75 green car, fuel filter in engine bay |
Tom |
Apr 12 2010, 05:11 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
I was looking at some pics McMark posted and noticed what looks like a fuel filter in the engine bay just before the fuel rail. Did new cars have this filter there? Anyone else do this and is it a good idea? If the heat isn't a factor, it would seem to be easier to change the second fuel filter there.
Tom Pics here http://www.914world.com/bbs2/index.php?showtopic=105807 11 th pic. |
Katmanken |
Apr 12 2010, 05:51 PM
That might be the fuel pressure regulator being mistaken for a filter. It's about the right location.
Tom |
Apr 13 2010, 11:12 AM
Pressure regulator is on the drivers side , this one is on the pass side. It is a fuel filter.
Tom |
Root_Werks |
Apr 13 2010, 11:14 AM
Village Idiot Group: Members Posts: 8,315 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Not suppose to be there of course. All stock 914's had filters under the engine. Even after the 75-76' moved the pump to the front.
Might be something someone added or moved becuase it is easier to access? I would think heat would be a factor and you would want the filter as low as possible so no chance air gets trapped in it. |
Cap'n Krusty |
Apr 13 2010, 11:19 AM
Not suppose to be there of course. All stock 914's had filters under the engine. Even after the 75-76' moved the pump to the front. Might be something someone added or moved because it is easier to access? I would think heat would be a factor and you would want the filter as low as possible so no chance air gets trapped in it. Not exactly. ALL 914/4s had a fuel filter BEFORE the pump. 1970-1974 had it below the battery under the engine. '75-'76 had it between the tank and the pump, behind the little "door" in the rear bulkhead of the front trunk. IN NO CASE should a filter be placed AFTER the pump, especially if it's a plastic one. The Cap'n |
TheCabinetmaker |
Apr 13 2010, 11:22 AM
Not suppose to be there of course. All stock 914's had filters under the engine. Even after the 75-76' moved the pump to the front. Might be something someone added or moved because it is easier to access? I would think heat would be a factor and you would want the filter as low as possible so no chance air gets trapped in it. Not exactly. ALL 914/4s had a fuel filter BEFORE the pump. 1970-1974 had it below the battery under the engine. '75-'76 had it between the tank and the pump, behind the little "door" in the rear bulkhead of the front trunk. IN NO CASE should a filter be placed AFTER the pump, especially if it's a plastic one. The Cap'n Yep. They aren't meant to handle the pressure. |
Root_Werks |
Apr 13 2010, 11:33 AM
Not suppose to be there of course. All stock 914's had filters under the engine. Even after the 75-76' moved the pump to the front. Might be something someone added or moved because it is easier to access? I would think heat would be a factor and you would want the filter as low as possible so no chance air gets trapped in it. Not exactly. ALL 914/4s had a fuel filter BEFORE the pump. 1970-1974 had it below the battery under the engine. '75-'76 had it between the tank and the pump, behind the little "door" in the rear bulkhead of the front trunk. IN NO CASE should a filter be placed AFTER the pump, especially if it's a plastic one. The Cap'n Yep. They aren't meant to handle the pressure. Yup! I totally forgot about the 75-76' moving up front before the pump. |
Tom |
Apr 13 2010, 11:36 AM
In that case, this seems to be waiting for a fire! Anyone know this person to warn them?
Tom |
TheCabinetmaker |
Apr 13 2010, 11:54 AM
Are you talking about this pic? I don't think that is a fuel filter. I believe thats part of the 75/76 smog control.
Attached thumbnail(s) |
tradisrad |
Apr 13 2010, 11:59 AM
decel valve. as early as '73
Root_Werks |
Apr 13 2010, 12:21 PM
I think Tom was talking about this.....bad place for it.
Cap'n Krusty |
Apr 13 2010, 12:22 PM
Dead center on the right edge ............... Plastic fuel filter. Bad news .......
The Cap'n |
Apr 13 2010, 12:29 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Dead center on the right edge ............... Plastic fuel filter. Bad news ....... (IMG:style_emoticons/default/agree.gif) Attached image(s) |
TheCabinetmaker |
Apr 13 2010, 12:35 PM
Wel shoot! I totally missed that. Good eye guys!
Katmanken |
Apr 13 2010, 12:53 PM
There are fuel filters designed to run on the high pressure side.
The VW Vanagon runs one and it's a huge metal can about the size of an old 1 qt. oil can. Run, don't walk to the store for a piece of high pressure fuel line to replace that plastic filter, and move the plastic filter to a place BEFORE the pump.. |
Sleepin |
Apr 13 2010, 01:39 PM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
Root_Werks |
Apr 13 2010, 01:40 PM
Yup, I haven't ever seen (Not that they don't exist) a plastic filter on anything above 12psig before. Any high pressure filter I've seen has always been metal.
But then, I haven't seen a lot. (IMG:style_emoticons/default/wink.gif) |
TheCabinetmaker |
Apr 13 2010, 01:42 PM
I think they had plastics ones from the factory. I know my 73 1.7 did.
Apr 13 2010, 01:46 PM
I think they had plastics ones from the factory. I know my 73 1.7 did. But not on the pressure side of things. That's what he's referring to ... (IMG:style_emoticons/default/shades.gif) Andy |
Bleyseng |
yes, all 914's had a fuel filter placed BEFORE the fuel pump.....
Lo-Fi Version | Time is now: 9th May 2024 - 08:50 AM |
