Starting problem, Abandoned and walked home! |
BigDBass |
Apr 14 2010, 09:36 PM
Dumb Question Champion Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
I was driving the 914 home from my in-laws I decided to stop for ice cream for the girls. It had started just fine at their house, then drove for 20 or so minutes before stopping. Bought the ice cream, then the car wouldn't start back up. Battery seems fine, and I think the starter was fine as it was turning over, but the engine wouldn't fire up. Sorta seemed like no fuel? Waited a few minutes then tried again but no luck. Called home to tell the wife, then naturally my cell battery died. Waited a few more minutes, tried and failed to start, then walked home to kill time and post/search on here (and keep my wife from freaking!) So any tips? |
SLITS |
Apr 14 2010, 09:40 PM
fuel pump? did you hear it run when you turned the ignition on?
blown fuse on the relay board? Bad FP relay on the relay board? |
McMark |
Apr 14 2010, 09:41 PM
Go back and try it again. (IMG:style_emoticons/default/wink.gif)
It got flooded.
probably need to replace your CHT. These motor get hotter when you park them...by quite a bit on a 20 minute drive. If it happens again, remove the air cleaner so the intake gets fresh air, hold your foot to the floor so the throttle is wide open and crank it for a bit...you will eventually get it going. I suspect if you go back after an hour or so, it will start right up. Get it home.. we can tell you a few tests to see what the real problem is. rich |
Dr Evil |
Apr 14 2010, 09:42 PM
AAR or heater fan power grounded? These will blow the fuse to the Fuel pump power. Same supply.
drgchapman |
Apr 14 2010, 09:45 PM
Current Stable Group: NoClassifiedAccess Posts: 922 Joined: 20-September 04 From: Portland, OR Member No.: 2,789 Region Association: Pacific Northwest |
Just had same issue with mine. Check to make sure fuel pump is priming the system upon turn of the key, prior crank position. Fuel pump relay is in the engine bay, third round one from the front of the car. You can "borrow" another relay from the panel, pick the first or fourth one from the front, they run the rear window defroster and the heater blower motor respectively. The second relay is for the injection system, might want to swap that one as well. In other words, the two middle round relays are the important ones and the end ones are optional for getting home. The relays are getting old, I found that out of 6 extra relays that I had, 3 were defective, 2 intermittently.
Good luck. Gary |
BigDBass |
Apr 14 2010, 09:51 PM
Oh yeah, meant to mention that I was listening for the fuel pump to "prime" when first turning the key to ON, and I couldn't hear it, but that may have been due to traffic noise.
My plan/hope is that after I walk back it will start up, then can dig deeper after it's home. Figured I may as well get the conversation started while I wait! (IMG:style_emoticons/default/smile.gif) I cursed myself by mentioning to my father-in-law how great it's been running... Further back story is that I was at their house to fix their PC. Ended up bringing it home with me, so had the pleasure of the ~1 mile walk from Baskin Robbins carrying a quart of ice cream and their PC tower! |
Tom |
Apr 14 2010, 10:01 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
If your fuel pump is running, you probably have what was mentioned by Rich. If it happens again, before you put the gas pedal to the floor, turn the key to off. Prevents a shot from the injectors, which makes the problem worse. I've had this happen several times and asked before. If you are good at the search function, look up hot,hard to start. Brad Anders gave me the answer.
Tom |
BigDBass |
Apr 14 2010, 10:04 PM
Ok, have 4 spare round relays to take back with me and spare fuses waiting in the glovebox. It's been over an hour now. Is that long enough for it to cool down? |
Tom |
Apr 14 2010, 10:06 PM
YEP!
BigDBass |
Apr 14 2010, 10:14 PM
Ok, here goes nuthin'! Cross your fingers! (IMG:style_emoticons/default/biggrin.gif)
rick 918-S |
Apr 14 2010, 10:26 PM
Hey nice rack! -Celette Group: Members Posts: 20,443 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Dr. Roger |
Apr 14 2010, 10:31 PM
(IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif)
I just love troubleshooting stuff. It's so educational. |
Jerry |
Apr 14 2010, 10:37 PM
Member Group: Members Posts: 413 Joined: 7-April 05 From: Conroe, Texas Member No.: 3,892 Region Association: None |
.....Well ????? We are waiting on pins and needles!!! What happened? |
BigDBass |
Apr 14 2010, 10:42 PM
Started right up! (IMG:style_emoticons/default/biggrin.gif)
So now I'm trying to figure out what I learned... |
BigDBass |
Apr 14 2010, 10:49 PM
Lessons so far:
1. Don't use up your cell battery on PC tech support calls to India prior to having car trouble. 2. Keep extra relays in the car instead of the garage. 3. Eating ice cream is a good way to kill time while waiting for your car to cool off. 4a. 914world is always there to help when you have trouble. 4b. 914world is to blame for dragging me in to trouble in the first place. |
rick 918-S |
Apr 14 2010, 10:54 PM
Glad it worked out ok! (IMG:style_emoticons/default/bye1.gif)
Tom |
Apr 15 2010, 05:15 AM
Root_Werks |
Apr 15 2010, 09:19 AM
Village Idiot Group: Members Posts: 8,315 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
We're here to help buddy. (IMG:style_emoticons/default/biggrin.gif)
Well, except me, I waited until it was all over......then started posting dancing bananas. (IMG:style_emoticons/default/mueba.gif) (IMG:style_emoticons/default/mueba.gif) (IMG:style_emoticons/default/mueba.gif) (IMG:style_emoticons/default/mueba.gif) (IMG:style_emoticons/default/mueba.gif) (IMG:style_emoticons/default/mueba.gif) (IMG:style_emoticons/default/mueba.gif) (IMG:style_emoticons/default/mueba.gif) |
Sleepin |
Apr 15 2010, 09:37 AM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
....so had the pleasure of the ~1 mile walk from Baskin Robbins carrying a quart of ice cream and their PC tower! (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/poke.gif) Sorry, I was just invisioning what I would have thought as I drove past some guy carrying a PC tower and a bucket of ice cream.....at least you didn't have on high heels and a skirt.... (IMG:style_emoticons/default/blink.gif) So the final verdict was just a hot start issue.....or a CHT? |
Lo-Fi Version | Time is now: 8th May 2024 - 05:51 PM |
