> 2056 questions, Special pushrods for 2.0 crank in 1.8 block?
70_914
post May 8 2010, 02:33 PM
Finally working on getting my engine put together, so wanted to get an idea on any pitfalls when building a stroker and big bore engine. I am sure there are plenty of people that have done this build and who may have insight. Pushrod length normal or do I need chromoly ones made? Spaces under the jugs? Spacers under the heads? Spacers under the rocker pedestals? Machine work inside the block to make it all work?
This is my first type 4 engine, but I have built 2 stock and 1 big bore type 1 engines, mazda b2200, 427 chevy hilborn injected engine, a mean little rabbit engine, my SHO v6 and a few others when I was in school. I am not looking for any basics, just anything wierd when building a type 4 bigger and better.
Thanks
Kevin
70_914   2056 questions   May 8 2010, 02:33 PM
Vacca Rabite   What cam?   May 8 2010, 02:55 PM
70_914   What cam? Delta 20 reground. Specs of a Webb 2...   May 8 2010, 03:02 PM
396   Great question   May 8 2010, 03:14 PM
McMark   The only true answer to your question is to bolt i...   May 8 2010, 05:30 PM
charliew   You can just about bet when you space a cylinder j...   May 8 2010, 06:12 PM
- Lo-Fi Version Time is now: 9th July 2025 - 08:09 AM
