Coil wires for crane cams LX91 Ignition coil?, Bosch don't fit |
rwilner |
May 7 2010, 10:00 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
I have an LX91 (model # fixed, thanks mcmark) ignition coil. The plug wires in my car need to be replaced, so I bought the stock bosch set from PP.
The connector on the coil --> dizzy wire doesn't fit over the contact nub in on the LX91. Does anyone know what wires will fit properly? Should I get a set of magenores? |
McMark |
May 7 2010, 10:04 AM
Looks something like this:
rwilner |
May 7 2010, 10:39 AM
McMark |
May 7 2010, 11:45 AM
Yup, stock center lead won't work. Stock wires are meant to slide into a tube. You need the style that go around the pin.
You can get the supplies to make your own at most FLAPS. I got mine at NAPA. I can make a cable for you if you can't find anything else. Can't tell you off the top of my head what would work though. Too many combinations out there. |
Lo-Fi Version | Time is now: 21st May 2024 - 09:56 PM |
