QUOTE(jaxdream @ Apr 26 2010, 09:04 AM)
You don't really have to take the windshield mount off to change the mirror , there is a small screw that holds the mirror to the windshield mount , it is inside of the "stem " that the mirror is attached to .The screw head is slotted , use a very good small slotted screw driver , work with it for a bit or it may come right on out. You might apply a little heat ( not a lot so as to not melt anything ) which will aid in the removal of the screw , it is long but very small diameter . Good luck , maybe give it shot before trying to unglue the windshield mount.
Jack / Jaxdream
And about the time you get the replacement one just about tightened, the old windsheild mount should fall off easily into your hand, replacement mirror and all.
