Gauging interest for PnP Megasquirt solution, MS anyone? |
JamesM |
Apr 12 2010, 08:15 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
For my most recent Megasquirt install i went a different route and had some mini-MS boards produced. It did not make a lot of sense to just have one PCB printed so needless to say i have more then a few empty boards laying around. Now i am trying to decide if it is worth my time and money to build these boards out and sell them as a plug n play solution for d-jet cars.
For those who don't know, mini-ms is electronically compatible with megasquirt 2.2 however the components are arranged tighter on the board and it integrates the relay board all on a form factor smaller then the original MS. My first couple of installs i used a standard megasquirt 2.2 with relay board and DB-37 cable but the mini-ms seemed like the better way to go so that is what i am playing with now. The setup i a running right now looks almost stock, the mini-ms is enclosed completely in a gutted d-jet brain and plugs directly into the d-jet harness. the only difference from stock is a MAP line running to the brain and the 2 injector ground wires being run back as well. You have to look close to tell its not stock, however i have a feeling i could make it even more stealth by hiding the MAP sensor in an old MPS in order to get rid of the vac line to the ECU. I just have not cared enough to cut up an MPS yet. The great part about this system is it makes troubleshooting way easier and eliminates the need for stock trigger points, MPS. ECU, decell valve, and cold start injector, though they can all be left in place if desired in order to appear stock. It also allows for cool things if you desire like closed loop operation with a wideband O2 sensor, spark control, rev limiters, traction control, and a bunch of other stuff depending on how far you want to take it. It can be tuned around just about anything, so its great if you want to change cams or go bigger on your motor and still look stock. So is there any interest out there for this sort of thing or should i just dump the empty boards on ebay or something? |
draganc |
Aug 24 2010, 08:27 AM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
James,
I like your project a lot and believe the MS system is the right approach for 914. Why? Because most of us “like” to work on 914 and we are all facing a return-of-invest issue/challenge with the 914. I have been screening the aftermarket FI ECU for about a year. There are great products (Electromotive, AEM, MSD, ect) out there for a great price. MS offers a very flexible inexpensive package for the DIYer. Maybe it’s not perfect (I don’t see any show stopper yet) but it’s within reach. I believe MS – even in a PNP setup – will always require some minor tuning. But that goes for all aftermarket FI ECU. A true PNP system will be to go to one of the 914 experts and have them install a ECU system and let them do all the work. As of the MS warranty terms, they had to use that statement because it IS a DYI experimental system and every 2nd guys modifies the system to his specification – that is the purpose of a open platform! Even SDS’ webpage states that read their manual first and then buy the product if you believe you can do it. To conclude, I believe that most of the available aftermarket ECUs are very well design systems and all have some pros/cons. It’s up to you/us to pick the system of your choice. My suggestion is to read a few ECO books (i.e Bosch FI & Engine Management, Design and tuning high-performance FI systems, ect) before you make up your mind. I have made my choice, it is Megasquirt. Keep up the great work!! Dragan PS: How did you install the trigger wheel? Std. GM or MS 36-1 trigger wheel at the crank? |
Lo-Fi Version | Time is now: 17th May 2024 - 07:46 PM |
