Gauging interest for PnP Megasquirt solution, MS anyone? |
JamesM |
Apr 12 2010, 08:15 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
For my most recent Megasquirt install i went a different route and had some mini-MS boards produced. It did not make a lot of sense to just have one PCB printed so needless to say i have more then a few empty boards laying around. Now i am trying to decide if it is worth my time and money to build these boards out and sell them as a plug n play solution for d-jet cars.
For those who don't know, mini-ms is electronically compatible with megasquirt 2.2 however the components are arranged tighter on the board and it integrates the relay board all on a form factor smaller then the original MS. My first couple of installs i used a standard megasquirt 2.2 with relay board and DB-37 cable but the mini-ms seemed like the better way to go so that is what i am playing with now. The setup i a running right now looks almost stock, the mini-ms is enclosed completely in a gutted d-jet brain and plugs directly into the d-jet harness. the only difference from stock is a MAP line running to the brain and the 2 injector ground wires being run back as well. You have to look close to tell its not stock, however i have a feeling i could make it even more stealth by hiding the MAP sensor in an old MPS in order to get rid of the vac line to the ECU. I just have not cared enough to cut up an MPS yet. The great part about this system is it makes troubleshooting way easier and eliminates the need for stock trigger points, MPS. ECU, decell valve, and cold start injector, though they can all be left in place if desired in order to appear stock. It also allows for cool things if you desire like closed loop operation with a wideband O2 sensor, spark control, rev limiters, traction control, and a bunch of other stuff depending on how far you want to take it. It can be tuned around just about anything, so its great if you want to change cams or go bigger on your motor and still look stock. So is there any interest out there for this sort of thing or should i just dump the empty boards on ebay or something? |
roadster fan |
Apr 14 2010, 06:46 PM
Project Frankenstein !!!!!!!! Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
I think Jeff brings up some valid points. I think using the term plug n play is probably a stretch, but for the advanced DIY'er it could feel like PnP. I think marketing the system with a base fuel map for 1.7 and 2.0 cars would sell a few kits as that would get the beginner MS user close to a working setup.
In fact you would probably be better off in my opinion selling your expertise in the base setups for stock engine configs and leave the hardware to the end user. Make recommendations, or show what worked for you hardware wise, then sell the mini-MS boards and base setup. I would be more inclined to go MS if I had a good basis to start from to reduce the risk of destroying my motor but like the idea of tinkering with programmable EFI. I would think anyone using an original harness would be foolish to attempt to adapt it to MS. Jeff has seen more harnesses than most of us, and the few I have seen were thrashed. In fact I am amazed my 1.7 harness still works, gonna have to address that this year (IMG:style_emoticons/default/dry.gif) I think the discussion is productive as a solution for djet cars is inevitable in my humble opinion as parts continue to become scarce and pricey. Just my .02 Jim |
JamesM |
Apr 14 2010, 09:58 PM
I think Jeff brings up some valid points. I think using the term plug n play is probably a stretch, but for the advanced DIY'er it could feel like PnP. I think marketing the system with a base fuel map for 1.7 and 2.0 cars would sell a few kits as that would get the beginner MS user close to a working setup. In fact you would probably be better off in my opinion selling your expertise in the base setups for stock engine configs and leave the hardware to the end user. Make recommendations, or show what worked for you hardware wise, then sell the mini-MS boards and base setup. I would be more inclined to go MS if I had a good basis to start from to reduce the risk of destroying my motor but like the idea of tinkering with programmable EFI. I would think anyone using an original harness would be foolish to attempt to adapt it to MS. Jeff has seen more harnesses than most of us, and the few I have seen were thrashed. In fact I am amazed my 1.7 harness still works, gonna have to address that this year (IMG:style_emoticons/default/dry.gif) I think the discussion is productive as a solution for djet cars is inevitable in my humble opinion as parts continue to become scarce and pricey. Just my .02 Jim Perhaps "Bolt-on" would be a better term to use then plug n play. As with any aftermarket part it most likely will require tuning to get it at its best, but the same goes for carbs or any other FI setup. Nothing is perfect out of the box. The goal is to have it running and driving decently out of the box with minimal install effort and no fabrication. Im not sure how i would feel about selling my expertise. I am fine with selling my time, but i have always been a big believer in free information so anything i know on the subject i will gladly share with the community, provided it does not eat up to much of time. My initial idea behind this was not one of turning it into a business, but more of providing what i saw as a useful solution and covering the cost of the parts and my time involved in doing it. I had spare boards from a personal project that i did not want to go to waste. Interest in this has been way more then i expected though, my supply of "extra" boards wouldn't even cover half of the people that have already spoke up, and this poll has only been up for 2 days. That being said I might have to look at a more serious production/business venture. Though various liability and support issues have been brought up that warrant strong consideration. Either way though I plan on it being an open project with information shared freely. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:24 PM |
