is silly on an AX car since oil probably can't heat up enough in 60 seconds to need one, and if it does - the car's not moving any more at the end of the run. Informing one's instructor that he's wasted a buncha money on needless parts may not be the fast-track to a good grade, even if it is the correct engineering answer... (BTW -- (IMG:style_emoticons/default/welcome.png) ) (Thank you for the correction Terry) |
stewteral |
Apr 11 2010, 12:32 PM
Old Member Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
Hi all, I'm a new member, so go easy if you will. Anyways, I'm currently a university student working on a class project for a professor/teacher, which just so happens to entail his modded 914 (see more here). In a nut shell, he has already bought a front-mounted oil cooler for the 914, but does not know the optimal shape/size of the holes in the front bumper/valance area and the front floor in order to provide the right amount of airflow to the cooler, yet still preserve as much aerodynamics and lowered drag. He has tasked us to figure this out (using Solidworks/Flow Simuation, and a real-life water channel experiment using a 914 scale model), and suggested this forum for advice. Anyways, has anyone done/looked into anything similar for their car, especially modifying the front fascia area to increase/promote better airflow into an radiator/cooler, and what kinds of results/consequences you noticed? It doesn't even have to scientific at all, I was just fishing for different ideas of how some drivers may have modified their cars especially to promote aerodynamics and/or better airflow in the frontal area. This is mainly an autoX car, so huge ass fins or wings won't be that important. I'm more looking for slits or opening modifications to the bumper/fascia. Thanks all for your help. Hi Backdraft, Thanks for joining and sharing your project info on the aerodynamics of the 914. I've done a lot of Autocrossing (some of it with my first STOCK 914) and agree with Artechnika about NOT mounting the front oil cooler. I viewed the video of the tufted car and it sounds as though it is DEAD stock, with no need for additional oil cooling other than the one already on the engine. Thus, it seems the best aero answer is keeping the nose of the car smooth and free from openings to promote laminar airflow. However, if this is an assigned project for the experience of doing the analysis, carry on! (IMG:style_emoticons/default/smile.gif) With respect, a correction: the author of the Engineer, Drive, Tune, Prepare and Screw TO WIN books is the late Carroll Smith: An engineer first and great race engineer to-boot. I keep all of them as a reference library and recommend them highly. Now I have request for some of your help: I have a V8 conversion car and am VERY interested in the airflow from the rear window to the back of the car. While the car was designed around air flowing INTO the engine cover, I am flowing air from under the car and OUT the top. I'm very interesting in: -Can you share any more Solid Works output, photos of tufting or the like showing in greater detail the airflow over the rear trunk area and engine cover? -Your analysis work is at very low speed as in autocrossing, will airflow characteristics change at 100 MPH? If so how? -Do you have anything that would indicate the airflow for my application? -What could I do to AID the up-and-out airflow? -Am I bucking the cars design my trying to vent to a higher than desirable pressure area? Thanks for any feedback, Terry |
ArtechnikA |
Apr 11 2010, 12:38 PM
With respect, a correction: the author of the Engineer, Drive, Tune, Prepare and Screw TO WIN books is the late Carroll Smith You are absolutely correct. Brain fade on my part. That's what I get for trying to remember stuff while taking a break from mowing the lawn... Great books all and yes, I've got 'em - even the little pocket reference... |
ArtechnikA |
Apr 11 2010, 12:49 PM
-What could I do to AID the up-and-out airflow? -Am I bucking the cars design my trying to vent to a higher than desirable pressure area? If you have air deflectors on the underbody (I don't know when they started that) remove them. If you can add a wickerbill to the trailing edge of the top and outboard edge of the sail panels, they'll help reduce the pressure at the screen. I don't think the engine lid area wants to be a high-pressure area, which is why the underbody flaps were introduced - to help extract air out the bottom and increase the pressure differential. It's a sorta-effective intake for the air-cooled cars because we have (relatively) huge fans spinning at high speeds sucking air in. The /4's squirrel-cage fan runs at crank speed, but that /6's axial fan runs about 1,8x crank speed... I thought I saw a Subie conversion actually implement underbody scoops. I thought that was a bad idea but for an AX/track car you might get away with it. I think it'd suck up too much water, trash, and grit to make it a good everyday-driver method. I did some airflow testing with yarn and dirty oil, but it didn't tell me anything that wasn't already known. |
stewteral |
Apr 12 2010, 12:34 PM
-What could I do to AID the up-and-out airflow? -Am I bucking the cars design my trying to vent to a higher than desirable pressure area? If you have air deflectors on the underbody (I don't know when they started that) remove them. If you can add a wickerbill to the trailing edge of the top and outboard edge of the sail panels, they'll help reduce the pressure at the screen. I don't think the engine lid area wants to be a high-pressure area, which is why the underbody flaps were introduced - to help extract air out the bottom and increase the pressure differential. It's a sorta-effective intake for the air-cooled cars because we have (relatively) huge fans spinning at high speeds sucking air in. The /4's squirrel-cage fan runs at crank speed, but that /6's axial fan runs about 1,8x crank speed... I thought I saw a Subie conversion actually implement underbody scoops. I thought that was a bad idea but for an AX/track car you might get away with it. I think it'd suck up too much water, trash, and grit to make it a good everyday-driver method. I did some airflow testing with yarn and dirty oil, but it didn't tell me anything that wasn't already known. Hey ArtechnikA, Yup, we're on the same page: I removed the underbody flap long ago. To deflect air upward, I my own air dam back in the middle of the engine bay that extends down 4". When I drive the car, I come back with dust and weeds all over the engine and a heavy dust layer on the rear trunk lid. So things appear to working as I want them too...but I could look at adding the scoops you mentioned. I also made my own fiber glass side scoops to pull in more air to the engine bay. However, when I tufted the car, I was surprised to see that once the air flow gets around the sides of the roof, back about mid trunk lid, air starts flowing FORWARD to the engine bay. If you take a look at the professors web site, there are a number of computer created drwgs, along with a video of the prof's tufted car showing the same air flow patterns. Additionally, I was expecting a BIG vortex coming off the roof of the car creating what I hoped was a BIG low pressure area. NO JOY: my tufts told me the vortex was only about 5" in diameter and the air smoothed out only 18" back from the roof. So I don't know how big nor how much drop in pressure exists in the volume above the engine cover. Even a 2"roof spoiler did little to increase the vortex. So I'm left with less real world data than I would like and that's why I asked the engineering student for some more info on that area of the car. What a great way to do a college project: you MUST work on the aerodynamics of a 914!! Ya' Gotta' Love It! I hope he is..... Terry |
Backdraft |
Apr 13 2010, 04:02 PM
Lol thanks Terry, but then you realize you are being graded on this (IMG:style_emoticons/default/KMA.gif). Also CFD theory is quite difficult to grasp.
Anyways, thanks for your replies. Just to clear a few things up: The reason he's putting an oil cooler in it is because his engine is modded (even though it might not seem apparent from his site) up to almost 120 hp according to the dyno graph, and he's running temps of up to 250 F after a hard run at an autoX. Also, I didn't mention this but the autoX he runs it at is Qualcomm Stadium in San Diego (I'm studying Mechanical Engineering @ UCSD), so, combined with the hotter weather, as well as a tighter and harder-running track (60+ secs for a lap is normal for this track, unlike the 30-40 you usually see), it doesn't come as a surprise that the engine is running that hot. In the future, he is also planning to drop a 6 in there too. As far as the airflow characteristics towards/over the rear of your car, as you may have noticed the projects already displayed on his website were done by previous years' students, so unforunately I do not know the complete results/conclusions they deducted from their experiments, except what is already seen in the poster PDFs. I'll try to look at their research papers when I obtain them. Anyways, for our project, we are only looking at how modifications to the front fascia/underside will affect our airflow through the front trunk, because that will be where the oil cooler will be mounted. That is why I was asking if you or you knew any examples of 914 projects where the front valance/bumper area was modified to increase airflow to the trunk bay, so we could model it in CAD and do airflow simulation for these different configurations and intake/exhaust sizes. IE. Something like this, which is obviously not stock bumper: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.patrickmotorsports.com-11550-1271196140.1.gif) |
PeeGreen 914 |
Apr 13 2010, 04:23 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Wow, that's wild. I like it (IMG:style_emoticons/default/aktion035.gif)
URY914 |
Apr 13 2010, 06:21 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,389 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Isn't that the standard AIR kit?
ArtechnikA |
Apr 13 2010, 06:24 PM
The reason he's putting an oil cooler in it is because his engine is modded (even though it might not seem apparent from his site) up to almost 120 hp according to the dyno graph, and he's running temps of up to 250 F after a hard run at an autoX. Also, I didn't mention this but the autoX he runs it at is Qualcomm Stadium in San Diego Sorry, I ain't buyin' it. Find out how many mouse nests he's got over his stock cooler. Or why else it's not working. 120HP ~= 10% over stock. I've driven the AX courses there. Before it was Qualcomm. Before it was Jack Murphy even. I know the area (lived there 20 years). I have driven 120HP+ cars there... I've also driven 75-second AX courses in 110ºF ambient in the high desert (Reno, Winnemucca, Hawthorne NV... If you're seeing 70ºF oil temp rise in 60 seconds, something is wrong... A front-mounted cooler won't do squat once you pull off the course. I expect you're plumbing a thermostat, so it might not even help you much when it's on the course... QUOTE In the future, he is also planning to drop a 6 in there too. OK, but you're looking at AN-12 plumbing for that (AN-16 better...) so either what you have is WAY too big now or you're back to Square One should that day come.You need look no further than the 914.6 GT cars. ~210HP. Little bitty opening into the front bumper/valence, exits through trunk floor. They didn't worry about airflow exiting under the car and they were driving on the Mulsanne Straight. With limited HP, drag is a factor. Air you can't evacuate is drag. Concentrate on the exit. For a dedicated track car, exhausting up through the trunk lid works well. This kind of bodywork mod is not permitted in most classes so Step Zero is always: Read The Rule Book. But it's efficient and can contribute to improved downforce. Not that it's a big factor in a stock-ish car. |
stewteral |
Apr 13 2010, 10:43 PM
Lol thanks Terry, but then you realize you are being graded on this (IMG:style_emoticons/default/KMA.gif). Also CFD theory is quite difficult to grasp. Anyways, thanks for your replies. Just to clear a few things up: The reason he's putting an oil cooler in it is because his engine is modded (even though it might not seem apparent from his site) up to almost 120 hp according to the dyno graph, and he's running temps of up to 250 F after a hard run at an autoX. Also, I didn't mention this but the autoX he runs it at is Qualcomm Stadium in San Diego (I'm studying Mechanical Engineering @ UCSD), so, combined with the hotter weather, as well as a tighter and harder-running track (60+ secs for a lap is normal for this track, unlike the 30-40 you usually see), it doesn't come as a surprise that the engine is running that hot. In the future, he is also planning to drop a 6 in there too. As far as the airflow characteristics towards/over the rear of your car, as you may have noticed the projects already displayed on his website were done by previous years' students, so unforunately I do not know the complete results/conclusions they deducted from their experiments, except what is already seen in the poster PDFs. I'll try to look at their research papers when I obtain them. Anyways, for our project, we are only looking at how modifications to the front fascia/underside will affect our airflow through the front trunk, because that will be where the oil cooler will be mounted. That is why I was asking if you or you knew any examples of 914 projects where the front valance/bumper area was modified to increase airflow to the trunk bay, so we could model it in CAD and do airflow simulation for these different configurations and intake/exhaust sizes. IE. Something like this, which is obviously not stock bumper: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.patrickmotorsports.com-11550-1271196140.1.gif) Hey Backdraft, Thanks for your reply, I saw what was on the Prof's site, but, of course, wanted MORE!! I understand in spite of what your Prof THINKS about the oil cooler, YOU MUST work with it! It's great preperation for working in the Real World after graduation: can you say BOSS? (IMG:style_emoticons/default/smile.gif)....Maybe the prof should take a course on Thermal Dynamics? I'm still envious of your study project as there is nothing like real world testing and finding results with a science (Black Art?) like aerodynamics. For GRINS, I attached a couple photos of the front of my car. With some 500 HP, I am NOT concerned with a low CD and look to pick up some down force. You'll note the flexible air dam below the splitter: that was intended to increase the low pressure area under the nose to aid the trunk-bottom exhaust from the radiator. However, I'm currently in the middle of change my cooling approach and have repositioned the radiator to exhaust out the top through the hood. I've removed the air dam and hope the increase airflow under the car will aid in engine cooling. Ya', I know, it's a water-cooled engine, but during building this project I learned that the Chev is still 30% cooled by air over the block. Enjoy your project and please update us on your findings! 914s have been around for 40 years, but I've never heard of anyone doing a study on the CD of the nose. Best, Terry Attached thumbnail(s) Attached image(s) |
Rand |
Body kit is cool, but we've seen it.
You reference 120hp. An efficient 120hp type 4 doesn't need external oil cooling and associated ducting. Sounds like your team is behind the curve. I applaud what you are doing, but be sure you explore what has already been done. How about a TIV with nearly 200 hp and tq with stock cooling? Research first so you don't reinvent a wheel, but rather build on it. Further and break ground!!!! Looking forward to what your team adds. And know you've got huge resources behind you here. |
Chris Pincetich |
Apr 14 2010, 09:03 AM
Add a front big, flat, horizontal front splitter, model how much more air is shoved into the cooler, and how much less goes under the front trunk. Maybe you can even determine the achieved downforce, which is the real reason to add this. Play with splitter length, width and how far it extends under the front end, maybe even create some channels into the middle from the sides or side wings on it??
Of course, really adding a splitter means balancing it with a wing and overcoming more drag, but it would make a good modeling exercise. Adding the cooler adds a bunch of messy ballast, so if it were my car I would look to other solutions for cooling, and consider a cooler mounted closer to the engine. Have fun! The AIR body kit is rad (IMG:style_emoticons/default/beerchug.gif) |
Apr 14 2010, 11:23 AM
Resident German Group: Admin Posts: 41,618 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
You reference 120hp. An efficient 120hp type 4 doesn't need external oil cooling and associated ducting. Sounds like your team is behind the curve. (IMG:style_emoticons/default/agree.gif) Something isn't right if he's running 250 temps after a AX run ... The blue 914 up here that is usually TTOD at the local AX does not even have a cooling fan anymore! Or engine tin. Or blower housing. And it has more than 120HP. |
yeahmag |
Apr 14 2010, 11:32 AM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Yeah... My 2056 would get warm with two drivers at El Toro and long courses running back to back, but not that hot. Now that I have an external cooler it is perfect.
I'd check timing and AFR. Mine got even better as I dialed those in. I still need the cooler for the track though... |
Mr G Force |
Apr 14 2010, 11:36 AM
Newbie Group: Members Posts: 14 Joined: 14-April 10 From: California Member No.: 11,609 Region Association: None |
You reference 120hp. An efficient 120hp type 4 doesn't need external oil cooling and associated ducting. Sounds like your team is behind the curve. (IMG:style_emoticons/default/agree.gif) Something isn't right if he's running 250 temps after a AX run ... The blue 914 up here that is usually TTOD at the local AX does not even have a cooling fan anymore! Or engine tin. Or blower housing. And it has more than 120HP. Guess it depends on whether youre talking 120 WHP or crank HP on a dyno. Type of compression etc. I could see a car over heating at Qualcomm if it didnt have an external cooler. A hot run up one of the hilly sections could definitely bring the heat up. |
yeahmag |
Apr 14 2010, 11:40 AM
For reference, my head temps when racing are usually at 300F, it's just my oil temps that creep up lap after lap. I'd be curious what the head temps look like on the car.
Apr 14 2010, 12:05 PM
Maybe whoever build his motor left out the cooling flaps. Wouldn't be the first time that happened.
Without the cooling flaps installed, there's NO air flow to the stock oil-cooler ... (IMG:style_emoticons/default/idea.gif) Andy |
Backdraft |
Apr 15 2010, 01:44 AM
@ Art: Isn't 120 hp an increase of around 50% over stock (80 hp), or is my math wrong? Anyways, I sort of see your point that 120 hp is still not very much for this type of engine (if run efficiently), but I'll try to clarify with him why and where he's exactly seeing these types of temps.
Lo-Fi Version | Time is now: 5th May 2024 - 10:24 AM |
