? DPD and VPC A/C Center Console differences ?, A dealer installed option |
Dr. Roger |
Apr 13 2010, 03:39 AM
I'm not sure what I have, so...
I have a hard plastic, 3 gauge, center piece which has the gauges angled facing the driver. The clock is quartz. It is short to accommodate A/C. I also used to have a vinyl covered, 3 gauge, short center console in which the gauges sat square in the holes. My research seems to show that there were two different types of A/C with each a particular center console. ~I'm curious to know which year has which type of air-conditioning/center console combination? ~Is it true that the short, angled, gauge console is the rarer of the types? ~Is it true that A/C was a dealer installed option only? Thanks ! Attached image(s) |
Tom_T |
Apr 13 2010, 04:45 AM
This is the DPD console & underdash AC unit, where the controls are usually centered under the regular dash vent/heat control sliders sit, & the leftmost vent outlet for the AC is closer to the steering wheel than in the VPCs below:
. This is the VPC console & underdash AC unit, with the dials offset to the right of the dash sliders & the leftmost AC vent is further from the steering wheel & driver: ... The VPD in center console models has the 3 gauges flat mounted (as opposed to the DPD's canted ones), but more obvious is that they're in a triangular arrangement in the shortened gauge face board: . Also the DPD used a conical flat topped cover over the condenser in the spare tire well in the front trunk, over & around which the spare fit neatly without much if any added height to reduce front trunk storage space. I think it might have been a later development of the following & may have had the same designer. Whereas the VPC (Volkswagen Products Corp. - VW of America's accessories arm) had a a square or rectangular shroud which the spare sat on to of, which raised the floor board height & reduced trunk space. Apparently there are a few examples out there with alternative locations in the rear trunk or under the car because of this issue. All AC's on 914's were dealer installed options (excepting later conversions), &IIRC both VPC & DPD were available in all model years 1970-76. Apparently the "modern" unit sold by AA is also designed by the guy who did the DPD (at least that's what their catalog says). I cannot say which are/were more prevalent,but most preferred the DPD for the above reasons & slightly better cooling effectiveness - & either could freeze your socks off in that little cockpit, but both robbed 5-8 HP when running, vs. only 1-2 HP on the Modern R134 ones sold by AA. Hope this helps! (IMG:style_emoticons/default/biggrin.gif) |
Dr. Roger |
Apr 13 2010, 11:40 AM
Very interesting. I used to think the 3 offset gauges were home brewed solutions for a large diameter gauge set. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/lol-2.gif)
So there were 3 A/C options. DPD, VPC, and the VPD. DPD and VPC were offered in all years. VPD in later cars. This is why I need to hang out more in "Originality and History". (IMG:style_emoticons/default/driving.gif) |
Tom_T |
Apr 13 2010, 12:17 PM
Oooops!!!! - my bad! (IMG:style_emoticons/default/chair.gif)
No Roger - just the 2 - the "VPD" was just my brain fart"! (IMG:style_emoticons/default/laugh.gif) The second 914 with the VPC center console is Steve G's Sahara beige featured in the O&H Forum's "The few, the rare ..." nailed thread. I added it when I realized the old VPC options brochure pic didn't show the console. I'm trying to train myself with the VPC there! (IMG:style_emoticons/default/lol-2.gif) You could say that the new AC sold at AA is the 3rd one. Here's the link to the AA site on their 1 & 2 condenser versions of it for 914s: http://www.autoatlanta.org/detail.lasso?pa...;serial_number= http://www.autoatlanta.org/detail.lasso?pa...;serial_number= A better description of it is on pg. 149 of their free to download AA linkable pdf 914 catalog at this link below, which does say that the same guy designed all 3 systems - VPC, DPD & new AA one): http://www.autoatlanta.com/pdf/download914...e-914-parts.pdf This is their how to install a VPC or DPD unit book by Dr. George: http://www.autoatlanta.org/detail.lasso?pa...;serial_number= IIRC - this isn't covered at the O&H section yet, so maybe when I get time I can post pix. I did all this research because I was considering putting AC in mine as a part of the resto due to the SoCal heat, but was advised by dr914 (George Hussey) not to do so since mine was never optioned that way from the dealer. After all the research - my plan ended up though to try to put the "new" R134 system of his into a period correct dash/shorty-console & front condenser of the DPD - so modern innards & operation with the correct period look (as if updated), which is probably what I'd do today if I had an AC'ed 914 whose DPD AC unit was dead or becoming a PITA to keep running. |
Tom_T |
Apr 13 2010, 12:30 PM
Roger - I put the link below in O&H - to your topic here as a temporary measure ....
http://www.914world.com/bbs2/index.php?sho...=105915&st= (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 9th May 2024 - 09:12 AM |
