One more new item -Actually a few, Delrin roller and bushing for clutch cable $14.50 / $4 |
Mikey914 |
Apr 26 2010, 08:32 PM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I was replacing my clutch cable pulley as it was brittle and the edge broke out. So I decided to do up a few of these. This is a machined Delrin pulley that will replace the OEM. It will have less flex that the OEM. It is also much more sturdy. I'm also making the bushing that goes in the center as I went to buy a new one to make sure it was within tolerance for the bushing, and guess what NLA. They are not a standard size pipe that you could just cut and use, so I decided to machine down a few to make these available in stainless. If you want a spare in case you loose one now is a good time as they're cheaper than OEM were.
Thought I'd introduce these as there were a few other parts that were coming out that I could combine shipping on. I will have the heater knobs in 2 days, and the scissor window roller bushings. I will start threads on these as soon as I get them done. Sign up here for the clutch cable pulley or just the bushing. Shipping will be flay rate envelope at $5 Attached thumbnail(s) |
Gint |
Apr 26 2010, 09:37 PM
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Yes please. Two of each in fact.
Kansas 914 |
Apr 28 2010, 12:48 PM
I was replacing my clutch cable pulley as it was brittle and the edge broke out. So I decided to do up a few of these. This is a machined Delrin pulley that will replace the OEM. It will have less flex that the OEM. It is also much more sturdy. I'm also making the bushing that goes in the center as I went to buy a new one to make sure it was within tolerance for the bushing, and guess what NLA. They are not a standard size pipe that you could just cut and use, so I decided to machine down a few to make these available in stainless. If you want a spare in case you loose one now is a good time as they're cheaper than OEM were. Thought I'd introduce these as there were a few other parts that were coming out that I could combine shipping on. I will have the heater knobs in 2 days, and the scissor window roller bushings. I will start threads on these as soon as I get them done. Sign up here for the clutch cable pulley or just the bushing. Shipping will be flay rate envelope at $5 Yep - I'm in for the pulley/bushing set. Don't ship yet as I will want more stuff. |
kharma |
Apr 28 2010, 12:58 PM
Member Group: Members Posts: 68 Joined: 13-November 07 From: Billerica MA Member No.: 8,328 Region Association: North East States |
Count me in for one pulley + bushing set. I'd also like to hold off on shipment while I consider adding some other items, let me know if you'd like initial payment though.
-Jim |
7275914911 |
Apr 28 2010, 01:04 PM
Hummmm!!! Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States |
1 pulley and bushing for me....
Geezer914 |
Apr 28 2010, 01:11 PM
Geezer914 Group: Members Posts: 1,412 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
I'll take one.
kconway |
Apr 28 2010, 01:27 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
If there are any left, I'll take a pulley and bushing.
Kev |
maf914 |
Apr 28 2010, 02:48 PM
Mark,
I will take a pulley and bushing set. I just ordered a main targa seal from you and would like to add these to that order if possible. Please send a PM if this is okay. Thanks. |
zymurgist |
Apr 28 2010, 02:51 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
blitZ |
Apr 28 2010, 03:10 PM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I'll take a pulley and a bushing.
Eric_Shea |
Apr 28 2010, 03:13 PM
Throw them in the box marked "Eric"
veltror |
Apr 28 2010, 04:33 PM
Senior Member Group: Members Posts: 928 Joined: 27-April 08 From: Potters Bar Herts UK Member No.: 8,978 Region Association: None |
i ll take one, I will need some parts soon so a combined ship will be good. I hope you have told Mittelmotor about your new parts!!!
9146FAN |
Apr 28 2010, 09:40 PM
Member Group: Members Posts: 294 Joined: 20-July 04 From: ROSSMOOR, CA Member No.: 2,378 |
I'll buy one pulley and one bushing. Let me know payment details. Thanks.
bigkensteele |
Apr 28 2010, 10:38 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
One of each, please...
Have you thought about making the pulley for the thermostat cable that controls the engine tin flaps? I have one that is busted on my 2.0, and I keep forgetting to check to see if it is available, since that motor has been on a stand for nearly 10 years. Thanks again for all of your great parts! |
BigDBass |
Apr 28 2010, 10:45 PM
Dumb Question Champion Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
One pulley, one bushing for me too.
Someone should help Mark help us by making an FAQ/catalog. I'm sure I should be buying a whole set of all Mikey914 pieces, but I don't know what half the stuff is or which pieces (seals) can be done easily at leisure versus when the car is stripped or being painted or "while you're in there". |
sgetsiv |
Apr 28 2010, 10:59 PM
Former 914 Owner :( Group: Members Posts: 159 Joined: 20-June 08 From: Portland, OR Member No.: 9,192 Region Association: Pacific Northwest |
I would like one pulley and one bushing as well.
I can come by to pick up. Thanks, Steve Getsiv |
Mikey914 |
Apr 29 2010, 02:09 AM
One pulley, one bushing for me too. Someone should help Mark help us by making an FAQ/catalog. I'm sure I should be buying a whole set of all Mikey914 pieces, but I don't know what half the stuff is or which pieces (seals) can be done easily at leisure versus when the car is stripped or being painted or "while you're in there". When I get caught up on my projects I'm planning to redo the website, and utilize a format that will recommend groupings that can be done at the same time. I just need to organize a little better to lay it out in a more intuitive format. Any help would be appreciated. Thanks, Mark |
zx-niner |
Apr 29 2010, 06:35 AM
Member Group: Members Posts: 294 Joined: 13-June 05 From: Las Vegas, NV Member No.: 4,269 Region Association: Central California |
One pulley and one bushing for me, please!
flat4tom |
Apr 29 2010, 12:51 PM
Member Group: Members Posts: 51 Joined: 6-January 10 From: Shingletown CA Member No.: 11,207 Region Association: Northern California |
One pulley and bushing for me as well please. I think I can swing that! (IMG:style_emoticons/default/biggrin.gif)
Thanks Tom |
michaelmoo |
Apr 29 2010, 01:02 PM
Member Group: Members Posts: 312 Joined: 21-May 04 From: Kennesaw, GA Member No.: 2,092 |
One pulley and bushing.
Mike |
Lo-Fi Version | Time is now: 16th May 2024 - 07:38 AM |
