> V8 Conversion Kits, Kits, parts which is the best
914gem
post Apr 3 2004, 09:51 PM
Post #21
All you V8 guys and guys that have built these pocket rockets which kit or combination of parts work best. Such as quality of parts, service, instructions, cost,ect. How about some testimonys and storys from V8 people about their cars, what they used and what they wouldn't use if they had it to do over again.
914gem   V8 Conversion Kits   Apr 3 2004, 09:51 PM
chunger   Get the Renegade radiator setup. It's worth t...   Apr 3 2004, 11:52 PM
John2kx     Apr 4 2004, 06:20 AM
FriarJohn   In addition to asking Brad specifically and this B...   Apr 5 2004, 10:51 PM
Brad Roberts   Watcha thinking about 914GEM ?? I know you have ac...   Apr 5 2004, 11:37 PM
neo914-6   I tried to build a Jaide (who) kit in the 80's...   Apr 6 2004, 01:23 AM
914gem   Hi Brad, not up to to much. I have a KEP adapter a...   Apr 6 2004, 07:20 AM
Brad Roberts   Renegade all the way. No questions. Hopefully you...   Apr 6 2004, 09:53 AM
boxstr   914GEM here is a 327 with a 283 crank brings it do...   Apr 6 2004, 10:30 AM
turbo914v8   Hi all I used the old Renegade kit from the 90...   Apr 6 2004, 12:17 PM
914gem   Hi Boxstr, your engine compartment looks nice, whe...   Apr 6 2004, 12:22 PM
JmuRiz   That 305 looks pretty cool. I've always loved...   Apr 6 2004, 12:24 PM
chunger   Turbo914v8, Do you have pics? -'Chung   Apr 6 2004, 03:28 PM
Brad Roberts   Talk to us Turbo.. show us some pics.. I knew you ...   Apr 6 2004, 04:48 PM
neo914-6   Yeah Paul G, pics of your beast would be NICE. Ch...   Apr 6 2004, 06:28 PM
boxstr   914GEM thanks the pics are taken before I got the ...   Apr 6 2004, 07:32 PM
turbo914v8   I have been in contact with both Chris and Harry r...   Apr 7 2004, 09:31 AM
soloracer   Welcome Turbo914V8! That is a ton of power to...   Apr 7 2004, 11:43 AM
turbo914v8   soloracer, I took many hours and seam welded the ...   Apr 7 2004, 01:10 PM
Brad Roberts   Hey Paul, Nothing larger than a 930 CV will fit i...   Apr 7 2004, 02:06 PM
turbo914v8   Brad, Thanks for the information. I guess the obv...   Apr 7 2004, 06:26 PM
chunger   Hello, Is there a difference between 930 CV's...   Apr 7 2004, 11:24 PM
Brad Roberts   Chung, Call them and find out what the "kit" incl...   Apr 8 2004, 12:28 AM
Brad Roberts   Paul, I dont actually have a conversion car. Ever...   Apr 8 2004, 12:31 AM
chunger   Do the 911 CV's hold together ok with the 2 pi...   Apr 8 2004, 12:39 AM
Brad Roberts   The holes for the pins are too big to be tapped. T...   Apr 8 2004, 12:46 AM
chunger   Uh oh, Which part of the flanges do not fit right...   Apr 8 2004, 01:00 AM
andys   Brad, Are the 930 CV's the same size as the l...   Apr 8 2004, 09:53 AM
turbo914v8   Brad, Your work must be really grand if you are s...   Apr 8 2004, 10:26 AM
Chris914n6   Hi Chung, glad you made it here. I found a relati...   Apr 10 2004, 01:04 AM
jridder   >Billet water pump housing anyone Cool. Of cours...   Apr 11 2004, 12:00 AM
neo914-6   Seems to me if you have a clean sheet, engineering...   Apr 11 2004, 02:00 AM
John2kx   For comparison, this is the Renegade pump. I pref...   Apr 11 2004, 04:45 AM
John2kx   hikgf   Apr 11 2004, 04:48 AM
John2kx   The fixed inlet fitting on Dessert pump will more ...   Apr 11 2004, 05:01 AM
BIGKAT_83   Davids(Desert Hybrids) steel pump housing lines up...   Apr 11 2004, 06:45 AM
John2kx   Bob, The inlet fittings do appear to work when pu...   Apr 11 2004, 07:28 AM
John2kx   Looking at the RH pump again and comparing to Dese...   Apr 11 2004, 08:09 AM
John2kx   Renegade now offers this piece to aid in eliminati...   Apr 11 2004, 08:21 AM
BIGKAT_83   I used a molded rubber hose with a 90 bend it it f...   Apr 11 2004, 08:54 AM
turbo914v8   Some really great ideas in regards to fixing the p...   Apr 11 2004, 10:20 AM
Brad Roberts   I have access to the small bead roll device needed...   Apr 11 2004, 10:49 AM
Mike T     Apr 11 2004, 11:54 AM
turbo914v8   Brad, As I understand it, RH is instructing peopl...   Apr 11 2004, 07:14 PM
boxstr   John Thomas had posted athread about the thermosta...   Apr 11 2004, 07:20 PM
John2kx
- Lo-Fi Version Time is now: 2nd April 2026 - 03:33 PM
