How can I safely remove my rear view mirror?, Don't want to damage the windshield, any tips?? |
nsr-jamie |
Apr 26 2010, 08:32 AM
914 guy in Japan Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
Hi, my rear view mirror is cracked and damaged beyond repair and I have a nice spare one I got from Bruce (thanks!!) I have the adhesive sticker and am ready to install the mirror, but before I do anything I would like to ask for some advice from you people on how can I remove the old mirror without damaging the nice somewhat fresh front windshield I have on now? I did a search but am not coming up with anything...would a hair dryer work? Sorry if this is a dumb question, I thought I would ask here first before trying anything...thanks and cheers (IMG:style_emoticons/default/beerchug.gif)
charliew |
Apr 26 2010, 08:53 AM
I have just pulled them off but If it was me I would call a auto glass shop you might be familiar with if someone here doesn't respond pretty soon. I probably would still call my favorite glass shop to compare replys anyway. I think I remember using some laquer thinner on one to get it softened up before I pulled it off. I know thats what I used to clean the residue up.
jeffdon |
Apr 26 2010, 08:57 AM
Hi, my rear view mirror is cracked and damaged beyond repair and I have a nice spare one I got from Bruce (thanks!!) I have the adhesive sticker and am ready to install the mirror, but before I do anything I would like to ask for some advice from you people on how can I remove the old mirror without damaging the nice somewhat fresh front windshield I have on now? I did a search but am not coming up with anything...would a hair dryer work? Sorry if this is a dumb question, I thought I would ask here first before trying anything...thanks and cheers (IMG:style_emoticons/default/beerchug.gif) You have one that sticks? Whats that like? |
jaxdream |
Apr 26 2010, 09:04 AM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
You don't really have to take the windshield mount off to change the mirror , there is a small screw that holds the mirror to the windshield mount , it is inside of the "stem " that the mirror is attached to .The screw head is slotted , use a very good small slotted screw driver , work with it for a bit or it may come right on out. You might apply a little heat ( not a lot so as to not melt anything ) which will aid in the removal of the screw , it is long but very small diameter . Good luck , maybe give it shot before trying to unglue the windshield mount.
Jack / Jaxdream |
turboman808 |
Apr 26 2010, 09:16 AM
Advanced Member Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
I was having a heck of a time trying to get a mirror off of a parts car. Then I took the heat gun to it. Thing popped right off.
EdwardBlume |
Apr 26 2010, 01:41 PM
RJMII |
Apr 26 2010, 02:48 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
You don't really have to take the windshield mount off to change the mirror , there is a small screw that holds the mirror to the windshield mount , it is inside of the "stem " that the mirror is attached to .The screw head is slotted , use a very good small slotted screw driver , work with it for a bit or it may come right on out. You might apply a little heat ( not a lot so as to not melt anything ) which will aid in the removal of the screw , it is long but very small diameter . Good luck , maybe give it shot before trying to unglue the windshield mount. Jack / Jaxdream (IMG:style_emoticons/default/agree.gif) And about the time you get the replacement one just about tightened, the old windsheild mount should fall off easily into your hand, replacement mirror and all. |
nsr-jamie |
Apr 27 2010, 05:07 AM
Thanks, I will try to unscrew the mount, I didn't even notice that, thanks!! I actually installed the mirror last year or so and yes it sticks well to the glass for the time being. I bought the adhesive sticker at HPH and it works well but unfortunately the mirror cracked and needs replacement and I have a spare here so thought to do it myself.
Thanks, my car needs a lot of work but slowly it is coming along. Cheers!! (IMG:style_emoticons/default/beerchug.gif) |
hcdmueller |
Apr 27 2010, 05:45 AM
????????????? Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England |
I glued my mirror on with some aircraft grade epoxy that we have at work. I was on my way to get the car inspected for registration and the mirror fell off in my hand. I didn't think about removal at the time. When the time comes hopefully it will come off with heat because it isn't coming off any other way.
Lo-Fi Version | Time is now: 16th May 2024 - 04:11 PM |
