Gauging interest for PnP Megasquirt solution, MS anyone? |
JamesM |
Apr 12 2010, 08:15 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
For my most recent Megasquirt install i went a different route and had some mini-MS boards produced. It did not make a lot of sense to just have one PCB printed so needless to say i have more then a few empty boards laying around. Now i am trying to decide if it is worth my time and money to build these boards out and sell them as a plug n play solution for d-jet cars.
For those who don't know, mini-ms is electronically compatible with megasquirt 2.2 however the components are arranged tighter on the board and it integrates the relay board all on a form factor smaller then the original MS. My first couple of installs i used a standard megasquirt 2.2 with relay board and DB-37 cable but the mini-ms seemed like the better way to go so that is what i am playing with now. The setup i a running right now looks almost stock, the mini-ms is enclosed completely in a gutted d-jet brain and plugs directly into the d-jet harness. the only difference from stock is a MAP line running to the brain and the 2 injector ground wires being run back as well. You have to look close to tell its not stock, however i have a feeling i could make it even more stealth by hiding the MAP sensor in an old MPS in order to get rid of the vac line to the ECU. I just have not cared enough to cut up an MPS yet. The great part about this system is it makes troubleshooting way easier and eliminates the need for stock trigger points, MPS. ECU, decell valve, and cold start injector, though they can all be left in place if desired in order to appear stock. It also allows for cool things if you desire like closed loop operation with a wideband O2 sensor, spark control, rev limiters, traction control, and a bunch of other stuff depending on how far you want to take it. It can be tuned around just about anything, so its great if you want to change cams or go bigger on your motor and still look stock. So is there any interest out there for this sort of thing or should i just dump the empty boards on ebay or something? |
McMark |
Apr 13 2010, 12:15 PM
True, but hardware that's PnP does exist. That's the common problem with MS. You have to spend a ton of time actually building your conversion (and I'm not even talking about soldering the brain here) then you have to take the time to tune it.
JamesM |
Apr 13 2010, 02:22 PM
True, but hardware that's PnP does exist. That's the common problem with MS. You have to spend a ton of time actually building your conversion (and I'm not even talking about soldering the brain here) then you have to take the time to tune it. (IMG:style_emoticons/default/agree.gif) That is the common problem i am trying to solve. My thoughts on it are that if you have a standard set of hardware you are adapting to say an existing 1.7 or 2.0 d-jet system, then you pretty much know what to expect during the install. If you can prepare all the adaptation ahead of time inside the ecu, then the hardware at least is plug and play. use it with a fuel map setup for for the same spec motor and you are going to be pretty darn close, at least as close as d-jet would be. ...and here is where modern fuel injection wins out in my opinion. From a close map megasquirt can use a wideband sensor with target AFR tables to put your mixture where ever you want it on the fly, this will handle engine wear and other environmental situations that d-jet can not. Just one of the advantages that i see. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:09 PM |
