Need a quick measurement |
underthetire |
May 18 2010, 04:55 PM
Anyone have a rotor they could measure? I need the diameter of the hat. Making wheel spacers tonight and need to know what OD to cut them to.
RJMII |
May 18 2010, 05:08 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
I've got a rotor sitting right here in front of me... now to find a tape measure since my calpers don't go that big...
and I'm getting 168cm. want pics? |
underthetire |
May 18 2010, 05:19 PM
I've got a rotor sitting right here in front of me... now to find a tape measure since my calpers don't go that big... and I'm getting 168cm. want pics? Perfect! Thank you! That sounds like a good number to me. (IMG:style_emoticons/default/biggrin.gif) |
RJMII |
May 18 2010, 05:22 PM
need any others while I've got it here? OD of the hub centric lip? height of said lip?
May 18 2010, 05:30 PM
3
Cap'n Krusty |
May 18 2010, 06:28 PM
I've got a rotor sitting right here in front of me... now to find a tape measure since my calpers don't go that big... and I'm getting 168cm. want pics? 168CM is 66.1417 inches. That's a SERIOUS "big brake" conversion. I'm thinking the size of some of those mining truck brakes ........................ Wonder what those wheels cost? Note this is a Carrera, says so right on the front of the bed. The Cap'n Attached image(s) |
RJMII |
May 18 2010, 07:15 PM
I think I must have grabbed the wrong rotor, or forgot to put in my dot.
16.8CM or 168mm. I'm sure Jeff got the idea and was able to |
underthetire |
May 18 2010, 08:57 PM
Yes, thank you very much. My 1 1/4" hub centric front spacers are now done. Time to call eric and get some brake pads coming so I can stop this thing a little easier. I sure love having the metalworking hobby shop on tuesdays.
76-914 |
May 18 2010, 09:28 PM
underthetire |
May 18 2010, 09:49 PM
One more measurement if anyone has a rotor available. Looking for the thread depth for the stock lug bolts or thickness of the rotor where the studs get pressed in. (IMG:style_emoticons/default/beer.gif)
May 18 2010, 10:42 PM
3
Cap'n Krusty |
May 18 2010, 10:54 PM
I think I must have grabbed the wrong rotor, or forgot to put in my dot. 16.8CM or 168mm. I'm sure Jeff got the idea and was able to You're probably right, but my answer was more fun .......... (IMG:style_emoticons/default/lol-2.gif) The Cap'n |
Root_Werks |
May 19 2010, 09:44 AM
Village Idiot Group: Members Posts: 8,320 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
effutuo101 |
May 19 2010, 12:51 PM
Advanced Member Group: Members Posts: 2,734 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
Datsun 280z...wait, what was the question?
RJMII |
May 19 2010, 01:52 PM
Jeff, do you still need the other measurement? I can go grab my rotor again.
RJMII |
May 19 2010, 01:55 PM
I think I must have grabbed the wrong rotor, or forgot to put in my dot. 16.8CM or 168mm. I'm sure Jeff got the idea and was able to You're probably right, but my answer was more fun .......... (IMG:style_emoticons/default/lol-2.gif) The Cap'n You're definitely right, your answer was more fun. (IMG:style_emoticons/default/aktion035.gif) |
underthetire |
May 19 2010, 02:54 PM
Jeff, do you still need the other measurement? I can go grab my rotor again. I could use it, but if you don't have time it's ok. I was trying to get studs on order today, but now that I discovered I no longer have any real front brakes on the way home yesterday (IMG:style_emoticons/default/blink.gif), i'm gonna start tearing it down tonight. |
RJMII |
May 19 2010, 03:13 PM
Jeff, do you still need the other measurement? I can go grab my rotor again. I could use it, but if you don't have time it's ok. I was trying to get studs on order today, but now that I discovered I no longer have any real front brakes on the way home yesterday (IMG:style_emoticons/default/blink.gif), i'm gonna start tearing it down tonight. Let me know if you end up needing new rotors; I have this pair that I've been measuring for you that I have no use for. They are off of 73-76 car, and have very few miles on them. They'll need some slight surface rust scuffed off, but you can have them for cheap. (I went 5 lug shortly after getting the car, and the had PO just had the brakes redone. He even gave me fresh receipts from pelican and the shop that did them) |
underthetire |
May 19 2010, 03:17 PM
Jeff, do you still need the other measurement? I can go grab my rotor again. I could use it, but if you don't have time it's ok. I was trying to get studs on order today, but now that I discovered I no longer have any real front brakes on the way home yesterday (IMG:style_emoticons/default/blink.gif), i'm gonna start tearing it down tonight. Let me know if you end up needing new rotors; I have this pair that I've been measuring for you that I have no use for. They are off of 73-76 car, and have very few miles on them. They'll need some slight surface rust scuffed off, but you can have them for cheap. (I went 5 lug shortly after getting the car, and the had PO just had the brakes redone. He even gave me fresh receipts from pelican and the shop that did them) I know I need rotors, after the pad came off it was pretty obvious. I'll PM you. |
RJMII |
May 19 2010, 04:19 PM
Crude measurement:.580" on the thread depth. I'll go inches this time, since I screwed up metric last time. (IMG:style_emoticons/default/lol-2.gif)
Lo-Fi Version | Time is now: 16th May 2024 - 09:24 PM |
