Sachs Clutch Kit, Good or Bad |
rebelmdot |
May 11 2010, 12:41 PM
914ini Group: Members Posts: 224 Joined: 25-January 08 From: Tennessee Member No.: 8,625 Region Association: South East States |
Well apparently I need a new clutch. I have found a clutch kit for $321.01 The brand is Sachs. It comes with Clutch, Pressure Plate, and Throw Out Bearing.
Questions are: 1. Is this a good quality cluch kit? 2. Is this about what I should pay for it? 3. What other things should I purchase at the same time? Pilot Bearing? What else? Thank you for the replies. Christian |
detoxcowboy |
May 11 2010, 01:12 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
#1 Yes, Absolutely
#2 Yes, Wonderfull deal. #3 Assuming your doing it your self (see how to replace clutch link below.) http://www.pelicanparts.com/techarticles/9...ch_replace1.htm New Pilot Bearing and Felt Ring 2 Throw-out Bearing Guide Clips New Throw-out Fork Bushing 2 CV Joint Gaskets 2 Muffler Gaskets New Flywheel O-Ring New Flywheel Bolts New Flywheel Metal Crush Gasket Clutch Disc Alignment Tool Flywheel/crankshaft seal |
Cap'n Krusty |
May 11 2010, 01:33 PM
Flywheel bolts for a 914/4 are NOT a replacement item. They're big, don't take a lot of torque, have serrations to prevent them from backing out, and they're not torque to yield design.
You may also need a flywheel. If yours can safely be resurfaced, you'll need to shim the release arm pivot. It's a good idea to replace the transmission input shaft seal while you're in there. The Cap'n |
Tom |
May 11 2010, 02:48 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
(IMG:style_emoticons/default/agree.gif) You don't want to have to remove to replace a small item later, so do it all the first time. The while you're in there syndrome. (IMG:style_emoticons/default/biggrin.gif)
Tom |
dr914@autoatlanta.com |
May 11 2010, 03:32 PM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Well apparently I need a new clutch. I have found a clutch kit for $321.01 The brand is Sachs. It comes with Clutch, Pressure Plate, and Throw Out Bearing. Questions are: 1. Is this a good quality cluch kit? 2. Is this about what I should pay for it? 3. What other things should I purchase at the same time? Pilot Bearing? What else? Thank you for the replies. Christian Cost is $279.45 for the three pieces, all Sachs which is original equipment, but you usually need much more than just those three pieces to properly replace a 914 clutch and that is where every one with the so called "good deal" falls short. |
Lo-Fi Version | Time is now: 17th May 2024 - 06:53 PM |
