BigDBass
May 21 2010, 02:44 PM
A couple years ago, Brad Mayeur (914LTD) welded in Weltmeister front sway bar mounts while replacing fuel lines in my '74 2.0. I already had U-tabs on my A-arms.
I finally got around to getting a set up to install and went with a stock. I believe that would be a 15mm, right?
I need to buy bushings for this. It seems to me that I need 4 drop link bushings and 2 cup bushings, but wanted to make sure that was all I need. Is that all? (I figured to get them from Pelican Parts.)
My other question is: Does the gas tank have to be removed to install the bar, or is the tank removal only required for installing the mounts?
Thanks!
bobhasissues
May 21 2010, 02:59 PM
You got it.
15mm is the factory stock size.
You should be able to push the bar through one size and out the other without removing the tank.
4 droplink and 2 cups will do it.
