Cevan
Apr 26 2010, 01:31 PM
Is there any sealant used on the washers and/or nuts that go on the lower head studs to prevent leakage? As I type this in my office, I can't recall if that is covered in Jake's video. I have Curil T and Curil K2 sealants.
Jake Raby
Apr 26 2010, 01:36 PM
Use Curil T in this location.
KaptKaos
Apr 26 2010, 03:24 PM
What are lower head nuts?
Should I be using this on my cylinder to case mating point?
Cevan
Apr 26 2010, 03:42 PM
Thanks.
The lower head nuts are the nuts that secure the head to the case, the lower ones being the four that are under the valve cover.
KaptKaos
Apr 26 2010, 04:19 PM
Fair enough. Do you use the curil on the upper, exposed ones too?
