Solid Engine mounts |
Pudge |
May 14 2010, 10:37 PM
Newbie Group: Members Posts: 49 Joined: 7-February 05 From: Tampa, FL Member No.: 3,568 |
Has anyone had experience with the Patrick Motorsports solid engine mounts? The transmission mounts went in easy but the outboard mounts at the front look like the front of the engine will be lower.
SirAndy |
May 25 2010, 10:04 AM
Resident German Group: Admin Posts: 41,640 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Has anyone had experience with the Patrick Motorsports solid engine mounts? The transmission mounts went in easy but the outboard mounts at the front look like the front of the engine will be lower. No experience with PMS mounts but on a '74, you already have solid outer engine mounts ... (IMG:style_emoticons/default/shades.gif) Andy |
Britain Smith |
May 25 2010, 10:38 AM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Why do you believe that you need solid engine mounts? They will suck on the street.
-Britain |
70_914 |
May 25 2010, 12:03 PM
Member Group: Members Posts: 395 Joined: 4-December 09 From: Roy, WA Member No.: 11,096 Region Association: Pacific Northwest |
Are the mounts on the front cover solid? Those should be the only rubber parts on your engine mount.
Joe Ricard |
May 25 2010, 01:11 PM
I made solid mounts out of Polyproplene. (plastic cutting board). made them the same thickness as stock. Engine was very solid and with the same sort at the trans ears shifting was pretty darn good.
Pudge |
Jun 2 2010, 10:27 AM
I made solid mounts out of Polyproplene. (plastic cutting board). made them the same thickness as stock. Engine was very solid and with the same sort at the trans ears shifting was pretty darn good. Thanks Joe for the info. I had the wrong mounts from PMS. The car is for the track and won't see much of any street time. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:22 PM |
