Replacement key |
Replacement key |
Limesoda |
Apr 20 2010, 12:07 AM
Newbie Group: Members Posts: 22 Joined: 16-April 10 From: Portland, OR Member No.: 11,622 Region Association: Pacific Northwest |
Anyone know how to get a replacement ignition key? My mom lost both of hers... damn old age memory loss I guess. If not, is there a way to unlock the steering without a key? I can't get it on a trailer with the wheels locked... (IMG:style_emoticons/default/headbang.gif)
Chris |
smontanaro |
Apr 20 2010, 03:52 AM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
Can you get the front wheels onto some dollies then roll it onto the trailer that way?
Limesoda |
Apr 20 2010, 10:46 AM
Can you get the front wheels onto some dollies then roll it onto the trailer that way? Thanks for the reply. That's a good idea, unfortunately I don't think it would work because it is in gravel and the ramps to the trailer are not smooth... (IMG:style_emoticons/default/sad.gif) Chris |
Sleepin |
Apr 20 2010, 10:53 AM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
The quickest way Chris, would be to use an allen wrench to pull the four bolts under the column (that hold the column to the dash) and pull the steering shaft coupling near the footwell. This will enable you to kick-steer the tires.
If you are not in a hurry, you can pull the column and remove the tumbler and get it to a locksmith.....edit: If your mom is sure that the trunk key is the same as the ignition, you can pull the trunk lock out and take it to a locksmith....a lot easier than messing with the column, as you can remove the trunk lock in under 2 minutes. (IMG:style_emoticons/default/wink.gif) |
bandjoey |
Apr 20 2010, 10:54 AM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Door lock comes out easily and any good locksmith can make a new key. If the key numbers are in the owners manual a locksmith can code cut the key.
Limesoda |
Apr 20 2010, 11:42 AM
Door lock comes out easily and any good locksmith can make a new key. If the key numbers are in the owners manual a locksmith can code cut the key. Thanks guys! I called Porsche, they want $60 and 3 days to make a key (not as bad as I thought) of course, I don't know if the car has been re-keyed. I just called all of the locksmiths in the area of the town the car is in and they all go to the same dispatch who wants $120 to go out there to do the key. (IMG:style_emoticons/default/ar15.gif) Finally I got an actual shop that can do the key for $17 if I bring in the cylinder... (IMG:style_emoticons/default/smilie_pokal.gif) Geez-Louise! Chris |
Sleepin |
Apr 20 2010, 11:59 AM
QUOTE I got an actual shop that can do the key for $17 if I bring in the cylinder... (IMG:style_emoticons/default/smilie_pokal.gif) Geez-Louise! Chris That is your ticket. Now pull that trunk lock out! (IMG:style_emoticons/default/wink.gif) |
Limesoda |
Apr 23 2010, 11:47 PM
They lied... (IMG:style_emoticons/default/sad.gif) They said that they could cut the key if I brought in the tumbler but they actually need the code. I pulled the driver's door handle and lock and the trunk lock...no code (IMG:style_emoticons/default/headbang.gif) Anyone know where I can find the code to cut a new key? Why is this so hard?
Chris |
markb |
Apr 24 2010, 12:24 AM
You'll want to have a key made for the ignition, and if it's different than the others, you'll be doing this again, so go ahead & pull the ignition & have the key made from it. If you're lucky, it'll have the code on it. The locksmith I've used in the past didn't need the code, he'd look at the wafers & be able to do it by that.
Lo-Fi Version | Time is now: 15th May 2024 - 04:43 PM |
