> I think I just got vapor lock!, or my ignition is failing, again..
silverteener
post May 18 2010, 01:15 PM
Just went out to start my car to go the store and it won't turn over. The pump turns on but I got nothing. I just got back from lunch a while ago so I know it's a little hot. Will the motor turn over if you have vapor lock, or is it the ignition switch I just replaced earlier this year? it is frustrating to say the least!
detoxcowboy
post May 18 2010, 01:18 PM
Region Association: Africa
If you have vapor lock the motor will turn over, probably your ignition switch
Ferg
post May 18 2010, 01:19 PM
Sounds like starter/hot start.
CAR IN NEUTRAL!!! take a screwdriver and bridge/spark the poles on the starter wires, and try to start.
Ferg
post May 18 2010, 01:28 PM
Resident German
QUOTE(silverteener @ May 18 2010, 12:15 PM) *
I don't think so. With vapor lock, the gas in your fuelpump got so hot that it turned into vapors. That is very, very, very rare. The outside weather needs to be near baking and the motor of the car needs to be very hot. With vapor lock, the car will turn over just fine and the fuel pump will be noticeably noisy (trying to pump vapor).
(IMG:style_emoticons/default/shades.gif) Andy
TheCabinetmaker
post May 18 2010, 01:40 PM
I drive my car everyday
QUOTE(SirAndy @ May 18 2010, 02:28 PM) *
(IMG:style_emoticons/default/agree.gif) Your car did not vapor lock. Could be switch, solenoid, wiring, grounds,etc, but not vapor lock!
silverteener
post May 18 2010, 02:15 PM
thanks for the tips. Just went out to try to start it and it starts right up! hopefully it will later when I get done working!
post May 18 2010, 02:18 PM
Resident German
QUOTE(silverteener @ May 18 2010, 01:15 PM) *
Get a new starter. It's about to die ...
(IMG:style_emoticons/default/popcorn[1].gif) Andy
SLITS
post May 18 2010, 02:31 PM
"This Utah shit is HARSH!"
QUOTE(SirAndy @ May 18 2010, 01:18 PM) *
I disagree slightly ... it's probably the solenoid overheating, but you might as well get a new starter. (IMG:style_emoticons/default/beer.gif)
underthetire
post May 18 2010, 02:39 PM
And unless you really like changing starters, don't get the flaps one. Learned that by the 4th one in 4 months. BTW it's a whole lot easier to remove the drivers side tire and change it out than crawling underneath for those that don't have lifts.
I can do one now in 15 minutes, name your tune!
TheCabinetmaker
post May 18 2010, 03:08 PM
Once again, use only bosch new or bosch rebuilt starers and alternaors.
orthobiz
post May 18 2010, 04:21 PM
Given the cars are 35 or 40 years old, is it a good idea to just replace the starter at the sign of any start problems? Like it's gonna go bad soon anyway?
My car developed a mysterious problem starting last year. Sometimes hot, sometimes cold, turn the key and...nothing! The ignition switch had been replaced when I bought it 3 yrs ago. The new switch was defective and I had to replace it right away (with another aftermarket switch). So I'm wondering, how often can an ignition switch go bad?
Also, anybody have a photo of jumping the wires with a screwdriver? As in, where EXACTLY does the screwdriver go?
Thanks,
Paul
Ferg
post May 18 2010, 08:40 PM
On two cross country trips when I encountered the hot start issue, the screwdriver tricked worked for me every time, two different cars.
Two wires on the starter solenoid, using a long screwdriver bridge the poles, not at a gas pump because it will spark, and not in gear because car will lurch.
PIC
silverteener
post May 18 2010, 08:48 PM
my dad bought me some kind of Bosch low voltage relay thing but I haven't had a chance to look at it to much. I will take a picture of it tomorrow. It goes on the starter but i'm not sure what it does. I have an extra starter here I can swap out. but I am curious to see what this Bosch thing is supposed to do? Does anyone know what I am talking about?
silverteener
post May 18 2010, 08:58 PM
I found what I have on the bird.
Hot Start Relay Kit
914 1.7/1.8/2.0 (1970-76), 914-6 (1970-72), Each
You guys think I should put this on?
underthetire
post May 18 2010, 09:01 PM
Thats a relay to help with hot start problems. My car had something like it on it when I got it. Basically it takes the high current load off the ignition switch for the starter solenoid. Kind of a band aid I think, but they do work. Mine was removed when I put the new starter(s) in and have not had a problem.
silverteener
post May 28 2010, 08:24 AM
Well I still have this problem. I haven't put the other starter on yet but it's not in the best shape so I'm not sure it will work. I've driven the car the past couple days and it has started with no problems. I just went out to go somewhere and it won't start again. It sat for about an hour since I got here to work. I felt the selonoid and it does not feel hot. I guess I'll try putting on the hot start harness and see if that will help. I don't have the money for a new starter right now. I guess I'll have to jump the starter today huh.
Drums66
post May 28 2010, 01:02 PM
914 Rudiments
QUOTE(underthetire @ May 18 2010, 08:01 PM) *
Call it what you want? but.........I have'nt had an issue since I put 1 on!
( been many many moons)
P.S. even after long periods of sitting!)
SLITS
post May 28 2010, 01:06 PM
QUOTE(silverteener @ May 28 2010, 07:24 AM) *
It's not so much the solenoid getting overheated, it's the contacts inside that get burned and do not make good contact. Try whacking it with a hammer (or other suitable tool). On old Chevys we would take the solenoid apart and filp the copper contact disk inside ... wella, a new starter (almost).
Oh, and for a hot start relay, I use a cheap ass Ford solenoid ($6). Doesn't come with the wires, but comes with instructions. Anybody need one or some?
Drums66
post May 28 2010, 01:13 PM
914 Rudiments
Ya.....I agree starter and solenoid issue's must
be corrected first or it is a............can't say it! (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/popcorn[1].gif)
Todd Enlund
post May 28 2010, 01:14 PM
Resident Photoshop Guru
My car had a Ford starter relay wired in when I got it.
- Lo-Fi Version Time is now: 8th July 2025 - 11:03 AM
