> Just got a set of 1970 rear hubs, have you seen one with this??
East coaster
post Apr 1 2004, 05:59 PM
I just received these hubs that I bought off ebay(from someone on this board to remain nameless for now) and there appears to be a substantial wear area on one of the bearing surfaces. I can't believe this would be a "normal" thing, has anyone seen one like this?? The worn area is .020 smaller in diameter than the non worn area. The add stated they were in "LIKE NEW condition".??? It's actually kinda strange cause if it spun a bearing I would think the wear area would be the width of a bearing race. It almost looks like someone machined it to hide damage,
I believe these are unusable, unless someone can convince me otherwise. (IMG:style_emoticons/default/confused24.gif)
Attached File(s)
East coaster
post Apr 1 2004, 06:00 PM
Here's the diameter of the non-worn area.........
Attached File(s)
East coaster
post Apr 1 2004, 06:02 PM
here's the diameter of the worn area........
Attached File(s)
anthony
post Apr 1 2004, 06:09 PM
2270 club
I don't think what you are measuring there is a bearing surface. The rear cartridge bearing slides on there but the bearings ride on the race that's included with the bearing.
ChrisFoley
post Apr 1 2004, 06:17 PM
I am Tangerine Racing
QUOTE(East coaster @ Apr 1 2004, 06:59 PM)
That means there's no surface rust! (after sandblasting them) (IMG:style_emoticons/default/blink.gif)
Actually I don't think there's anything wrong with the groove being there, as long as the hub slides into the bearing with a little resistance. Any machining to that surface will render them totally unusable and you will know it right away during installation.
echocanyons
post Apr 1 2004, 06:21 PM
As long as they go on there tight and are a royal pain in the butt to get on like normal I dont think that they would be a problem.
The only way that they would be a problem is if the inner bearing race didnt fit tight and they were able to slip when the bearing inside is rotating.
TimT
post Apr 1 2004, 06:29 PM
retired
Ill have to go dig out a pair of stub axles... but from what I see dont worry about it..
J P Stein
post Apr 1 2004, 06:31 PM
Irrelevant old fart
Is that a step or a groove?
If it's a step....half the seating surface is .02 smaller that the other half, they are toast.
If it is a .05/08 or so wide groove....as it appears in the top pic, they'll work.
garyh
post Apr 1 2004, 06:33 PM
That groove lines up with where the inner race is split.
How it got there is a mystery. But like others, I wouldn't worry about it.
Do check for cracks on the tip. Little hairline cracks show up there, and make it useless.
Also verify that they are a -snug- fit with new bearings. If they were blasted, and -any- metal was taken off from there, they're toast.
Unfortunately, all real testing requires the axle nut to be torqued.
G.
East coaster
post Apr 1 2004, 06:53 PM
Sorry, Maybe I should've explained it better. What you see in the first pic is not a groove, but a ridge where from that ridge to the base of the hub it is .020 smaller in diameter than the other half of the bearing surface. With this, I would think that the bearings inner race would be swingin' in the breeze for 1/2 the width of the bearing?? It almost looks like someone turned it down in a lathe, I think they're junk!
seanery
post Apr 1 2004, 06:55 PM
waiting to rebuild whitey!
can they be tig'd and machined?
415PB
Yep, I agree. See if they will take them back......
ChrisFoley
post Apr 1 2004, 07:03 PM
I thought it was just a groove. If the inner half of the bearing surface is as you say, then it is useless and I suggest you expose the perp here and now so we can stone him.
There is no excuse for such false advertising.
(IMG:style_emoticons/default/chair.gif)
East coaster
post Apr 1 2004, 07:09 PM
I think it's only fair to let them make good on this before I flame them on the board. I'm really surprised by this, they seemed reputable. I'll report back here after giving them the opportunity to fix this......stay tuned!
ChrisFoley
post Apr 1 2004, 07:15 PM
QUOTE(East coaster @ Apr 1 2004, 08:09 PM)
E-mail him the link to this thread and give him a deadline to respond publicly.
"Like new condition" my ass!
415PB
post Apr 1 2004, 09:54 PM
If it's the vendor I think, because I was going to bid on these hubs, I am sure they will make good on the deal. If they dont then they can (IMG:style_emoticons/default/pissoff.gif)
Rich Bontempi
post Apr 1 2004, 10:15 PM
914 Road Racer
That hub, should not be used, get a good one!
East coaster
post Apr 2 2004, 10:11 AM
Ok.....so now I need another set of 1970 914 hubs. Does anybody have a set of the early hubs with both the 4 and 5 lug bosses available. I had a set of 914-6 stubs and was going to use 911 hubs, but I sold my damn stubs when I bought these, so now I'm stuck looking for another set of 1970 914 hubs! Anybody got a set available???
BTW - The seller has contacted me and is willing to accept the return of the hubs. I'll accept that the seller didn't realize the condition and didn't mean to misrepresent the item. This was resolved quickly and I would do business with them again! No need for any flames! (IMG:style_emoticons/default/blowtorch.gif)
ss6
post Apr 2 2004, 10:31 AM
fun city...
Sounds like you've been around the block a few times on your 5 lug conversion attempts. FYI, you can have plain vanilla 4 lug hubs drilled and studded for 5; I've been running a set of these for a couple years now through multiple DE's / AX's with no trouble. I had Patrick Motorsports do the mod, though any 914 savvy machine shop can do it; both Patrick and the related PP tech article say they're strong enough.
If you wind up with a set of 914-6 stubs again, I have a set of early 911 hubs available.
GaroldShaffer
post Apr 2 2004, 10:40 AM
You bought another 914?
how soon do you need them? I have a 1970 parts car in the driveway but I won't be able to get in the garage for 3 weeks or so.
- Garold
- Lo-Fi Version Time is now: 30th July 2025 - 06:37 PM
