Engine is in cranks good, no start |
jsayre914 |
Apr 22 2010, 10:21 AM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
i finished up the engine, lookin good, was up till after 1am so not a lot of time to trouble shoot. Symptoms include...
NO FUEL the fuel pump was just replaced and a few fuel lines were changed. the pump is running strong but there is no fuel anywhere. fuel pressure guage dosnt even bump or twitch so i nheed to check tonight fuel, is there any in the tank any lines kinked or pinched clogged fuel filtre anything eles to check?? car has been sitting ass up with no motor for about 2 months. fuel lines were plugged with a bolt. joe |
dr914@autoatlanta.com |
Apr 22 2010, 12:00 PM
914 Guru Group: Members Posts: 7,858 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
FRom what you said, maybe the lines are misrouted. Make sure first that the delivery line when disconnected at the rear POURS fuel. If not there is the problem. Next check the routing D R S d for deliver to the right pass injector rail, s for suck from the main larger line through the tunnel and through the fuel filter, and R for the return from the fuel pressure regulator and the smaller return line through the tunnel both connected to that nipple via a thee way connector
i finished up the engine, lookin good, was up till after 1am so not a lot of time to trouble shoot. Symptoms include... NO FUEL the fuel pump was just replaced and a few fuel lines were changed. the pump is running strong but there is no fuel anywhere. fuel pressure guage dosnt even bump or twitch so i nheed to check tonight fuel, is there any in the tank any lines kinked or pinched clogged fuel filtre anything eles to check?? car has been sitting ass up with no motor for about 2 months. fuel lines were plugged with a bolt. joe |
VaccaRabite |
Apr 22 2010, 12:47 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
You at work or at home today?
1) Is there gas in the tank? Put in some fresh gas when you get home. A good 5 gallons. 2) make sure your lines are routed right (as George said) Are you pumping anything? I know you have a fuel pressure meter in the line, is it going anywhere? If you have gas in the tank replace the filters. If you hear the pump running, the lines are run right, and the filter is not clogged, then you should have fuel pressure. Oh. One more thing. When you were running the pump, did you get a strong gas smell and notice a big puddle forming? Zach |
jsayre914 |
Apr 22 2010, 04:02 PM
You at work or at home today? 1) Is there gas in the tank? Put in some fresh gas when you get home. A good 5 gallons. 2) make sure your lines are routed right (as George said) Are you pumping anything? I know you have a fuel pressure meter in the line, is it going anywhere? If you have gas in the tank replace the filters. If you hear the pump running, the lines are run right, and the filter is not clogged, then you should have fuel pressure. Oh. One more thing. When you were running the pump, did you get a strong gas smell and notice a big puddle forming? Zach I am at work all day.... the anticipation is killing me. if i had 30 min this morning i might be driving already (IMG:style_emoticons/default/wacko.gif) i will add fuel when i get home and check the routing of the lines. then i will .. drive really really fast (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 10:27 AM |
