Tom
Apr 12 2010, 05:11 PM
I was looking at some pics McMark posted and noticed what looks like a fuel filter in the engine bay just before the fuel rail. Did new cars have this filter there? Anyone else do this and is it a good idea? If the heat isn't a factor, it would seem to be easier to change the second fuel filter there.
Tom
Pics here
http://www.914world.com/bbs2/index.php?showtopic=105807 11 th pic.
Katmanken
Apr 12 2010, 05:51 PM
That might be the fuel pressure regulator being mistaken for a filter. It's about the right location.
Tom
Apr 13 2010, 11:12 AM
Pressure regulator is on the drivers side , this one is on the pass side. It is a fuel filter.
Tom
Root_Werks
Apr 13 2010, 11:14 AM
Not suppose to be there of course. All stock 914's had filters under the engine. Even after the 75-76' moved the pump to the front.
Might be something someone added or moved becuase it is easier to access?
I would think heat would be a factor and you would want the filter as low as possible so no chance air gets trapped in it.
Cap'n Krusty
Apr 13 2010, 11:19 AM
QUOTE(Root_Werks @ Apr 13 2010, 10:14 AM)
Might be something someone added or moved because it is easier to access?
Not exactly. ALL 914/4s had a fuel filter BEFORE the pump. 1970-1974 had it below the battery under the engine. '75-'76 had it between the tank and the pump, behind the little "door" in the rear bulkhead of the front trunk. IN NO CASE should a filter be placed AFTER the pump, especially if it's a plastic one.
The Cap'n
TheCabinetmaker
Apr 13 2010, 11:22 AM
QUOTE(Cap'n Krusty @ Apr 13 2010, 12:19 PM)
The Cap'n
Yep. They aren't meant to handle the pressure.
Root_Werks
Apr 13 2010, 11:33 AM
QUOTE(vsg914 @ Apr 13 2010, 10:22 AM)
The Cap'n
Yup! I totally forgot about the 75-76' moving up front before the pump.
Tom
Apr 13 2010, 11:36 AM
In that case, this seems to be waiting for a fire! Anyone know this person to warn them?
Tom
TheCabinetmaker
Apr 13 2010, 11:54 AM
Are you talking about this pic? I don't think that is a fuel filter. I believe thats part of the 75/76 smog control.
tradisrad
Apr 13 2010, 11:59 AM
decel valve. as early as '73
Root_Werks
Apr 13 2010, 12:21 PM
I think Tom was talking about this.....bad place for it.
Cap'n Krusty
Apr 13 2010, 12:22 PM
Dead center on the right edge ............... Plastic fuel filter. Bad news .......
The Cap'n
Apr 13 2010, 12:29 PM
QUOTE(Cap'n Krusty @ Apr 13 2010, 11:22 AM)
TheCabinetmaker
Apr 13 2010, 12:35 PM
Wel shoot! I totally missed that. Good eye guys!
Katmanken
Apr 13 2010, 12:53 PM
There are fuel filters designed to run on the high pressure side.
The VW Vanagon runs one and it's a huge metal can about the size of an old 1 qt. oil can.
Run, don't walk to the store for a piece of high pressure fuel line to replace that plastic filter, and move the plastic filter to a place BEFORE the pump..
Sleepin
Apr 13 2010, 01:39 PM
This was such a sneaky picture!
Root_Werks
Apr 13 2010, 01:40 PM
Yup, I haven't ever seen (Not that they don't exist) a plastic filter on anything above 12psig before. Any high pressure filter I've seen has always been metal.
But then, I haven't seen a lot.
TheCabinetmaker
Apr 13 2010, 01:42 PM
I think they had plastics ones from the factory. I know my 73 1.7 did.
Apr 13 2010, 01:46 PM
QUOTE(vsg914 @ Apr 13 2010, 12:42 PM)
But not on the pressure side of things. That's what he's referring to ...
Andy
Bleyseng
yes, all 914's had a fuel filter placed BEFORE the fuel pump.....
Root_Werks
Apr 13 2010, 01:47 PM
We should probably make sure people know exactly what we are talking about here.....
Apr 13 2010, 01:50 PM
QUOTE(Root_Werks @ Apr 13 2010, 12:47 PM)
Zee Fillder!
Sleepin
Root_Werks
Apr 13 2010, 01:56 PM
Oh I see it now...
Bleyseng
Apr 13 2010, 02:06 PM
That looks like a drawing Redshift did back in the day...
TheCabinetmaker
Apr 13 2010, 02:17 PM
QUOTE(Root_Werks @ Apr 13 2010, 02:40 PM)
QUOTE(SirAndy @ Apr 13 2010, 02:46 PM)
Andy
I didn't say anything about where the filter was placed. I know well where it goes. I was refering to roots statement that they never used plastic ones over 12 psi. I think they did!
Root_Werks
Apr 13 2010, 04:06 PM
QUOTE(Bleyseng @ Apr 13 2010, 01:06 PM)
I had that one saved on my PC for years, the cam with the lobes.
Frost
Apr 13 2010, 08:27 PM
i like those pics!
Cap'n Krusty
Apr 13 2010, 09:20 PM
QUOTE(vsg914 @ Apr 13 2010, 01:17 PM)
Andy
Wrong. In a 914/4, there's no pressure on the factory installed filters.
The Cap'n
