WTB: Driver side front A Arm and strut assembly for late 914, To repair WCR rock damage... |
ConeDodger |
May 19 2010, 08:05 PM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Some of you may be aware that while driving my 914 up to WCR jcd914 encountered a bowling ball sized rock laying in the road. The collision was unavoidable and the damage is concerning but doesn't appear to be terminal.
The rock impacted the A Arm just inboard of the ball joint and there is a bend in the A Arm proximal to the impact. I am looking for an A Arm from a 75 914 to replace it. Also, the strut housing appears to be leaking the cooling oil at the bottom. We will be checking the Koni Adjustable strut to make sure it is straight and it does appear to work but we expect the housing has a crack in it. So similarly, we are looking for a 75 914 driver side front strut. Got 'em? |
martin914 |
May 19 2010, 08:21 PM
martin914 Group: Members Posts: 48 Joined: 23-October 05 From: beauharnois cdn Member No.: 4,987 |
Some of you may be aware that while driving my 914 up to WCR jcd914 encountered a bowling ball sized rock laying in the road. The collision was unavoidable and the damage is concerning but doesn't appear to be terminal. The rock impacted the A Arm just inboard of the ball joint and there is a bend in the A Arm proximal to the impact. I am looking for an A Arm from a 75 914 to replace it. Also, the strut housing appears to be leaking the cooling oil at the bottom. We will be checking the Koni Adjustable strut to make sure it is straight and it does appear to work but we expect the housing has a crack in it. So similarly, we are looking for a 75 914 driver side front strut. Got 'em? Hi i have two set for sale powdercoated in black $40.00 a pair check my add in the classified.thanks.Martin |
bdstone914 |
May 19 2010, 08:24 PM
I got you covered. Giving you a call now.
ConeDodger |
May 20 2010, 12:34 PM
Jakeodoule |
May 20 2010, 03:13 PM
Member Group: Members Posts: 353 Joined: 10-October 08 From: Des Moines Iowa Member No.: 9,630 Region Association: Pacific Northwest |
I have one you can have for free, you pay shipping.
Off of a 75. Could get it pulled by the end of next week. John |
strawman |
May 20 2010, 06:26 PM
Senior Member Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
What happened to the set I traded a 12-pack for? Will those not work?
Geoff |
ConeDodger |
May 20 2010, 09:45 PM
strawman |
May 21 2010, 01:35 PM
What happened to the set I traded a 12-pack for? Will those not work? Geoff Forgot. Are the early or late? I need late and I need a strut housing. They're off my late '73. I tossed the strut housings, since no one responded to my pleas to take 'em off my hands! |
ConeDodger |
May 21 2010, 10:06 PM
What happened to the set I traded a 12-pack for? Will those not work? Geoff Forgot. Are the early or late? I need late and I need a strut housing. They're off my late '73. I tossed the strut housings, since no one responded to my pleas to take 'em off my hands! Well then, I will check them for swaybar tabs and blast them and PCoat them. By the way, now that the struts are gone, I will take them off your hands. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 09:02 PM |
