Why is my car getting power?, In neutral and back wheel spins... |
amphiduck |
Apr 24 2010, 02:37 PM
Member Group: Members Posts: 94 Joined: 29-September 06 From: Tennessee Member No.: 6,947 |
So today, I finally got my 74 2.0 running with a new fuel pump after sitting for probably about 8 months. The car has one weber two barrel and the new fuel pump pushes about 3 psi. I also recently put in new rear bearings, brake calipers & rotors, and today when the car started in neutral I saw that the back left wheel was spinning (still on the jack stand with no tire). It took all of touching the rotor to make it stop, so I assume with a tire on the ground, it wouldn't spin at all.
I know that before I parked the car last fall, I had to be extra careful in shifting gears because the entire car would shudder if I tried to shift quicker than I typically do. In this case I'm pretty sure I need a new clutch/pressure plate, but will that fix the wheel spin if it is abnormal? Could the clutch have some how froze to the flywheel after sitting for some time giving the back wheels power? This car is a daily driver, nothing fancy. Just getting closer and closer to summer and I'm ready for this thing to be on the road... |
dr914@autoatlanta.com |
Apr 24 2010, 02:44 PM
914 Guru Group: Members Posts: 7,858 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
typical they all do it. The jitter means a warped clutch disc
So today, I finally got my 74 2.0 running with a new fuel pump after sitting for probably about 8 months. The car has one weber two barrel and the new fuel pump pushes about 3 psi. I also recently put in new rear bearings, brake calipers & rotors, and today when the car started in neutral I saw that the back left wheel was spinning (still on the jack stand with no tire). It took all of touching the rotor to make it stop, so I assume with a tire on the ground, it wouldn't spin at all. I know that before I parked the car last fall, I had to be extra careful in shifting gears because the entire car would shudder if I tried to shift quicker than I typically do. In this case I'm pretty sure I need a new clutch/pressure plate, but will that fix the wheel spin if it is abnormal? Could the clutch have some how froze to the flywheel after sitting for some time giving the back wheels power? This car is a daily driver, nothing fancy. Just getting closer and closer to summer and I'm ready for this thing to be on the road... |
McMark |
Apr 24 2010, 02:50 PM
Normal. Some excessively slight amount of power gets transferred because of friction.
amphiduck |
Apr 24 2010, 09:06 PM
Much appreciated, thanks for the info!
Lo-Fi Version | Time is now: 16th May 2024 - 11:25 AM |
