Turn Signal Woes!, 3 questions to maybe shed some light on my issues |
wallys914 |
Apr 27 2010, 07:55 PM
In life you don't get what you want, you get what you negoia Group: Members Posts: 190 Joined: 10-October 08 From: Garden Grove, Member No.: 9,631 Region Association: Southern California |
Ingnition on, Turn signals work!
Turn on running lights, no turn signals! Turn on headlights, no turnsignals! 3 questions now: 1) What wires go where on a 72 Front turn signal? 2) What filament bulb should be in the front of a 72? 3) Was there every 2 bulbs in a turn signal for a 914? (Mine look like the turn and running lights could be split, and it's confussin me) That's it... |
Cap'n Krusty |
Apr 27 2010, 08:58 PM
Wiring diagrams at pelicanparts.com
The Cap'n |
Mike Bellis |
Apr 27 2010, 09:10 PM
You did not mention if this is front, rear or both. If it's front, the trerminals may be flipped (running lights and turns reversed). If you look under the fender, you will see 3 terminals on the lense. two of these are riveted to the bottom. The third has no rivet and is the ground terminal. flip the two with rivets and try again. Your relpacemant bulb is an 1157.
jt914-6 |
Apr 27 2010, 09:15 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
The european front t.s. assm. had two bulbs. One for running lights and one for the t.s. U.S. versions had one bulb (1157). I have split mine like the european type as other have too and some here have european t.s. buckets in their cars.
Check for the right bulb if you have the U.S. version (1157) and clean bulb socket (s) and ground... You can check the elec. diagram here: http://www.pelicanparts.com/914/914_electrical_diagrams.htm |
wallys914 |
Apr 27 2010, 09:30 PM
Thanks guys, I will try this and get back to you.
wallys914 |
Apr 28 2010, 05:12 PM
last question:
Are the rear turn signals supposed to be an 1157 bulb as well? I think I just have the wrong bulbs installed... |
Mike Bellis |
Apr 28 2010, 06:17 PM
Lo-Fi Version | Time is now: 15th May 2024 - 05:13 AM |
