ELECTRICAL ISSUE, Batter drain. |
oz371 |
Apr 25 2010, 02:14 PM
Member Group: Members Posts: 101 Joined: 28-August 09 From: ontario, CA Member No.: 10,739 Region Association: None |
Hello all,
Met a few of you at the G&R swap and heard some ideas on my current issue. Heres the deal.. (IMG:style_emoticons/default/blink.gif) New battery. draining down to nothing within a matter of hours. Checked the motors i.e. headlights, blower motor, lights are off, even pulled the stereo. With the car off I hear nothing. (IMG:style_emoticons/default/confused24.gif) Any ideas? Thanks for the help my freinds. (IMG:style_emoticons/default/pray.gif) |
silver74insocal |
Apr 25 2010, 02:28 PM
Senior Member Group: Members Posts: 736 Joined: 26-November 09 From: rancho cucamonga Member No.: 11,073 Region Association: Southern California |
do you have access to an amp meter? and when you say you "checked" the motors what did you do? i am a newbie so i cant offer any guru advice, but i am a low voltage electrician so can help you with process of elimination. i believe i met you todaay, i was commenting on your pull out tape deck(?) lmk, Dave (IMG:style_emoticons/default/beerchug.gif)
gopack |
Apr 25 2010, 02:37 PM
CHEESEHEAD in CA, MARK Group: Members Posts: 744 Joined: 7-August 04 From: Folsom, CA Member No.: 2,472 Region Association: Northern California |
Damn! if all the batter drains, you can't have any pancakes. How can you have any pancakes, if you let the batter drain? (IMG:style_emoticons/default/poke.gif)
Seriously, Maybe a short in an energized circuit? |
oz371 |
Apr 25 2010, 02:40 PM
do you have access to an amp meter? and when you say you "checked" the motors what did you do? i am a newbie so i cant offer any guru advice, but i am a low voltage electrician so can help you with process of elimination. i believe i met you todaay, i was commenting on your pull out tape deck(?) lmk, Dave (IMG:style_emoticons/default/beerchug.gif) Yeah I remember. Nice to meet you by the way. I just check to see if there were any motors running. Ron check the headlight motors and they are fine. Headlights are turning off. I did pull the radio because I know it is hooked up constant. I can get an amp meter I just need a lil instruction on what to look for. |
TravisG |
Apr 25 2010, 02:43 PM
Member Group: Members Posts: 71 Joined: 8-June 09 From: Supply, NC Member No.: 10,449 Region Association: MidAtlantic Region |
Did this happen with the old battery? If not, could be a defective battery.
I replaced a perfectly good starter before because I had a "NEW" bad battery (IMG:style_emoticons/default/headbang.gif) Just a thought Travis |
oz371 |
Apr 25 2010, 02:49 PM
Did this happen with the old battery? If not, could be a defective battery. I replaced a perfectly good starter before because I had a "NEW" bad battery (IMG:style_emoticons/default/headbang.gif) Just a thought Travis The old battery was shot. Put the new one in about a month ago. The problem started last week. |
oz371 |
Apr 25 2010, 02:53 PM
Damn! if all the batter drains, you can't have any pancakes. How can you have any pancakes, if you let the batter drain? (IMG:style_emoticons/default/poke.gif) Seriously, Maybe a short in an energized circuit? So now I need to post a topic asking how to edit topic posts. (IMG:style_emoticons/default/idea.gif) |
TravisG |
Apr 25 2010, 02:55 PM
The old battery was shot. Put the new one in about a month ago. The problem started last week. [/quote] The problem I had started about 6 weeks after I put in a top of the line battery. If you have another battery, switch it out, or go to an Advance Autoparts or the like and have them test the battery. It could have a bad cell that is draining the battery. It is an easy test and it would at least rule out the battery. Good luck, Travis |
oz371 |
Apr 25 2010, 03:01 PM
[quote name='TravisG' date='Apr 25 2010, 01:55 PM' post='1309040']
The old battery was shot. Put the new one in about a month ago. The problem started last week. [/quote] The problem I had started about 6 weeks after I put in a top of the line battery. If you have another battery, switch it out, or go to an Advance Autoparts or the like and have them test the battery. It could have a bad cell that is draining the battery. It is an easy test and it would at least rule out the battery. Good luck, Travis [/quote] Will do! Thanks Travis. (IMG:style_emoticons/default/beerchug.gif) |
Krank |
Member Group: Members Posts: 140 Joined: 11-October 09 From: Winnipeg, MB Member No.: 10,922 Region Association: Canada |
If the battery checks out, you could take out the fuses a couple at a time. There are some relays that could be stuck and draining down the electrical system. If you have access to a multimeter with a 10 amp ammeter, you could maybe try touching the leads across the fuse contacts to see if there is any current drain and find out at least what circuit it is.
silver74insocal |
Apr 25 2010, 03:02 PM
Did this happen with the old battery? If not, could be a defective battery. I replaced a perfectly good starter before because I had a "NEW" bad battery (IMG:style_emoticons/default/headbang.gif) Just a thought Travis (IMG:style_emoticons/default/agree.gif) it may be worth taking back to them and having them load test it before you start chasing gremlins in the car, but make sure they load test it which they probably do anyways if you tell them whats happening. the amp meter would be a good starting point for process of elimnation. just put it between (or if its a clamp style clamp it over) the postive battery terminal and the positve battery cable. this will display the amount of current going through the circuit which (with the car turned off ) should be next to nothing. if you see a reading, start unplugging stuff until it goes away. its not that simple, but you get what i am saying right? lmk what you find, i can prolly give you a hand if need be neighbor. (IMG:style_emoticons/default/bye1.gif) Dave |
SUNAB914 |
Apr 25 2010, 04:34 PM
Senior Member Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
What else have you worked on that might be the cause of this problem? Bulbs? anything that might have started this besides replacing battery?
904svo |
Apr 25 2010, 06:16 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
The easily way to find out if you have a battery drain is to remove the plus terminal off the battery and connect a 12 volt light bulb in nseries with the
plus terminal. If the bulb glows there is a drain on the battery, remove the fuses one at a time and find out which circuit is causing the drain. If it don't glow you have a bad battery or a dead battery. PS the gen light should light when you turn on the key, if it don't replace the bulb your battery won't charge with a burn out bulb. my $.02 |
Mike Bellis |
Apr 25 2010, 07:00 PM
Have the battery tested. To kill a battery in a few hours would take a serious load not just stoped car trickle. Do you have a trolling motor hooked to it? (IMG:style_emoticons/default/poke.gif)
Normal drain on a battery with the key turned off should be less than 0.5 Amps. This would include a clock, radio and ECU. |
sean_v8_914 |
Apr 25 2010, 07:27 PM
did you and Ron test voltage at batt when running?
turn everything off remove teh batt neg tap it onto post gently... big spark or little spark? place amp meter between neg and batt neg terminal. as stated should be less thsan 1/2 amp im sorry I walked away, I know I could have fixed it pm me , Ill talk ya thru it |
Krank |
Apr 25 2010, 08:31 PM
Just don't try to see if there is an arc when the car is running or you will blow the diodes in the alternator. |
SLITS |
Apr 25 2010, 09:37 PM
did you and Ron test voltage at batt when running? turn everything off remove teh batt neg tap it onto post gently... big spark or little spark? place amp meter between neg and batt neg terminal. as stated should be less thsan 1/2 amp im sorry I walked away, I know I could have fixed it pm me , Ill talk ya thru it Battery was showing 13.56 volts @ idle. |
oz371 |
Apr 26 2010, 01:30 AM
When I got home from the Swap I parked it pulled the old radio and the in line fuse for it. The car has been sitting for 10 hours and cranked fine. (IMG:style_emoticons/default/beerchug.gif) Problem solved?? (IMG:style_emoticons/default/confused24.gif) We will see, I will test again in the morning.
Thanks for the input. (IMG:style_emoticons/default/bye1.gif) |
oldschool |
Apr 26 2010, 01:47 AM
Advanced Member Group: Members Posts: 3,362 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
did you and Ron test voltage at batt when running? turn everything off remove teh batt neg tap it onto post gently... big spark or little spark? place amp meter between neg and batt neg terminal. as stated should be less thsan 1/2 amp im sorry I walked away, I know I could have fixed it pm me , Ill talk ya thru it So Sean with the car running what should i get on my meter? and whats a good setting? on the meter? |
charliew |
Apr 26 2010, 08:44 AM
I'm not Sean but with the motor running a volt meter should say over 14 volts on my cars
Lo-Fi Version | Time is now: 16th May 2024 - 05:04 PM |
