Drilling Spot Welds, What do you use? |
obscurity |
Apr 15 2010, 08:09 AM
Member Group: Members Posts: 411 Joined: 24-February 06 From: Atlanta ,GA Member No.: 5,628 Region Association: South East States |
I have been drilling spot welds as I work on my car and it occured to me that there may be a better way (or maybe I am being to picky). I am curious what everyone else uses.
I have been using a spot weld cutter. It looks like a short drill bit with a pilot point and little cutters along the edge. It will cut through the top layer or steel but not the back layer (usually). They will cut about 10 welds before being hoplessly dull. When I was buying them at $5/bit it was fine but that company went out of business and the ones I find now are $25/bit. Are these the right tools to use or should I be just using a drill bit allthe way through the weld. Any help or tool suggestions would be appreciated. (IMG:style_emoticons/default/smile.gif) Thanks, John W. |
ConeDodger |
Apr 15 2010, 08:12 AM
Apex killer! Group: Members Posts: 23,577 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
That is what I use... They run about $15/bit at an autobody supply near me.
tat2dphreak |
Apr 15 2010, 08:37 AM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
a decent one will drill more than 10 spots... or should. remember the welding metal is usually softer than the metal around it... the metal around it will dull the blade faster.
I have one that I've used for quite a few spots(I've lost count) and it still works... I can't remember what I paid, tho I remember thinking it wasn't cheap for a single bit.... then I ended up needing it more than I thought I would. |
sean_v8_914 |
Apr 15 2010, 08:46 AM
Chingon 601 Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
harbor freight spot weld drill I use has done 3 suspension consoles, 3-4 battery trays and 2 trunks. they try to walk if your technique is off, this breaks the pilot tip. I drill a small 1/8 pilot dimple. start teh "circle" cut slow then lay into it once the "cut track" is about 1/16-1/8 deep
993inNC |
Member Group: Members Posts: 194 Joined: 14-August 09 From: at the beach Member No.: 10,676 Region Association: South East States |
I just did my floor pans recently and used a standard bit (sorry don't recall the size). I drilled until the bit got dull and then ran it through the bit sharpener, worked like a champ. The only issue is you can't drill quite as deep and I used a chisels to get under the pan and pop the last fringes of metal holding on. One bit, worked it down to a nub (IMG:style_emoticons/default/biggrin.gif)
dion9146 |
Apr 15 2010, 08:54 AM
Member Group: Members Posts: 469 Joined: 16-May 04 From: Buckner, KY Member No.: 2,071 Region Association: MidAtlantic Region |
harbor freight spot weld drill I use has done 3 suspension consoles, 3-4 battery trays and 2 trunks. they try to walk if your technique is off, this breaks the pilot tip. I drill a small 1/8 pilot dimple. start teh "circle" cut slow then lay into it once the "cut track" is about 1/16-1/8 deep Yep, exactly what I used too, but I only used it on one suspension console and it worked like a charm. I started using a regular drill bit, but this was much easier to use and less damaging to the metal underneath. |
rjames |
Apr 15 2010, 09:00 AM
I'm made of metal Group: Members Posts: 3,922 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Would cutting fluid help with keeping the bits from getting dull?
jasons |
Apr 15 2010, 09:11 AM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
You know, I found using an air chisel CAREFULLY worked better than a spot weld bit. Or, using a small cut off wheel to grind down the spot weld, then pop it with the air chisel. Once you get the seam lifted up a little, the air chisel just pops it away, leaving a minimal amount of weld to clean up.
I must stress the word CAREFULLY. You can do a lot of damage with the chisel if you aren't careful. BTW, if you are dulling them, maybe you are turning them too fast. Also, a touch of oil on the bit before you drill might help too. |
jim_hoyland |
Apr 15 2010, 09:15 AM
Get that VIN ? Group: Members Posts: 9,272 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
What size is recommended for say removing the spot welds for a bumper backdate project ( '75 914 )
Attached image(s) |
Bleyseng |
Apr 15 2010, 09:20 AM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
What size is recommended for say removing the spot welds for a bumper backdate project ( '75 914 ) Are you finally going to jump to the "darkside" of early chrome bumpers? (IMG:style_emoticons/default/chair.gif) |
McMark |
Apr 15 2010, 09:30 AM
I buy a huge box of cheap drill bits and use those. When one gets dull I toss it and grab another. $50 for 115
Porcharu |
Apr 15 2010, 09:42 AM
Senior Member Group: Members Posts: 1,314 Joined: 27-January 05 From: Campbell, CA Member No.: 3,518 Region Association: Northern California |
I use the solid type spot weld cutters. These are much better and last much longer than the 'tiny hole saw type'. I got 5 for about $12 on ebay.
obscurity |
Apr 15 2010, 10:51 AM
I use the solid type spot weld cutters. These are much better and last much longer than the 'tiny hole saw type'. I got 5 for about $12 on ebay. The kind I have been using us the solid type. I have actually never seen the two piece version. I can't actually find them on Harbour freight but I will check e-bay. john |
Larouex |
Apr 15 2010, 11:01 AM
Larouex Group: Members Posts: 144 Joined: 22-July 08 From: Larouex@gmail.com Member No.: 9,339 Region Association: Pacific Northwest |
Everyone of those cheap, HF buys will leave you pissed off and unhappy with the cleanliness of the job. I tried them all and have done 100's of them with my Wurth bits. I recommend them highly.
Wurth Spot Weld Bit Cheers, Larouex |
rick 918-S |
Apr 15 2010, 11:04 AM
Hey nice rack! -Celette Group: Members Posts: 20,443 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I don't drill spot welds unless I absolutely have to. I grind them an slip a sharpened flat blade screw driver between the pieces and pop them. This wrecks the piece I am discarding and leaves the piece I want to clean up and save from being swiss cheesed full of holes from drilling too deep or making a bunch of thin spots that blow through when trying to reattach the new piece.
strawman |
Apr 15 2010, 11:05 AM
Senior Member Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
If you're going to be tossing the piece you're removing, just grind down the spot in the outer/upper metal piece and then use a cold chisel to knock it loose -- much faster than a spot weld cutter. I use a round-head bit in an air die grinder.
If you plan to re-use the piece you're removing, then using a good quality spot welder cutter is essential. I used to use the el cheapo Harbor Freight ones, but they seem to be made out of powdered iron and break at the most inopportune times. Regardless of the cutter you end up using, I'll echo the advice above about drilling a small pilot indentation and spinning the cutter at a relatively slow speed. Best of luck! |
SirAndy |
Apr 15 2010, 12:10 PM
Resident German Group: Admin Posts: 41,623 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The guys at the body shop have some special drill bits they use with a air-drill. Those last forever without going dull and the air-drill makes for very quick drilling.
I watched them remove whole panels in just minutes ... (IMG:style_emoticons/default/smash.gif) Andy PS: I have to ask what brand the drill bits are. I bet they are not cheap ... |
1968Cayman |
Apr 15 2010, 04:23 PM
Redacted by Irving Washington Group: Members Posts: 116 Joined: 5-February 10 From: Holly Springs, GA Member No.: 11,332 Region Association: South East States |
In the past I used a spot weld removal tool; if you're doing several cars or several panels that can become expensive.
Now I used DeWalt Pilot-Tip bits. They don't run like other bits and you can usually buy a complete set for $17- and use at least four of the bits to drill welds (all of the pilot-tipped ones if you don't mind the larger holes). |
roadster fan |
Apr 16 2010, 12:21 AM
Project Frankenstein !!!!!!!! Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
Just my .02 but I have drilled hundreds of spot welds with the smallest size of these (5/16" i think) from the set I have and it is as good as new. Cut steel like butter! Blair Rotabroach.
Jim |
Richard Casto |
Apr 16 2010, 11:11 AM
Blue Sky Motorsports, LLC Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
When drilling, I use a 3/8" Blair Rotabroach. If you do not use cutting oil they will dull within a handful of uses. But if you use cutting oil they last quite a long time.
As much as I love the Rotabroach, I also grind down the spot weld and pop apart and sometimes just drill straight through using a regular drill. It just depends upon the situation. |
Lo-Fi Version | Time is now: 6th May 2024 - 12:19 AM |
