Gauging interest for PnP Megasquirt solution, MS anyone? |
JamesM |
Apr 12 2010, 08:15 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
For my most recent Megasquirt install i went a different route and had some mini-MS boards produced. It did not make a lot of sense to just have one PCB printed so needless to say i have more then a few empty boards laying around. Now i am trying to decide if it is worth my time and money to build these boards out and sell them as a plug n play solution for d-jet cars.
For those who don't know, mini-ms is electronically compatible with megasquirt 2.2 however the components are arranged tighter on the board and it integrates the relay board all on a form factor smaller then the original MS. My first couple of installs i used a standard megasquirt 2.2 with relay board and DB-37 cable but the mini-ms seemed like the better way to go so that is what i am playing with now. The setup i a running right now looks almost stock, the mini-ms is enclosed completely in a gutted d-jet brain and plugs directly into the d-jet harness. the only difference from stock is a MAP line running to the brain and the 2 injector ground wires being run back as well. You have to look close to tell its not stock, however i have a feeling i could make it even more stealth by hiding the MAP sensor in an old MPS in order to get rid of the vac line to the ECU. I just have not cared enough to cut up an MPS yet. The great part about this system is it makes troubleshooting way easier and eliminates the need for stock trigger points, MPS. ECU, decell valve, and cold start injector, though they can all be left in place if desired in order to appear stock. It also allows for cool things if you desire like closed loop operation with a wideband O2 sensor, spark control, rev limiters, traction control, and a bunch of other stuff depending on how far you want to take it. It can be tuned around just about anything, so its great if you want to change cams or go bigger on your motor and still look stock. So is there any interest out there for this sort of thing or should i just dump the empty boards on ebay or something? |
ThinAir |
May 3 2010, 10:04 PM
Best friends Group: Members Posts: 2,542 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
I'm late to this thread, but finding it very interesting. My vote in the poll was "I'm interested" and "price is no object" because it wouldn't let me skip the price question.
I'm running a stock 2.0L engine with stock FI. Although upgrading to a Jeff Bowlsby harness has given me a system that is very reliable, it's really only a matter of time before there some component that goes out which cannot be obtained or replaced for any price. So yes I'm interested in a system made of modern components that I could install by simply unplugging what I'm got, then plug in the new system and have a running car that was ready to be optimized. I don't care if that's call "bolt-on" or "PnP". I don't care if it reuses my existing harness (although it would be nice). What I care about is that gives me a way to easily remove what I consider to be the 914's Achilles heal - an aging FI system. So everyone involved in contributing ideas gets my support! |
Lo-Fi Version | Time is now: 17th May 2024 - 06:40 PM |
