tranny input shaft leak, do i have to pull the cover? |
rudedude |
Apr 13 2010, 07:16 PM
Senior Member Group: Members Posts: 508 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
Or can i get access to the roll pin on the input shaft from that small cover on the bottom? It seems like the front cover probably needs to come off but I'm not sure.
Also is the seal the same size as as a 901 input shaft? Thanks, Jule |
underthetire |
Apr 13 2010, 07:24 PM
Input shaft seal=trans removal. Seal comes out the front, and the input shaft would have to be free of the flywheel in order to do it.
rudedude |
Apr 13 2010, 07:29 PM
Sorry, I mean the shift linkage input shaft on an early style tranny.
Thanks Jule |
Lo-Fi Version | Time is now: 8th May 2024 - 09:26 PM |
