TWM Throttle Bodies, TWM throttles, SDS efi turnkey system |
Teknon |
May 21 2010, 07:05 AM
The more I learn the dumber i think I am Group: Members Posts: 357 Joined: 10-August 04 From: Denver, Colorado Member No.: 2,505 Region Association: Rocky Mountains |
I purchased an after-market efi system from a southeast coast supplier as a turn key system for a 914. (IMG:style_emoticons/default/aktion035.gif)
They came without manifolds, without adapter extensions to clear the fuel rails, without linkage, and without filters. (IMG:style_emoticons/default/headbang.gif) I have contacted this supplier many times and have yet to get a straight answer or proper direction to find a solution. So I purchased the CB Performance 914 linkage kit and the throttle extensions directly from TWM . (IMG:style_emoticons/default/hissyfit.gif) Problem is the CBs linkage does not have the same bolt pattern as the throttles and TWM has no clue what will fit them. (IMG:style_emoticons/default/confused24.gif) I have spent more than $400 more over the "turnkey" price of nearly $4000 to make these work. I am left in the dark and with any help from the suppliers on how to make this system fly. (IMG:style_emoticons/default/poke.gif) My question is: Does anyone know what my options are? With over $4000 invested I am left hanging. I need to get this remedied I have too much invested at this point. (IMG:style_emoticons/default/mad.gif) I figured 914 World can help me out, for I have exhausted all my other options. (IMG:style_emoticons/default/pray.gif) |
bfrymire |
May 21 2010, 10:40 AM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
Pictures? Might help in seeing what you need. SDS should also be very helpful.
-- brett I purchased an after-market efi system from a southeast coast supplier as a turn key system for a 914. (IMG:style_emoticons/default/aktion035.gif) They came without manifolds, without adapter extensions to clear the fuel rails, without linkage, and without filters. (IMG:style_emoticons/default/headbang.gif) I have contacted this supplier many times and have yet to get a straight answer or proper direction to find a solution. So I purchased the CB Performance 914 linkage kit and the throttle extensions directly from TWM . (IMG:style_emoticons/default/hissyfit.gif) Problem is the CBs linkage does not have the same bolt pattern as the throttles and TWM has no clue what will fit them. (IMG:style_emoticons/default/confused24.gif) I have spent more than $400 more over the "turnkey" price of nearly $4000 to make these work. I am left in the dark and with any help from the suppliers on how to make this system fly. (IMG:style_emoticons/default/poke.gif) My question is: Does anyone know what my options are? With over $4000 invested I am left hanging. I need to get this remedied I have too much invested at this point. (IMG:style_emoticons/default/mad.gif) I figured 914 World can help me out, for I have exhausted all my other options. (IMG:style_emoticons/default/pray.gif) |
McMark |
May 21 2010, 10:52 AM
Do you have IDF or IDA style throttle bodies?
gothspeed |
May 21 2010, 11:06 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
rfuerst911sc |
May 21 2010, 11:53 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
What kind of " turn key " kit doesn't contain all the parts needed ? I assume you have contacted them and they said what ? And who is it so others can stay away !!!
McMark |
May 21 2010, 12:22 PM
They use different manifolds, and the air cleaner studs are different.
Teknon |
May 21 2010, 06:35 PM
Teknon |
May 21 2010, 06:38 PM
What kind of " turn key " kit doesn't contain all the parts needed ? I assume you have contacted them and they said what ? And who is it so others can stay away !!! They said everyone has different application, but i'd like to know how many applications there are for a 914. |
May 21 2010, 07:44 PM
Your core problem is how to mount the throttle linkage?
If that is correct, post a picture of both the throttle bodies and the air cleaner base (you got from CB) There are many choices for throttle linkage setups. Rich |
McMark |
May 21 2010, 08:00 PM
You're link is to the TWM homepage where they list both IDF and IDA style throttle bodies. I'm assuming you're cross referencing a part number or something? We're gonna need a lot more information/pictures to help you out. |
rick 918-S |
May 21 2010, 08:04 PM
Hey nice rack! -Celette Group: Members Posts: 20,457 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
lotus_65 |
May 21 2010, 08:38 PM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
box it up, send it back.
run carbs for now. these guys may not know how big the 914 market could be for a clean, well engineered system- i know i'd rather run a more modern efi setup. gl thefleur |
Mark Henry |
May 21 2010, 09:00 PM
The CB air cleaners and linkage won't fit, although the base of the TMW TB will be the "IDF" pattern the top, the part that bolts to the air filter and linkage is the wrong pattern.
You most likely need to use a bell crank type linkage and the little K&N single barrel filters. |
moparrob |
May 21 2010, 09:10 PM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
Not meaning to hijack your thread, but, since we are on the topic, how do the CB throttle bodies/manifolds stack up as compared to others like the TWM and the other ones from Jenvey? I like the fact that CB has the pressurized hats for a turbo set up. Does anyone make them for TWM's?
Thanks Rob |
rhodyguy |
May 21 2010, 10:29 PM
i have a set of cb talls that have 2 different sets of stud holes for the carb mount and will work for either the 3 or 4 bolt heads. are yours the same? $4.4k for a fi setup-ZIOKS!!!
Teknon |
May 22 2010, 07:28 AM
Teknon |
May 22 2010, 07:32 AM
i have a set of cb talls that have 2 different sets of stud holes for the carb mount and will work for either the 3 or 4 bolt heads. are yours the same? $4.4k for a fi setup-ZIOKS!!! They bolt up fine off the manifolds. They bolt up fine to the throttles. It is bolting the CB linkage/filters that in question. And yeah for that money you would think you would get help. |
JamesM |
May 22 2010, 10:30 AM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Ouch! For $4k I would build you one of my efi systems and then fly out and install the thing myself. I can not believe they are not supporting you on this.
Post some pictures, it might help with figuring out a solution... I purchased an after-market efi system from a southeast coast supplier as a turn key system for a 914. (IMG:style_emoticons/default/aktion035.gif) They came without manifolds, without adapter extensions to clear the fuel rails, without linkage, and without filters. (IMG:style_emoticons/default/headbang.gif) I have contacted this supplier many times and have yet to get a straight answer or proper direction to find a solution. So I purchased the CB Performance 914 linkage kit and the throttle extensions directly from TWM . (IMG:style_emoticons/default/hissyfit.gif) Problem is the CBs linkage does not have the same bolt pattern as the throttles and TWM has no clue what will fit them. (IMG:style_emoticons/default/confused24.gif) I have spent more than $400 more over the "turnkey" price of nearly $4000 to make these work. I am left in the dark and with any help from the suppliers on how to make this system fly. (IMG:style_emoticons/default/poke.gif) My question is: Does anyone know what my options are? With over $4000 invested I am left hanging. I need to get this remedied I have too much invested at this point. (IMG:style_emoticons/default/mad.gif) I figured 914 World can help me out, for I have exhausted all my other options. (IMG:style_emoticons/default/pray.gif) |
Teknon |
May 22 2010, 10:40 AM
Here's the pic. I decided to just redrill holes in the that was suggested.
Teknon |
May 22 2010, 10:51 AM
Okay NOW here it is
Lo-Fi Version | Time is now: 15th May 2024 - 12:47 PM |
