> Radio, Need to know
mk114
post May 13 2010, 10:12 AM
LOST in NO space (my garage)
Ok guys,
Anybody know which wire is switched, I need power for radio.
Ps picked up a sweet 71 for 4000 with no rust and original paint
pics to follow
McMark
post May 13 2010, 10:21 AM
914 Freak!
Fuse 9. Don't cut a factory wire. Get a piggyback spade connector and pull down the fuse panel to connect to the back of the fuse.
tod914
post May 13 2010, 10:22 AM
I seen them spliced into the thick red ignition wire behind the fuze box. Maybe a direct wire to the battery would be better so you don't fry your points when it's not running?
mk114
post May 13 2010, 10:26 AM
Thanks I always run a Piggy back too.
Cap'n Krusty
post May 13 2010, 11:05 AM
Cap'n Krusty
Do you own a test light? I don't mean to be rude (well, OK, I do, but I had to say that!), but some things are just too easy to do ..................... Doing electrical work without a test light is like nailing boards together without a hammer.
The Cap'n
KELTY360
post May 13 2010, 11:15 AM
914 Neferati
QUOTE(Cap'n Krusty @ May 13 2010, 10:05 AM) *
The Cap'n
Like this? (IMG:style_emoticons/default/headbang.gif)
jt914-6
It depends on your radio. You may need a "hot" wire for station presets and clock and one for off/on switched wire....
bandjoey
post May 13 2010, 11:16 AM
bandjoey
Don't remember the fuse # but it's obvious when looking at the connectors on the fuse panel. Pick the hot side for the radio memory and the fused side for ign on power. Of course be sure there's an online fuse on the memory wire. There were empty extra spades on my fuse panel.
mk114
post May 13 2010, 12:03 PM
The Cap'n
Yes I have one, I am at work, was hoping to hook it up at work, Light is at home.
underthetire
post May 13 2010, 12:05 PM
The Cap'n
(IMG:style_emoticons/default/lol-2.gif)
I use a nail gun then. I have a fluke scope and several multimeters.
mk114
post May 13 2010, 12:20 PM
QUOTE(underthetire @ May 13 2010, 12:05 PM) *
The Cap'n
detoxcowboy
post May 13 2010, 12:21 PM
Region Association: Africa
The Cap'n
Test lights? Just use your tongue will someone else turns the key.. (IMG:style_emoticons/default/blink.gif)
benalishhero
post May 13 2010, 02:51 PM
QUOTE(Cap'n Krusty @ May 13 2010, 01:05 PM) *
The Cap'n
The two perfect humans to have walked the earth: Jesus Christ and the Cap'n.
detoxcowboy
post May 13 2010, 03:35 PM
(IMG:style_emoticons/default/drunk.gif) Seriously though I understand you want to do this at work so you can have the radio on the drive home.. The easy test is to with key off try your lighter, if it does not work then it is on the switched circuit or broken.. look at your fuse box for the lighter symbol, wahlla done..
underthetire
post May 13 2010, 04:38 PM
QUOTE(benalishhero @ May 13 2010, 01:51 PM) *
The Cap'n
No chuck Norris and the Captn
Wait, is the Captn really chuck Norris? (IMG:style_emoticons/default/idea.gif)
Jeffs9146
post May 13 2010, 07:15 PM
Ski Bum
The cig lighter is the switched way to go and any constant hot from the fuse box! Use a spade jumper off of the back of the box from a constant hot! If you are running something with lots of power you need to run it directly from the battery!
markb
post May 13 2010, 10:05 PM
914less :(
I'll bet your car had a radio in it at some point, maybe you can find & use the original wire?
mk114
post May 13 2010, 10:35 PM
well the reason I need switched power it so it turns off with the key
markb
post May 13 2010, 10:49 PM
914less :(
That's what the stock wire does.
- Lo-Fi Version Time is now: 30th April 2026 - 06:12 AM
