Pictures of car w/removed engine shelf sheetmetal? |
Mueller |
Apr 4 2004, 02:59 PM
I thought I've seen this modification before on here, but I cannot find the pictures.
On my car the pass. side sheetmetal was hacked for an A/C installation. I'm debating repairing it or removing it completely. Since my engine tin will be cut and trimmed as well, I don't see any real reason to keep the sheetmetal on the sides Attached image(s) |
McMark |
Apr 4 2004, 03:15 PM
It's not very difficult to remove that piece. A few spot welds and some well placed cut with a cut-off wheel and it's gone.
dmenche914 |
Apr 4 2004, 03:38 PM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
Mike: i replaced an engine shelf once, was not too difficult with a MIG welder. If you run an aircooled motor (either 6 or 4 banger) the shelf need be sealed, either with a new shelf, or some sort of patch, else the cooling fan will draw hot air from under the car. If you add a water pumper engine, then it is only cosmetics that are a concern.
I found with a VW (kit car) a huge temp difference with verses without all the stock cooling tin that seals the engine compartment, something on the order of at least 50F head temp, and simular on oil temps. HPH probably can get you a new part, or maybe even one from a parted out car for less money. By the way, how is the 1.8 engine? hope it is working good for you. let me know dave menche |
bernbomb914 |
Apr 4 2004, 04:37 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
restoration design has a piece to replace that piece it is not diffecult to do, look at my earless piece for pics.
Bernie |
bernbomb914 |
Apr 4 2004, 04:40 PM
xx
Attached image(s) |
Jeroen |
Apr 4 2004, 05:24 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Here's one...
cheers, Jeroen Attached image(s) |
Korijo |
Apr 4 2004, 06:48 PM
[]D o [] o []V[] o []D Group: Members Posts: 1,308 Joined: 16-July 03 From: North Bend, WA Member No.: 914 |
Heres mine removed...
(IMG:http://www.nwfreshmarkets.com/914_24.jpg) and replaced. battery will be moved... (IMG:http://www.nwfreshmarkets.com/914_36.jpg) |
Chris914n6 |
Apr 4 2004, 11:22 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
My favorite site (IMG:style_emoticons/default/smilie_pokal.gif) there's a few from different angles in a bland primer.
Chris |
Lo-Fi Version | Time is now: 17th May 2024 - 06:33 PM |
