Time for front sway bar, Install and bushings? |
BigDBass |
May 21 2010, 02:44 PM
Dumb Question Champion Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
A couple years ago, Brad Mayeur (914LTD) welded in Weltmeister front sway bar mounts while replacing fuel lines in my '74 2.0. I already had U-tabs on my A-arms. I finally got around to getting a set up to install and went with a stock. I believe that would be a 15mm, right? I need to buy bushings for this. It seems to me that I need 4 drop link bushings and 2 cup bushings, but wanted to make sure that was all I need. Is that all? (I figured to get them from Pelican Parts.) My other question is: Does the gas tank have to be removed to install the bar, or is the tank removal only required for installing the mounts? Thanks! |
Lo-Fi Version | Time is now: 16th May 2024 - 08:46 PM |
