| ChrisFoley |
May 8 2010, 06:07 PM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,030 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
| burton73 |
May 8 2010, 07:39 PM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 4,028 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
| ChrisFoley |
May 8 2010, 10:11 PM
Chris are those rings a press fit in the rotor or are they trapped in between the rotor and hub? Light press fit in the rotor center bore, snug fit in the wheel. What is the weight? A couple of ounces |
| jaxdream |
May 9 2010, 08:02 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
Are 2 L fuchs hubcentric ??? (IMG:style_emoticons/default/confused24.gif)
Jack / jaxdream P.S. Racer Chris - great to see that you made steering hockey pucks out of Delrin , too late for me , but others should benefit!! |
| jimkelly |
May 9 2010, 08:59 PM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
http://www.race-studs.com/servlet/Categories
* correction >> seems i need M14 x 1.5 x 65mm for 4 lug fuchs. edit - seems like 80mm stud is needed with 4 lug fuch to leave some thread showing. * correction > and M14 spherical nuts. edit - seems like nut must have R14 ball seat, not R13. oh yeah - do i double nut to install them and would i use some version of loctite to hold them in place? jim |
| DanT |
May 9 2010, 09:11 PM
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
I believe you need 14x1.5 (IMG:style_emoticons/default/smile.gif)
when I installed mine on the Puttputt, I used loctite red and double nutted them to get them in... worked great. They never moved in over 3 years of lots of on and off with different tire/wheel combinations. Attached image(s)
| Elliot Cannon |
May 9 2010, 09:17 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
http://www.race-studs.com/servlet/Categories seems i need M12 x 1.5 x 65mm for 4 lug fuchs. and M12 spherical nuts. * oh yeah - do i double nut to install them and would i use some version of loctite to hold them in place? jim My question as well. What keeps the lugs from backing out when you take the wheels off? |
| DanT |
May 9 2010, 09:26 PM
torque and loctite (IMG:style_emoticons/default/biggrin.gif)
| Rav914 |
May 10 2010, 01:44 PM
All-weather fan ![]() ![]() ![]() Group: Members Posts: 741 Joined: 15-April 07 From: WA Member No.: 7,669 Region Association: None |
For the 2.0 liter Fuchs, would I use the Porsche nuts or the spherical VW/Audi nuts? |
| jimkelly |
May 10 2010, 03:07 PM
i sure hope it does not matter as i ordered the black oxide nuts and the
M14x1.5 ACS Race Studs - 65mm - this morning - i have wanted studs for a long time. m14x1.5 ball seat nut should all be the same fit - i hope. jim |
| DanT |
May 10 2010, 03:22 PM
those should work fine Jim....Spherical/ball seat I believe are interchangeable terms for the same thing.
As long as they are not cone seat you will be good. (IMG:style_emoticons/default/smile.gif) |
| underthetire |
May 10 2010, 03:42 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Chuck Norris just tells his wheels to stay on the car...and they do.............no nuts or studs needed (IMG:style_emoticons/default/biggrin.gif) But Chuck Norris is the ultimate stud! |
| jimkelly |
May 12 2010, 07:23 AM
rav - seems like i should have ordered the porsche nuts
the lug is about 24mm wide and the nut is about 25mm wide the lug seats perfectly into my 4 lug fuch but the nut does not. according to the website - the porsche nut has a R14 ball seat ?? the one i ordered has a R13 ball seat ?? jim http://www.race-studs.com/servlet/Categories For the 2.0 liter Fuchs, would I use the Porsche nuts or the spherical VW/Audi nuts? Attached image(s)
| jimkelly |
May 12 2010, 07:30 AM
that said - i can not wait to get these studs installed : )
| jimkelly |
May 12 2010, 08:07 AM
R13 seat ball
| Rav914 |
May 12 2010, 10:04 AM
Thanks for the info. I ordered the Porsche nuts, I'll let you know how they fit.
| IronHillRestorations |
May 12 2010, 10:07 AM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,945 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
Just to be sure I'd take a Sharpie and totally black out the seat on the wheel, and then torque a nut on and see where you are getting contact. If it's a broad area you are OK, but if it shows a thin line it's a no workie.
FWIW, they do look correct from the pic. |
| Chris Pincetich |
May 12 2010, 10:39 AM
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
Ideally, the stud length/wheel/spacer combo will allow some threads to poke through the top of the open lug nut. I JUST sold the wheels I owned that accept ball -seat lugs, PM me if you need a set that I bought from Pelican. (IMG:style_emoticons/default/beerchug.gif) |
| jimkelly |
May 12 2010, 11:36 AM
regarding threads showing past nut - the pic aboev is not mounted to car, just nut threaded on stud and dropped into wheel laying on ground - but i agree.
jim (IMG:style_emoticons/default/agree.gif) Ideally, the stud length/wheel/spacer combo will allow some threads to poke through the top of the open lug nut. I JUST sold the wheels I owned that accept ball -seat lugs, PM me if you need a set that I bought from Pelican. (IMG:style_emoticons/default/beerchug.gif) |
| jimkelly |
May 12 2010, 12:35 PM
ok - i installed one set of studs and lugs - i black sharpeed on ball seat on the wheel - the lug to the left was the installed one ( see shiny leading edge ) vs never installed nut. my left nut is shiny : )
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 15th June 2026 - 05:31 AM |
