Tube Frame, Crazy Idea |
Smitty911 |
Apr 20 2010, 12:03 PM
Member Group: Members Posts: 294 Joined: 19-March 08 From: La Mirada, Ca Member No.: 8,830 Region Association: Southern California |
I currently have a '74 2.0 that needs some body(rust) repair and got to thinking. I may spend alot of money on this repair. Which lead to the following.
How much would it cost to build a Tube Frame with un-equal length A-arms in front, 5 point rear end, buy fiberglass Fenders, hood and deck, seats, etc. etc. etc. and have a nice Track car. Something like the Factory Five Cobra. Use as much of an existing car or strong aftermarket parts to simplify the build and Voila, Good Track Car and OK Street car. Or Soften things up and have a Good Street Car and Adjust it back for the Track. I have no clue about designing a Car, but I can see we have loads of talent here and most of it has been done to one level or another. So just and intresting potential project. Smitty |
Rand |
Apr 20 2010, 03:00 PM
Smitty911 |
Apr 20 2010, 03:39 PM
Rand,
Thanks I read though his website the other day. Just not sure how much money it would take for the Frame (Roller). I also wasn't sure if someone was willing to share their design for someone else to duplicate. Thanks Smitty |
Brett W |
Apr 20 2010, 03:42 PM
Bring money and lots of it. The cost is high because of the design parameters. If you were talking about a front engined car like many race cars then it is easy but this is a one off special case kinda deal. That takes money.
Smitty911 |
Apr 20 2010, 05:55 PM
Well now I'm really intrested.
Around SoCal they can make a Sand Rail frame and suspension for under $10,000 for a roller add VW motor and tranny do some wiring and Viola Sand Car, less body panels. I saw one that was Mild Steel, you weld it around $2,500 at a Sand and Sport Show. Now that had Un-Equal A-Arms and VW Bug type rear. So I'm not an ME, but if you have a frame layout, add Pickups for Front and Rear Suspension points, all adjustable heims and rods, you should have a very adjustable setup just add motor and etc. etc. If you can get a Subi Turbo Motor for $2,000 Tranny for $1,000, rolling chassy for $10,000, shocks for $1,000, double to triple for etc. etc. etc. you should be able to have a Super Seven Type or Factory Five Type car for under $20,000. But I don't know, that's why I'm asking, how tough it is to do a frame with where to put the suspension points. All the rest can be laid outonce you have Frame. Smitty |
J P Stein |
Apr 20 2010, 07:24 PM
Byndbad (look on this forum) has built a tube framed 914 and is now refining it.
Take some of your time & ideas and search out his posts both here and on the 914 club. If you want things handed to you, this is as close as it gets . We get lots of "crazy ideas" here....most all never amount to more than just that. Ideas are free, building a car isn't. At worst you'll need a fully equipped shop, the necessary tools, the necessary skills, and a fist fulla money. If you're lacking those small items, a wheel barrow fulla money will do the trick. |
bam914 |
Apr 20 2010, 07:31 PM
Member Group: Members Posts: 334 Joined: 23-November 03 From: Atlanta, Ga Member No.: 1,378 Region Association: None |
Smitty911 |
Apr 20 2010, 08:37 PM
Byndbad (look on this forum) has built a tube framed 914 and is now refining it. Take some of your time & ideas and search out his posts both here and on the 914 club. If you want things handed to you, this is as close as it gets . We get lots of "crazy ideas" here....most all never amount to more than just that. Ideas are free, building a car isn't. At worst you'll need a fully equipped shop, the necessary tools, the necessary skills, and a fist fulla money. If you're lacking those small items, a wheel barrow fulla money will do the trick. Thanks Mr. Stein, I read one site were he is converting his front end to Un-Equal A-Arms. He had a Off Road shop do the 5 link rear end. I believe they are in Corona Ca. about 40 miles from me. I don't mind paying for peoples work, or sharing in the blood, sweet and tears helping other get their project going while I think about this. I have a copy of Alibre CAD so I should start drawing some ideas and see how they play out. Truck load of money would certainly help. LOL I have access to most the equipment to pull this off and several of the people I work with Fabric their own off road items. Fabing up some Shock hoops or Roll bars isn't exactly frame and suspension design. One makes off-road frames for himself and others. He races in SCORE desert but I'm not sure how much that relates to on road handling. Any suggestions for good books about design that I can pick up and start reading on? I don't need the PhD level, I'll pay someone for the actual review and modification suggestions. Thanks Smitty |
byndbad914 |
Apr 21 2010, 01:17 AM
shoehorn and some butter - it fits Group: Members Posts: 1,547 Joined: 23-January 06 From: Broomfield, CO Member No.: 5,463 Region Association: None |
AJ at The Baja Shop did mine. He is in Corona now. I won't say what I paid as it has been 3yrs since completion so costs likely changed and what you want will dictate actual pricing, so let him quote you. If you go dual A front and rear it will be more than I had with the struts I already owned at the time and making the 5 link. I am converting to SLA front and rear now - no fault of AJ necessarily, just me changing my mind now.
Price comparos, keep in mind it has to be all custom built to fit inside of the 914, not a jigged and copied sand rail (that is what gets costs down, repetition of the same design). Also mine was specific to using the V8, if you go with a 4 or 6 cyl the layout has to be different to cradle that. Mine comes out the top and the whole rear comes completely off. |
ArtechnikA |
Apr 21 2010, 05:16 AM
Around SoCal they can make a Sand Rail frame and suspension for under $10,000 for a roller... I haven't seen a sand rail since moving east. but I grew up in SoCal about a mile from Chenowth's shop. I've seen sand rails. My impression of sand rail frames is that they are designed for bending loads but are weak(er) in twist. Such a frame will be heavier than it needs to be for a road course and won't handle well. This can all be changed, of course, but now you're not looking at an off-the-shelf product any more. |
Smitty911 |
Apr 21 2010, 09:00 AM
AJ at The Baja Shop did mine. He is in Corona now. I won't say what I paid as it has been 3yrs since completion so costs likely changed and what you want will dictate actual pricing, so let him quote you. If you go dual A front and rear it will be more than I had with the struts I already owned at the time and making the 5 link. I am converting to SLA front and rear now - no fault of AJ necessarily, just me changing my mind now. Price comparos, keep in mind it has to be all custom built to fit inside of the 914, not a jigged and copied sand rail (that is what gets costs down, repetition of the same design). Also mine was specific to using the V8, if you go with a 4 or 6 cyl the layout has to be different to cradle that. Mine comes out the top and the whole rear comes completely off. Byndbad914, Thanks, reading your website started the Problem. I may have to give him a Call when I get back in Ca. I'm in Tupelo MS right now. One of the people I'm working with Races Dirt Ovel and had a catolog. Front end - Upper tube fully adjustable A-arm $125, tube lower arims $80, Shocks from $50 each to Coil overs complete $250, Than of course Ball Joints, Steering rack, Wilwood Brakes $125 per Caliper, Mustang II Spindles 2" Drop. looks like $2,000 for a complete adjustable Front end. I also saw in a Custom Street Rod ad, for a complete Chrome Mustang II front suspension for around $2,200. Is there something inherently wrong with using Mustang II set-up? Or Current Mustang parts, It sure would save some money using Commonly avalible parts. The Rear - Bearing Carrier, Bearings, heims, Shocks, and Brake system look to be about another $2,000. Frame - Chrome or Mild Steel? I know Chorme is more expensive, stronger and lighter, but cost is twice to three times as much, but would require heat Treating. Still kicking it around. Smitty |
Smitty911 |
Apr 21 2010, 09:15 AM
Around SoCal they can make a Sand Rail frame and suspension for under $10,000 for a roller... I haven't seen a sand rail since moving east. but I grew up in SoCal about a mile from Chenowth's shop. I've seen sand rails. My impression of sand rail frames is that they are designed for bending loads but are weak(er) in twist. Such a frame will be heavier than it needs to be for a road course and won't handle well. This can all be changed, of course, but now you're not looking at an off-the-shelf product any more. ArtechnikA, Thanks, I knew that they wouldn't work for street/track applications, but I was thinking about cost and material of just the Frame. Different application, lower CG, Shorter Wheel base, but some of that should be able to transfer. But I know what I don't know. |
byndbad914 |
Apr 21 2010, 11:50 AM
Nothing wrong with MII stuff. If I were going to do it from scratch, starting all over again, I would consider getting C5/C6 Corvette stuff and work from there. You will need to run big wheels to fit over it (18"... maybe 17" with C5 but I know 18" is minimum with C6 stuff) but you get wide tire variety/selection. Then just make custom axles in the rear to bolt up.
You could do MII front with Cobra rear uprights off the indep suspension cars and adapt the axles to those too. If you go with circle track stuff and just have AJ build you an upright for the rear you can do a lot of stuff, but you have to plan it well to make it all work together. Chromoly will save weight. AJ has, or at least had, a guy in LA that can heat treat vehicles and the price wasn't bad. Less than $1K IIRC and in the grand scheme of things, that is low $. That said, AJ is a phenomenal welder and has truggies/etc out there running for years jumping and racing without a crack and no heat treat - the key is having a guy that knows his sh!t weld the thing together. |
Apr 21 2010, 12:01 PM
Resident German Group: Admin Posts: 41,609 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
So just and intresting potential project. Here's a old thread with a bunch of pictures ... http://www.914world.com/bbs2/index.php?showtopic=23020 Scott Yeahman's silver car started it's life on a jig, the 914 components were added later. Roger Sheridan's car used to be a 914. (IMG:style_emoticons/default/driving.gif) Andy |
Smitty911 |
Apr 21 2010, 01:51 PM
So just and intresting potential project. Here's a old thread with a bunch of pictures ... http://www.914world.com/bbs2/index.php?showtopic=23020 Scott Yeahman's silver car started it's life on a jig, the 914 components were added later. Roger Sheridan's car used to be a 914. (IMG:style_emoticons/default/driving.gif) Andy SirAndy, Thanks for those links. There is some impressive skills and thought in those various designs. Looks like I have some serious homework to get done. |
Brett W |
Apr 22 2010, 10:24 AM
Sheridans car was never a 914. He started with a pile of tubes. Everything on it is custom. He car was built to the mid 90s SCCA GT2 rules.
If you are building a tube chassis car, I would start with Corvette suspension. It is bullet proof and easy to come by. PLus there are plenty of aftermarket parts for them. |
Apr 22 2010, 10:39 AM
Sheridans car was never a 914. He started with a pile of tubes. Everything on it is custom. He car was built to the mid 90s SCCA GT2 rules. Funny, he told me that he used a 914 to build his car. Either way, there is some 914 sheet-metal left on it ... (IMG:style_emoticons/default/shades.gif) Andy |
byndbad914 |
Apr 22 2010, 10:55 AM
IIRC Roger's car has a stock 914 windshield frame and cowl and that was it. Cool car and Roger is a damn nice guy - recommend his body kits if you are going to go to all the trouble of a tube chassis.
Smitty911 |
Apr 22 2010, 12:59 PM
IIRC Roger's car has a stock 914 windshield frame and cowl and that was it. Cool car and Roger is a damn nice guy - recommend his body kits if you are going to go to all the trouble of a tube chassis. I've looked at his website. That may be the best way to go to handle the body work. On the Plus side, I may have found an ME to look at my drawings, not a racer, but he should be able to figure out a few things. I'm attempting to learn all the Terminology. Roll Center - Is that the axis front to back, where the body flexes or the suspension reacts?? Scrub - I read in byndbad914 front end thread about setting or having enough to get the tires warm. I'm guessing it's not the same as Toe ??? |
Smitty911 |
Apr 22 2010, 01:24 PM
Sheridans car was never a 914. He started with a pile of tubes. Everything on it is custom. He car was built to the mid 90s SCCA GT2 rules. If you are building a tube chassis car, I would start with Corvette suspension. It is bullet proof and easy to come by. PLus there are plenty of aftermarket parts for them. Good idea, but if I use Corvette Brakes, aren't they a bit large for a car that should weigh less than 2000 pounds? Can you have to much braking power? I've been looking for sources for the Aftermarket parts, seems they mostly deal in Engine not suspension parts. |
Lo-Fi Version | Time is now: 2nd May 2024 - 12:38 PM |
