a Duh moment, idle changing |
underthetire |
Apr 24 2010, 01:37 PM
Although my idle is very smooth, using MS and a compu-fire, it would change by 100rpm or so, not bouncy, just change. After fixing my clutch tube, and patching the hole, I accidentally melted the plastic around the throttle cable. Now, the old throttle cable never gave me any problems, and it "seemed" ok, but after getting the new one in, I noticed dead accurate idle. Looking at the old cable a little closer, the plastic liner had some wear marks on it, but was also really stiff. So , if your gonna fix your clutch tube, remove both cables (IMG:style_emoticons/default/biggrin.gif) ,or chasing a idle problem replace the throttle cable.
Lennies914 |
Apr 24 2010, 07:14 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
Although my idle is very smooth, using MS and a compu-fire, it would change by 100rpm or so, not bouncy, just change. After fixing my clutch tube, and patching the hole, I accidentally melted the plastic around the throttle cable. Now, the old throttle cable never gave me any problems, and it "seemed" ok, but after getting the new one in, I noticed dead accurate idle. Looking at the old cable a little closer, the plastic liner had some wear marks on it, but was also really stiff. So , if your gonna fix your clutch tube, remove both cables (IMG:style_emoticons/default/biggrin.gif) ,or chasing a idle problem replace the throttle cable. Are you doing all this in preperation for a little trip to Tahoe? |
Lo-Fi Version | Time is now: 28th May 2024 - 11:55 PM |
