What are people doing after driving in the rain... |
dank |
Apr 13 2010, 02:58 PM
DanielK Group: Members Posts: 25 Joined: 8-March 10 From: Mountain View, CA Member No.: 11,440 Region Association: None |
...in terms of preventive rust maintenance, etc.?
Found this on what people who water-wash their car do, so I assume it's the same type of stuff? http://www.914world.com/bbs2/index.php?showtopic=71280 air compressor to blow out water from any nooks and crannies, after making sure in particular to get (with a towel): - trunk gutters - bottom corners of the front trunk, since water travels from top corners to bottom. - inside edges of the window trim - the black plastic vent plugs in the door jams |
Apr 13 2010, 03:00 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I added small drain holes to the rear trunk and floorboards.
If that's not enough, i use a towel to get the water out as soon as possible. I don't have a garage, so i have to do that frequently ... (IMG:style_emoticons/default/dry.gif) Andy |
turboman808 |
Apr 13 2010, 03:13 PM
Advanced Member Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
Use and air compressor like you said.
You have to use soap and water to get the dirt off the car. I've seen people use steam but it's really not impressive at all, great for cleaning motors and under the car though. When your done use the air compressor. I use a shop vac that I only use for drying the car. It has a filter so I am not blowing any dust or dirt back on the car. Towel up the excess After that park the car in the sun to heat up the car and get anything you might have missed. I haven't washed my car in 6 months. It's only got dust on it and I used a duster and air to get it off. Then hit up the paint with some poor boys spray n shine to make it look a touch better. Use soft plush microfiber towels to prevent scratching. It's softer then cotton and also pulls moistrue away from the car alot better . |
Apr 13 2010, 05:47 PM
I park the car...what else would I do after driving...
If your car is leaking, fix the leak if you can or put a cover on the car when you park it. Rich |
BigDBass |
Apr 13 2010, 06:01 PM
Dumb Question Champion Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
I don't drive it in the rain but have been caught a time or two. But... my car is utterly filthy. I want to wash it but threads like this one and the "dry wash" one referred to above scare me.
lotus_65 |
Apr 13 2010, 06:22 PM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
just make sure the drain holes are clear.
i'd check the turn signal housings unless you know the seals are perfect. |
pcar916 |
Apr 13 2010, 06:35 PM
I'm often caught in the rain and with a six, there is water to towel out of the engine compartment since there is no rain tray. That said...
if I keep the speed above 65 or so, no rain gets in the engine compartment. I make sure the hell hole gets dried out along with any other puddles that form elsewhere in the car. Then celebrate how much fun it is to drive in the rain. That and a big parking lot make for good times to teach the kids car control, and how NOT to be freaked out when the back end gets loose. |
VaccaRabite |
Apr 13 2010, 06:49 PM
En Garde! Group: Admin Posts: 13,441 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I drove in the rain today. Weather man lied about when it would start. :/
When I got home I just put it in the garage. No biggie. I am way more concerned about road salt then I am about a clear water spring rain. Zach |
realred914 |
Apr 13 2010, 10:02 PM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
compressed air can be tough on paint, lift up defects, be careful. really these cars can be driven teh int ehrain. if you park in a garage all the better, I have kept them outside all winter, just silicone the top seal if yours is shot and you cant afford a new one, a six buck tube of silicone will do several topes, mask with tape to get a nice stright line. when summer comes, zip it off with a sharp knive
main thing is good paint and wax , take care of chips right away even tempory fix with primer is better than bare metal for even a few days, frquent wax repels waxer, check for and repair leaks right away. do unde rside inspect fo intact seam sealer under car, make sure battery is sealed type so no acid rians down on suspension. oil under side of car with comercial weather proof coatigns as needed, dont drive on salted roads. do this and you can drive in teh rain all you want. maintanence is the key. I used to commut daiily many miles rain or shine, even storms in my 914 I had to repalce my top seal, but other wise it was great good heater is helpful cuase there is always some leak, and you need ot cook out the humidity to see out the the windows. I think I will go play my Who album, the rain song. |
Rand |
Apr 13 2010, 10:11 PM
All the areas that are prone to rust should be meticulously taken care of and painted well! Water runs off good paint. Water is only an enemy when it reaches unprotected metal.
If you are well protected, don't fear rain. But DO check protection often! |
horizontally-opposed |
Apr 13 2010, 10:23 PM
Advanced Member Group: Members Posts: 3,431 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Question: "What are people doing after driving in the rain?"
Answer: "Painting their 914s." At least, that was my experience. I've always LOVED driving my 914 in the rain (at least on good roads) but I am sad to say I probably won't anymore. My car had a few VERY minor rust bubbles that didn't change for 10-15 years the car was garaged, used occasionally (and occasionally in the rain), and washed from time to time. Then I pressed it back into service as a daily for a year, in all weather and quite a bit of rain. A few years later, things started bubbling up. Not a lot, but the things that were stagnant previously started making their move. We stripped the car to bare metal and found it is probably one of the less rusty 914s out there (esp. for 250,000+ miles) — but my experience tells me these cars are NOT okay in the rain. They're old, they do not benefit from rust-proofing, and there are a lot of pores and voids for water and moisture to get into that are then not easily or economically fixed. I am VERY surprised I am coming to this conclusion because I am a bit believer in driving the cars, but I'd like to keep this car another 30-40 years, and the best way to do that I can see is to sacrifice the fun of using it in the rain. That said, I know other 914 nuts I respect a great deal who take a very different view — one I agree with if the car is seen as a tool and as a replaceable tool. I don't view my 914 as replaceable. I could (and probably would) get another one, but it's been in the family since 1986 and in my care since 1991. A lot of memories... YMMV! pete |
veltror |
Apr 14 2010, 03:37 AM
Senior Member Group: Members Posts: 928 Joined: 27-April 08 From: Potters Bar Herts UK Member No.: 8,978 Region Association: None |
if you take a look at my car you can see what happened to it after i drove it everyday for 10 years, rain,snow,fog,sun whatever. Yes i had serious rust issues and yes it is going to cost me time and money, but cars are to be driven not garage queens, besides if i could only drive on sunny days it would mean 360 days a year it would be parked in a garage. And in all those 10 yeasr it was outside, because i did not have a garage....
rwilner |
Apr 14 2010, 06:22 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
My father has a corvette and we have a dehumidifier in the garage. We run it for a few days after the car has been washed or gets caught in the rain.
It is a garage queen though, so not sure about what you'd do for a DD. His garage is very tight which means we're not dehumidifying the outside world. That would take a much larger dehumidifier I think. |
dflesburg |
Apr 14 2010, 06:23 AM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
Just like when we wash them.
Open all doors, trunks, compartments and dry out everywhere. You wouldnt put a baby to bed wet would you? If the car has to sit out get a cover, even a walmart cover works but be sure to wash it in the big drum washers at the laundry mat now and then and use camp dry on it to keep it water proof. (dont treat it while its on the car). |
Katmanken |
Apr 14 2010, 10:55 AM
Shade Tree |
Member Group: Members Posts: 260 Joined: 18-December 08 From: Springfield, Oregon Member No.: 9,860 Region Association: Pacific Northwest |
After I drive my car in the rain, I go inside and put on dry clothes....'cause that sucker leaks!
bandjoey |
Apr 14 2010, 10:59 AM
bandjoey Group: Members Posts: 4,925 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Replace all of your seals with Mikey's seals, adjust the side windows to fit tight, reseal the rear window, and you'll not have any water inside the car. (IMG:style_emoticons/default/smash.gif)
Fix the rust and repaint the outside, and water doesn't matter. - To me, that is - (IMG:style_emoticons/default/smoke.gif) |
Drums66 |
Apr 14 2010, 03:33 PM
[quote name='BigDBass' date='Apr 13 2010, 05:01 PM' post='1302974']
I don't drive it in the rain but have been caught a time or two. ECHO echo (IMG:style_emoticons/default/yellowsleep[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) |
underthetire |
Apr 14 2010, 03:37 PM
Put dry shoes and socks on.
charliew |
Apr 14 2010, 03:58 PM
I don't like air pressure blowing water in cracks and crevaces. It will then get to where it normally wouldn't. My friend always blows his harley off with the air hose. His switches usually last about 4 years then he buys new ones.
Lo-Fi Version | Time is now: 9th May 2024 - 10:26 AM |
