Sealant on lower heads nuts/washers? |
Cevan |
Apr 26 2010, 01:31 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
Is there any sealant used on the washers and/or nuts that go on the lower head studs to prevent leakage? As I type this in my office, I can't recall if that is covered in Jake's video. I have Curil T and Curil K2 sealants.
Jake Raby |
Apr 26 2010, 01:36 PM
Use Curil T in this location.
KaptKaos |
Apr 26 2010, 03:24 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
What are lower head nuts?
Should I be using this on my cylinder to case mating point? |
Cevan |
Apr 26 2010, 03:42 PM
Thanks.
The lower head nuts are the nuts that secure the head to the case, the lower ones being the four that are under the valve cover. |
KaptKaos |
Apr 26 2010, 04:19 PM
Fair enough. Do you use the curil on the upper, exposed ones too?
Lo-Fi Version | Time is now: 15th May 2024 - 09:07 AM |
